dpmiller
Everything posted by dpmiller
I'd always seen RS's pricing as building in the shipping cost...
LG Therma V Monobloc CH14 flow error
dpmiller replied to Tim Pearson's topic in Air Source Heat Pumps (ASHP)
^ not sure if anyone other than RED modulate heating flows in that manner? Has the OP confirmed that this particular ASHP has an internal circulation pump, and that it is actually functioning correctly? -
has the pump got 2 cables plugged in or just 1 mains supply? PWM pumps have a second signal wire to tell them what to do... -
^ chap that did our screeding had a similar story. Dyed-in-the-wool Ford man, til about three years back when his last Transit left him stranded twice, parts took for ever to arrive, and then the repair was botched for good measure. He's now in a MAN sprinter clone and will *never* touch Ford again.
I was told beware the gear oil in French vans
dpmiller replied to CalvinHobbes's topic in General Self Build & DIY Discussion
that's only the odo on the dash, what about the one embedded in the ECU (s)? -
3 port motorised valve should move 90 degrees or 180 degrees?
dpmiller replied to me123's topic in Boilers & Hot Water Tanks
the drawing in the catalogue shows two rectangular rubber plates on a sprung mount, 90deg apart. If the drawing is accurate that means opening one port and closing the other only requires 90deg as it's switching from one plate closed, to the *other* one closed. But I've never been inside one of these so can't confirm. /edit or is there in fact only one valve plate? @Nickfromwales? -
The wired remote is literally a clone of the front panel, but you can only fit one AFAIK so I'm presuming you're actually just fitting boost switches in the other rooms? In control mode 1, you can set a time period for "normal" and it will drop back to "low" outside those times. Obviously you can set low to be as low as you want. The front panel button operates Boost. In control mode 2 you can toggle between speeds using the front panel button, plus three of the input terminals can connect to a 3-way switch for manual selection of a speed. Appendix 1 of the manual details this alternative mode.
According to the PDF, your Sunvic is motor-on, motor-off, with slipseal, and the image implies it's 90deg from side to side.. Have you got the shaft 180degrees out of position maybe? Or could it be a different valve "under the cover"? -
Looking at getting a van, what do you think?
we're not in Ireland tho, and the Irish vehicle test is the NCT. PSV /public service and (more likely) LGV/ light goods are the applicable tests for that class of vehicle but the term is used a bit interchangeably, never mind that some vans can be taxed as cars too and then would be MoT'd... -
can this time not be adjusted in the menus? -
100% might be the max limit. On our CoolEnergy, there are settings for min and max, and for a higher startup setting (probably to ensure the flowmeter trips before settling back into deltaT control) as well as the actual deltaT across the ASHP. -
Ecoforest 20kW (vs two Vaillant Arotherm 10kW)
dpmiller replied to drcarrera's topic in Air Source Heat Pumps (ASHP)
the Ecoforest looks like it's actually rated at 13kW? -
You'll not find much with that rating as it's USA only. It translates to an F7 filter in EU- speak and you should find that quite a few units can have F7s or better installed. I'm more than happy with our vent-axia although I'm sure some on here will tell you that only the fancy European Passiv- approved units are worthwhile
yes.
Kingspan heating (or lack of) issue
dpmiller replied to Lynford's topic in Air Source Heat Pumps (ASHP)
circulating pump is running and air is bled? -
a pump's flow can add or remove a surprising amount of pressure
yes, the chain isn't so critical. Presuming the parts interchange and there's no real wear, why not just use the old shaft so you can have the smaller sprocket?
oversizing the mounting holes on the bracket for the motor would be an option, and slather a load of grease on it, white "plastic" grease or PTFE bicycle grease (very similar)) would be my choice
looking at the wear, I've got to ask a. can you bring the worm down a bit for deeper engagement and b. what kind of grease are you using?
IR thermometers aren't dear. eg- https://www.amazon.co.uk/Infrared-Thermometer-Helect-Non-contact-Digital/dp/B071NBJJ2Q/ref=sr_1_28?crid=XIQA3RQD1FCO&keywords=ir+thermometer&qid=1671729727
Octopus Cosy - new tariff for ASHP owners
dpmiller replied to George's topic in Air Source Heat Pumps (ASHP)
Our el-cheapo mixers work perfectly well down to mid-40s. -
Salus Auto Balancing Actuators - Problems!.
dpmiller replied to Miller3857's topic in Underfloor Heating
sounds like you need to increase the flow in the main circuit, to send more heat energy to the mixer, then. Don't worry about calculated flows in the loops too much, the deltaT might be more telling. Does your particular mixer sense on the flow side, or the return? And are there any bypass settings? What mixer is it? -
what does "saturating the pump" mean please? -
worth having a flowsetter inline, just for visual confirmation. So restriction or airlock?
Walabot uses this kind of tech, an array of antennas
