Everything posted by JohnMo
The hole you make is airtight it allows a feed of air from the outside to fire and make the fire easier to start and your flue will work effectively. Instead of using outside air for combustion, you will using your internal heated air. You will depressurise the house and when you open the door to restock the wood, the smoke will come into the room; as its at a lower pressure. Cut and paste from another forum The biggest concern with woodstoves in airtight homes is if they don’t have a direct air feed from the outdoors to the back of the woodstove. A lot of people omit that one crucial feature, and in doing so you will depressurize your home every time you start a fire. It will also be hard to light, and in combination with a bathroom fan or stove hood operating, it may fill your home with smoke. At the best of times, you will be feeding the fire with heated indoor air which will then activate every tiny leak in your building envelope drawing in cold air.
Wrap a soakaway in an impermeable material, you no longer have a soakaway, you have a bucket with stones in it.
Would MOT type 1 just block everything up as it has lots of fines in the mix. Gravel or pea would be my thoughts
Who knows from the image, is there sellers pack or is that just a Scottish thing? It could be EPDM, PVC, fibreglass, rubbers or felt.
High efficiency fridge-freezers
JohnMo replied to puntloos's topic in Kitchen & Household Appliances
The A to whatever ratings all got changed about a year ago, think to old A is something like an F. All fridges were A+ or A+++++ so was very much meaningless. -
Information needed for a quote from the online estimators
JohnMo replied to Indy's topic in Costing & Estimating
Wow big costs for turnkey. -
Or cover the panels with black plastic or card, then there should be no volts. Connect without any risks. Assuming you've done everything Dave mentioned above first.
If your only doing 20 to 30mm PIR or similar. You could do aerogel but not sure the cost v reward would be worth it.
I would look to get a U value on the ground floor of around 0.1. To work out the u value you need the perimeter to area ratio. Screed thickness will determine how your UFH reacts to changing heat inputs. Thin (50mm) is quite quick (hour or two), thick quite slow, but you can buffer the input into the floor and it slowly releases the heat over the rest of the day. I would only use the grooved boards with direct tiling in bathrooms, if I used at all.
De centralised unit for retrofit?
JohnMo replied to hotnuts21's topic in Mechanical Ventilation with Heat Recovery (MVHR)
New build -
You will get a small temperature drop across the plasterboard, but not much. So the polythene will be at room temperature all the time, except in the case of poor insulation, a high degree of wind wash and thermal bridges, then it could be closer to outside temp. But shouldn't happen in a well designed house. With a decent ventilation system your internal humidity should be above 60% RH (dMEV or MVHR). In winter with building standards ventilation flow rates (with heat recovery) you may struggle to get much above 30 to 40% RH in really cold weather. As said do an interstitial condensation calculation, you can mess with lots of different materials, different temperature and different ventilation rates to see the effect. What I found interesting when you start to control max humidity at no more than 65%, it doesn't really matter what the internal temperature is you don't get condensation. If you don't control humidity, you start getting condensation at 18 deg, which could be the temperature of your bedroom. I used on from really useful software, which is free to use in demo mode.
ASHP, Just an outdoor fridge ?
JohnMo replied to Post and beam's topic in Air Source Heat Pumps (ASHP)
There a rip off because the government will chuck £5k towards installers. The installers hike up the price and say 'but we are now giving you £5k off because of the grant. Technically not any different from an A2A heat pump, slightly different heat exchanger and no fan coil unit inside the house. So actually simpler, but generally cost more. You can get them at a reasonable price, you need to shop around and DIY install as mentioned above, rather than going for a grant. You really don't want to over size them. -
My garage is very silver inside. Ceiling 25mm PIR boards screwed with spreader washers to ceiling rafters, then joints taped. Above that is 100mm of mineral wool. Walls, 100mm accoustic mineral wool in vertical wall timber, then covered in a foil membrane. Insulated roller doors, insulated side door. Garage not heated, but may use an electric heater at odd times.
I'm in Scotland so had to meet 0.5ach. -
My average over the 4 months is 2kW, so 68m3! Big Can't imagine the temperature staying at 90 degC for long. So in reality to take account of losses maybe 50% as big again.
Not much of a fan for the ventilation you are producing, you will end with the worst of all worlds. 2x power required, for extract and supply, but no heat recovery to offset the ventilation losses and electric use. I would ditch the PIV. Then three options, vent fans with heat recovery, such as these (link below) you will need one at least in each room, wet and dry rooms - dMVHR. https://www.ventilationland.co.uk/product/40954/decentralised-mvhr-unit-o100-mm-with-switch.html?utm_source=googleshoppingUK&utm_campaign=googleshopping-FeedUK&gclid=Cj0KCQjwzqSWBhDPARIsAK38LY9sv8y5tPeyEPH6lJdO42VQvR7AagTCv5jhXEym6Mpwy0W1M5whOLAaAv7EEALw_wcB Full MVHR. dMEV, but condition based ventilation, so passively controlled vents inwards that response to humidity and the same for fan extract side . This way ventilation will be limited to what is needed. This will limit ventilation losses, and only require power to vent fans in wet rooms. You need to get good cross flow for this to be effective.
Don't get involved let the contractor do it. If he hits anything it's on his shoulders not yours. Mine hit a main 10" water line , the cost to repair was down to him and his insurance. If you start saying do this, do that, you are in charge - it then your fault and your shoulders, your money.
In theory, but in practice the holes you make in it, means it's not airtight, plus you would need to seal skirting level. Instead of guessing do if I need this or need that, get an interstitial condensation assessment. Either download a free trial copy or get your house designer to do it. Are you going for an airtight build? Have you looked at ventilation?
Insulation/board support for pug/biscuit mix in suspended floor
JohnMo replied to Crowbar hero's topic in Underfloor Heating
All insulation has acoustic properties. The more dense it is, the better normally. PIR is rubbish. We used rockwool flexi in our internal walls, seems to do the job quite well, equally suited to ceilings. Ideally you need an air gap either side of the insulation, that helps with the acoustics. -
That sound like a good plan, hope there many hundreds
Recent topics on sand thermal storage and a mention of inter seasonal store on another topic has got me thinking. I live on an old sand dune (sea now 6 miles away). So have more sand than you shake a stick at. So my thoughts are 1. Dig big hole. 2. Line with 200mm PIR, or 300mm polystyrene. 3. Insert big tube coil, use same coil for charging in summer and extract heat in winter. Add suitable valves. 4. Back fill hole with sand, cap with more insulation. 5. With a spare solar thermal panel charge over summer. 6. Pump through same coil in winter to extract heat. Use heat stored to provide some heating load to UFH. UFH only needs a mean flow temp of 26/27 degrees for coldest day. Is it practical or would need to huge and not cost effective? Any thoughts
Nice design, but not sure how practical for a passivhaus. Has a passivhaus designer drawn up the design? I think overall you may struggle to get passivhaus heating requirements, your perimeter to floor space ratio is the wrong end of the scale, three long oblongs, with lots of room in roof; when the ideal shape is a single cube. Your U values will all need to be sub 0.1 to get anywhere close. You have lots of wall/roof to get airtight also. The glazing will kill the thermal properties in the cold and overheat you in the spring, summer and autumn.
That's some pretty thin insulation especially at the blue line. Plasterboard skimmed will give you reasonable airtightness, but only if no sockets or lights, these will leak like a seize. It is not moisture tight, so water vapour will pass straight through. If it was my house 1. VCL the whole roof fully tape all joints. If the walls are timber, same applies. 2. Install service Battons (counter directions to roof joists), 45 x 50mm, once services are installed insulate with 50mm mineral wool. This will help reduce the repeat thermal bridges, caused by the rafters. 3. Normal plasterboard in dry areas, wet areas with moisture resistant. 4. The wall that is blue, double the insulation thickness. Consider more insulation everywhere, you only insulate once, heating costs all the time.
