Everything posted by markc
Base size and configuration depends on the loads being imposed. A canopy has mass (weight) to distribute and uplift or overturning moments that need to be held down. a swing gate is a cantilever and produces a rotation load onto the pillar and it’s base. So the posts need to withstand bending and the foundation must have sufficient bearing on the ground to prevent it ‘cutting through’ the earth. brick pillars need to be massive or be brick around a steel or concrete core
Vibration transference from wall mounted ASHP?
markc replied to MikeMc's topic in Introduce Yourself
+1, I would fix brackets solid and float the unit -
Is installing guttering an easy job?
markc replied to Thorfun's topic in Rainwater, Guttering & SuDS
Absolutely, I have seen it done the other way … down pipes at each end and low point in the middle … and looked more like a roller coaster than a gutter -
Anti vibration mounts are used extensively in fridges, air con etc. They are simple rubber blocks with a stud or threaded hole on each end. no idea what the unit suppliers charge for them but very low cost on eBay or RS components (rare I can say that) -
If you have DP’s at both ends then high point in the middle yes -
Loads of existing. Buildings have smaller half landings, back to stair angle, domestic max is 42 deg, commercial is 38 deg. I’m 6-3 and I find any stairs lower that 38 deg hard work because I’m always deciding between short or double stepping. Our office main stairs are 37 degrees and loads of people trip on them but maybe because tread is on the min side. if I was designing and building a stair for myself I would be looking at 38.5-40 degrees for comfort or maybe down to 38 if the stair was going for aesthetics
That would work
36 degrees is really shallow for a domestic stair, making some risers 1mm different seems odd, does the calculator not have the option for .5 mm. as this is an existing property you have a little more “tolerance” and your floor coverings could easily explain a few mm at the bottom. is the 900 overall? Or tread width? If it’s tread width then the landing should be the same or bigger, but if it’s 900 overall then taking out the stringers thickness puts you very close to the 840. The jutting out first step after landing shouldn’t encroach on the landing so that could do with moving forward or being hidden by a newelpost. 184 rise to 190 is a big jump, it would be worth a moch up with some scaff boards to try a short section.
Good morning and welcome
Agreed. pre hang (fit) doors into casings, use 2mm packers top and sides, screw casing to door with screws at an angle so they can be taken out after fitting casing (you never see the tiny holes after plugging and finishing). this makes fitting a doddle and ensures nice even gaps. if your dad does not have a trim router then buy him one, cheap one is fine and so much better than chiselling hinge rebates. Look on YouTube for routing hinges to make a cheapie jig
No problem with that landing and if you must have a different step then it needs to be at the bottom to prevent falls. Amazing how a small difference in rise or going part way up or down a flight catches people out
Insulation has to be your main priority, also looks like single glazed windows so very draughty. UFH would not supply enough heat without sorting the insulation and droughts first. Ceilings look high so you can afford to loose some for floor build up but it’s a lot of work with doors etc. GSHP is a no go unless you have a field at the back. new windows, roof checked, roof insulation, cavity wall ins then start looking at the other stuff
If anyone broke in and ransacked my garage or workshop they would probably leave it tidier than they found it
Looks worse because someone has attacked it with a grinder. Don’t worry about it and as above, decoupling mat will protect the tiles. all screeds shrink, just slowly and there are thousands of tiny cracks a bit like crazy paving, you have just concentrated them into one spot.
Do you have a picture of the cracks? I’m assuming these are fine shrinkage ones and not big open movement cracks. I think the tiler is ars£ covering saying they will line tiles up with the cracks as I really don’t believe this is anything serious
If you can go around the outside then do it! The extra bit of cost will be outweighed by peace of mind. couple of years ago saw a new build where drains were run under properties and one needed the whole ground floor digging out after settlement destroyed a pipe run. Then again the mass builder also didn’t dig footings - they heaped type1 on the inside and soil outside to form trenches 🙈
As it’s fixed to the building, do you know the depth of the existing footings? Ideally the new structure should be footed at the same depth.
Window drain / cill detail in tilt and turn units
markc replied to MrMagic's topic in Windows & Glazing
That’s it -
Don’t worry, you haven’t ruined it. Better to learn now than crack tiles. Screed often cracks between rooms and doesn’t affect the floor. Tiler is doing right thing using decoupling mat.
@zoothorn sorry I didn’t realise (read) you were using twin wall, I figured it was a simple ‘shed chimney’ needing a rain protector China mans hat (pretty sure you can’t call them that now)
Depends on design, many cowls are on spring legs, some need a pilot hole and a self tapping screw
didnt think Wind turbines would be something I'd be talking about you will be amazed, and probably shocked and confused etc etc at some of the things we end up talking about on here,
Best way to add shelf above panelling
markc replied to AdamF's topic in General Self Build & DIY Discussion
Depends on width and thickness of shelf but dowels drilled into the walls and corresponding holes in the shelf so the shelf slides onto the dowels. works well, but needs accuracy in drilling. dowels are either steel round bar or threaded rod or small diameter alu tubing with long screw into wall plugs -
500x500 is a substantial footing, but the footing design depends on how the structure is fixed (or not) to the existing as you don’t want differential movement in the event of ground shrinkage or heave.
