tonyshouse
Everything posted by tonyshouse
I don’t like the sole plate or the thermal bridging it brings. I have had this before and suggested that condensation may happen on top of the dpc, not good . I would analyse the thermals and do something to mitigate before building
Insulation needs to be hundreds of millimetres thick to be compliant with regs, useful for future proofing and to make ant sense sustainability wise.
Go for the goodwill route if at all possible
Is this floor buildup common/ok? Concerns
tonyshouse replied to R1plusR2's topic in Building Regulations
I always built insulated floors with the membrane on top of the insulation, warm side, acts as a combined dpm/vb then - never had a problem except with occasional building inspector -
Way OTT, hopefully a printing/nomenclature error - can’t see what the toe is doing either. how will you insulate it?
- 37 replies
- basement
- concrete slab
(and 3 more)
Top 3 MVHR brands?
tonyshouse replied to ashthekid's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Compact will generally equate to less efficient and quiet to mor expensive -
Trouble is that the world isn’t perfect, base, sub base and underlying ground can be not fully compacted, heavy vehicles can apply uneven loads, corners snap off, in the real world there are lots of cracked concrete and printed concrete driveways, patios and paths. Always looks good when new, but not after a dig, trench or repair
Installing bathroom ventilators to cool down an appartment
tonyshouse replied to StevenLe's topic in Ventilation
Insulate and shade windows externally -
Top 3 MVHR brands?
Genvex for me -
Almost impossible to repair and prone to unexpected cracks
Answer is no! Just walk around your area and look at what they look like after a few years, ripples, weeds, moss, determination
Copper strip required for Cambrian slate?
tonyshouse replied to Eric's topic in Roofing, Tiling & Slating
Moss is a problem on all roofs, not sure if copper strip will do it evenly as water doesn’t run very evenly -
Air compressor works well and you can hear the leaks ?
How best to solve guttering issue
tonyshouse replied to BobHenry's topic in Roofing, Tiling & Slating
Right down to the gulley, through a lead slate in the roof with weather collar. 2 - I would tip it Bach onto the roof two 90 gutter angles, -
Aerated blocks crack and can shift around , they always crack, and sadly let air leaks in. Avoid using them in your own house.
I used basalt fibre wall ties on my house, mainly due to the wide cavities
Typical web search - https://www.extractorfanworld.co.uk/silavent-svc100b-axial-extractor-fan-with-auto-shutters-2515-p.asp
Positive shutter operated by a solenoid set to open when fan comes on
Danger, if the void I’d unsealed and open to outside air then the insulation will be subject to thermal bypass and the house cooler than intended.
Tin snips for lead flashing, trad and fancy?
tonyshouse replied to epsilonGreedy's topic in Tools & Equipment
Soakers easy with a Stanley knife (score deep and tear gently) or bench mounted workshop lever sheers -
Anyone had success soundproofing the party wall on a semi detached?
tonyshouse replied to Josh95's topic in Sound Insulation
Check this out - https://readinguk.org/draughtbusters/going-further/first-floor-void/ any tiny air path between you and a next door will let in a disproportionate amount of sound/noise my advice is to strip off the plasterboard linings to the party wall, Re plaster with sand and cement including in the floor void, sealing flexibly round all joists. I would also fill the party wall void with rockwool fibres. alternative is to fill the gap between the sheets and blocks with foam and seal the joists - difficult to do foam as it needs to be very liquid and non expanding -
Is the party wall dot and dabbed? Do floor joists or trimmer run into it? -
He will loose
Exposed vs concealed shower valves/pipework
tonyshouse replied to Adsibob's topic in Bathrooms, Ensuites & Wetrooms
When it goes wrong you want exposed, ideally with all gubbins freely accessible including brain and joints, pump etc
