JohnMo
    196
Everything posted by JohnMo
  1. https://www.partel.co.uk/product/21/5/alma-vert-115-kgm Slightly different product but in sheets
  2. Last month and this month so far, my gas bill has consisted of 1/3 actual gas usage and 2/3 for the standing charge. It wasn't that long ago that Ofgem or similar, said all energy companies had to apply a standing charges. I used to use Ebico, purely because they didn't apply a standing charge.
  3. Building Regs applicable to the area of the UK you live, should all the info you need.
  4. They already tax you for buying a second home in Scotland, at time of purchase. I thought they only wanted to stop new homes being build, if they could be purchased by anyone, but them, at a reduced price?
  5. If you really want to kill everything that may be in chlorinated water, then 60 degC is enough, you don't need it at 70 degC. Bet the thermostat is set at 70 degC or very close to it. That is why the boiler is never switching off
  6. But doesn't the thermostat need connecting in to the boiler control circuit, to do anything. The middle grey box, which I assume is the thermostat for the cylinder is not connected to anything as there are no wires coming out of it.
  7. If you just want to heat the towel rails from you central heating, you will end up with the boiler short cycling if they are the only thing asking for heat. Have you thought about making them dual fuel, by adding electric elements? Then you can add a simple time switch to heat the rail when you out wet towels on it.
  8. Does your cylinder have a thermostat? You need the thermostat to call for heat and shut off heat based on your time schedule. So the wiring goes from the thermostat via the time switch or your smart hub to the boiler. So your smart hub isn't really that smart!
  9. You beat me to it
  10. So your usage is down to 3.2kWh per day, from 18kWh per day. That sounds like a win. £1600 saved in water heating costs!
  11. You can if you have cylinder upstream of the combi. Just set up to do some experimenting, as we have quite a few days of overcast skies coming up/ Already have a buffer (thermal store) on the heating system, which has a DHW coil in it, this is used to preheat water going in to a combi in the heating season and heated by PV immersion in the summer. Downstream of the DHW coil is solar diverter valve (to a mixer valve or to combi). On a good solar we have free hot water. Have a good idea of gas used for DHW, when there is little or no solar. Have just set the heating system to charge the buffer at 47 degrees, 4 degrees hotter than the diverter is set at. Will see how gas consumption goes, over the next week or so. Have already noticed the draw of volume at the kitchen sink, is much lower with the heated buffer, than with the combi.
  12. they are all the same - difficult if you leave it to dry out, easy if you don't
  13. wood fibre, cellulose, natural wool, recycled plastic wool - but they also contain something nasty when you start looking, to either stop them rotting or insects/rodents out
  14. It had nearly a year exposed and untreated, was just starting to to have a tinge of grey. Now treated with ceder oil, as in the photo.
  15. I have Scottish larch, dismissed Russwood on a price. Got mine from Ali Patterson of Nairn, all trees from local wood, will mill to any shape or size and about a 1/3 the cost. Good delivery.
  16. Typical turn down is around 2:1 on an inverter heat pump, some are a little better. So if you look at the heating characteristics of the house at say -5 and 10/12 degrees, will your chosen heat pump do max demand and min turndown (kW) without being too big for the heat demand at 10/12 degrees, so that you don't need a buffer?
  17. Plasterboard tape and jointing compound, sand smooth?
  18. Sounds like the rip you off world of heat pumps. All heat pumps should come as standard with heating and cooling functions operative.
  19. Looks like your internal heat exchanger coil is 1.5m2 area, I think it more normal to a see a 3m2 coil when connected to a heat pump. So your issue is related to the DHW cylinder and it's internal coil being too small most likely. Did you install yourself or was it specified and bought by the plumber? Also looks like there is an anode to replace to prevent internal corrosion, these normally need to be replaced annually.
  20. Ask the structural engineering or architect why, way easier than loads of second guessing. There may be a simple explanation, or they have just and pasted from another job and not removed some details.
  21. No, the return will be lower than 55. If it's reaching 55, then the coil within the cylinder is not suitable for a heat pump. Assume you changed the cylinder when you upgraded to a heat pump. If you didn't or just installed a normal cylinder that is your issue. The coil within the cylinder is too small to transfer the heat from the lower temperature heat pump, compared to a gas boiler which with would be flowing at around 70 degC. The cylinder name plate will have all the info. You take a photo and post on here?
  22. I would check the min flow rates, as you don't want too many air changes in winter, as the air can get too dry.
  23. If you can get 4 ach from MVHR your unit must be massively oversized. Normal flow is 0.3 to 0.5 ACH and boost 25% or so above that.
  24. Can you see what the return temperature is when you flowing at 55 degC? Also what make/model cylinder are you trying to heat? Is specifically for a heat pump?
  25. I challenged our SE on several issues, well worth it. Sometimes a different slightly more expensive grade of steel, gets you a smaller size and fixes the issue. Could you add an internal or external mid span vertical support. This reduces the work the lintel has to do, so size drops considerably. Or batten the internal wall and add internal insulation to cover the cold bridge and the rest of that wall. Many ways to get things to work. We have a wall of glass and the steel holding the roof up was massive and somewhat killed our views. A few challenges ended up with a more expensive steel frame in 90mm square section. We now have very small sight lines around our windows.
