Everything posted by markc
Could be gap for door itself or he may mean the frame to allow wood or tiles to slot underneath. I have just done some frames with 15mm underneath and wish I had left more … it was a pig of a job slotting the 8mm click fit planks under with 5mm underlay. 20mm under a door for underlay and carpet sounds pretty good
Window drain / cill detail in tilt and turn units
markc replied to MrMagic's topic in Windows & Glazing
Anything that opens and closes is likely to need a drain of some sort -
Cool spot, a bit of smoke won’t hurt the tree unless you are burning creosote etc.
How close when face to face buildings?
markc replied to Post and beam's topic in Building Regulations
And all the “beautiful country setting detached homes” being thrown up on chicken hut estates around here. Detached and a slim person cannot squeeze between the 🤪 plus narrow roads and parking spaces that only smart cars fit into. Guy I know has a mini and that hangs over the pavement with bumper touching his down pipe -
Bugger! Yes it’s a pain to remove. Even pointing will be tedious because bitumen will clog the grinder or cutter used for raking out the old mortar.
Now that looks like it has set hard, if you pick at it does it flake off? if so then sand blasting or a needle gun or wire brush on a grinder will remove it.
Welcome. Bitumen paint is a real pain to remove, even sand blasting takes time because bitumen is pliable and most of the sand bounces off. Hard iron shot will quickly remove it but that really needs to be done in a tented area, not in the open
Omg! This is ridiculous! Get another SE quick
Looks like he is speccing a channel which would be RSC never seen VC. Channel would make sense but a 254 is a biiiig channel. 16mm end plates? Are you building a nuclear bunker? I would be getting a new SE and probably save you a fortune in steel fab and erection costs
Assuming all reinforcing is clamped or welded then it can be used to enhance earthing and would simply need a cable and earth spike, but as you are unlikely to have a fully clamped or welded cage then it’s pretty pointless.
Hmmm, wonder if trichloroethylene will work? Might have to try it.
As it’s there I would keep it.
It’s cutting oil, mix it roughly 1 part oil to 20-30 of water. WD is good but a squirt from a spray bottle or washing up liquid bottle every few seconds keeks the bits cool .. more important on the bigger diameter cutters.
I would ‘mole’ under the road if it’s public and only single track (single track causes a lot of hassle to get a permit to dig/close). you dig the two holes either side of road and all the trenches and save yourself a fortune.
Rotabroach (or other generic annular cutter) is also great for adding another ‘half’ hole to existing for misaligned holes. use plenty of water (preferably with soluble oil) to keep the cutters cool and they last for ages before needing a regrind
Did they detail what the MSC is? …. Marine Stewardship Council maybe, Midlothian Stolen Cycles? I wouldn’t bank on it being worth the money it costs
if you are going deeper than their footings and there is a chance of excavation collapse etc then yes you do need an agreement, but this doesn’t have to be anything fancy or expensive. you details the works to be done, show what measures you are putting in place to prevent damage to their property and what you will do if something does happen that affects them.
Hi and welcome. Do you really need a party wall agreement? As you are not fixing to, altering or undermining their property there should be no problem or reason. sounds like you have tried to be considerate and respect their privacy etc. I would just crack on with it now
How to board loft - advice please!
markc replied to Porthole's topic in Lofts, Dormers & Loft Conversions
And I just assumed trusses, but maybe not. Everyday is a school day -
Unless the truss bottom cords are very small and not suitable for load bearing (in which case you should not board or use for any storage) then 90 degree timbers are not detrimental as they are fairly light compared to the flooring and any subsequent storage. ensure all trusses are screwed to the new timbers to distribute the loads and tie all trusses together -
Siberian larch vs sweet chestnut cladding
markc replied to PeachyBeechy's topic in General Construction Issues
Cupping really depends on how and when the timber was cut. quarter sawn timber will not cup at all but doesn’t look as nice grain wise, flat sawn timber is for aesthetics and fantastic grain pattern but will not stay flat left on it’s own. -
Reducing accidents for elderly
markc replied to CalvinHobbes's topic in General Self Build & DIY Discussion
RCD for scald protection? Anyone ever had an element rupture? Is it painful? -
I agree, UK seems obsessed with concrete for foundations and slabs whereas many places around the world build on timber founds, posts and floors
- 16 replies
- ground screws
- timberframe
@zoothorn well done sir, looks good
Discount Offers of the Week
markc replied to Ferdinand's topic in General Self Build & DIY Discussion
Picked one up on my way in today
