dpmiller
    4
Everything posted by dpmiller
  1. @crispy_wafer what size Solido is it? I've just checked our documentation and the 6-8PE is 150kg, needing a 180cm dig, it's got a lifting eye on top and no concrete required... best practice is to steadily fill with water as you backfill, to equalise the loading although the moulded tank can take full load either way unsupported
  2. not how it works. You made the assertion...
  3. certainly not the cheapest in the UK. Maybe the GB part of the UK? I passed two stations yesterday here both at the same 130.9...
  4. Our HP will happily switch itself from cooling to DHW if it needs to. Plus how long do you think you'll need to run it for to take a wee bit of extra heat out of the house?
  5. OT, but how much are diesel and unleaded at the mo with you?
  6. I'd love to see some actual data on that, if you have it?
  7. I'm guessing the spark meant compressor, not condenser.
  8. better not forget the locking collets on the JG fitting if it's going to be unseen...
  9. depends. ASHP tops the tank up- and catches better half's morning shower- during the E7 period in winter. Currently the PV is diverting to it.
  10. Depends on the standing charge surely?
  11. Fan? if you're savvy electronically, you might open it up and see if you can ascertain the offending board area or component; a blob of silicone might well damp the culprit.
  12. why do you think you need 4-core to a boost switch? It only needs to be a momentary contact closure.
  13. 230kg sounds like an awful lot, is this a Conder with a steel frame underneath? I don't think our Solido would've been over 100kg. We used out 2.7t machine to install it, but there's no way it would've had the reach to lift it off a wagon.
  14. well 70 is already scalding temperature so you should be able to confirm a tempering valve on your hot tank? If so then yes, it's safe.
  15. so during the day they won't notice the light and it will burn needlessly. The corner of a shelf in the hips/ ribs OTOH might just focus the mind...
  16. nope, that's just an overflow tank to catch anything from the safety valve.
  17. Look at LBS Snowdon. Slate-looking clay tile. Great job...
  18. ...but hang on, you say it's a drainback system? Are there any valves that have erroneously been shut off that might be restricting that?
  19. I wouldn't expect it to immediately start doing things if it's already at elevated temperatures. Change the settings and monitor it tomorrow on heat-up.
  20. At 70c you must have a tempering valve on your tank to protect users, so why not just increase store temp to 80c or more? Is this a drainback system? How many sensors are connected? what is the setting for EM, collector limit?
  21. my reply was aimed at @saveasteading, sorry. Have you been charged for the engineer's time, designing the plant in the wrong place?
  22. I'm not talking about in industry or commercial development. Looking at the size of a house to size a treatment plant aint rocket science?
  23. As @JohnMo says, Beam will flog you something in a very retail manner. Personally I went BPC for design and hardware, but acquired the main unit off Ebay and bought everything else from them. I self-installed...
  24. why is a SE speccing something non-structural?
