Everything posted by markc
No idea what the blocks are, but i am curious why there is what looks like skirting on the ceiling
M12 through 3x2`s is massive overkill, plus 1200mm centers is too far to be of any real benefit. Clamp the timbers together and then screw or Annular ring nails in a zig-zag pattern at around 150-200mm spacing. (this is how trusses and joists are doubled or trebled)
where is the small area that squeaks? mid span? near a wall? service void? etc. i reckon it could well be a joist hanger/connection noise depending on location
Wall Hung Toilet With Extra Hole At Front Leaking
markc replied to minskin's topic in General Plumbing
some of the pans do slope towards the front, i always assumed it was to ensure any splashes disnt rest in the joint line. i wouldn't bung the hole up as it could cause the whole pan to fill with water and stay there ... although it would be clean water so no real detriment. -
fresh air .... and the condensation disappeared
Nope, if you can score 3 sides, sharp bolster hits (not hard enough to break it) to the 3 sides and then crack it and it will break pretty cleanly
thats how i would do it
If you are going straight through, then the length of cable covered by the insulation is short and will not cause overheating, so yes its ok to seal around the hole.
Good idea, technically the joists could just sit on the shelf, no fixings and be stabilised with noggins both ends.
How are you looking at fixing them? Really should have vertical plates welded to the box sections to fix to
Manifold system versus hot return system
markc replied to Russell griffiths's topic in General Plumbing
Thats a pretty good description -
It will, but unless the lamp fittings are really tall no one will ever notice the small tapering gap, i thought some i did would annoy the hell out of me but ive never notioced them.
Screw type for ridge abutment metal straps.
markc replied to epsilonGreedy's topic in Roofing, Tiling & Slating
Yes, 6mm studding into 8mm hole is about as small as you can go or the resin nozzle wont go into the hole far enough to pump it in and let the air out -
Just put a packer under the top edge, dont `seal` the back as water will get in but then cant get out
As big Jimbo said, clean dust free hole is the secret, also (If possible) use a drill in reverse to push the fixings in - the thread then tries to force the resin back into the hole and ensures it is forced into the masonry or concrete pores/cavities and fixing threads, something we learned while installing thousands of them on big construction projects. -
16mm SWA is more than sufficient for this purpose. Close the duct off with some insulation or squirty foam. Also drill your hole though the wall slightly downhill towards the outside to prevent water creeping along the cable and into the house.
Structural Truss Noggins at Ceiling Level
markc replied to MortarThePoint's topic in General Construction Issues
@MortarThePoint, Again, most floor stiffeners/noggins are there to prevent the joists/beams from rolling over when loaded. If you look at a pozi type joist (its easier to explain than a solid member) then floor bounce occurs when the top cord compresses and/or the bottom cord stretches allowing the joist to deflect downwards. Solid noggins or Diagonal (top/bottom/top/bottom etc) mid or part span braces have very little effect on deflection. If you want to reduce floor bounce you have to increase beam depth or increase section on the top and bottom cords -
A noggin is classed as a compression member from a design point of view, its purpose is to prevent the trusses or cords from deflection towards each other. Therefore the fixings are merely to hold it in place. -
No-concrete foundations for a timber framed building
markc replied to Carol L's topic in Foundations
This is great for load bearing but no use if the foundation is also a ground anchor against wind load (rolling over) etc. Screwed piles work in compression and tension so fantastic for lighter buildings in windy areas. -
Door bell is so low powered (almost zero current) that cable size is almost irrelevant. For multiples its will be easier to run a 2-core to each call point back to a central controller/chime unit. If you are going for long runs then a 12v circuit would be better than the very low voltage units
Timber supply issues due to brexit
markc replied to Pocster's topic in General Self Build & DIY Discussion
There is no basis to put prices up due to Brexit, Covid and the increased cost of keeping businesses operating yes. Bit of paperwork and £167.00 for us to customs clear a fully loaded Artic, offset by reduced transport costs as there are now less delays and the ferries are competing for business due to there being no holiday makers. -
Good morning, not the best picture, it looks like a reinforced roofing felt, can you say what the material is? or what its like? rubber?, hard? etc.
Seems that many people/businesses are saying costs will increase but i cant see why, my company imports everything from Europe and we are predicting price reductions to customers as machines are costing less to us now
