JohnMo
    196
Everything posted by JohnMo
  1. I'm on gas combi boiler, and last heating season was not very good, as I had a lot of short cycling of the boiler, three designs later I have where I need it. Basically a re-plumb of buffer and adding a big plate heat exchanger on the boiler side in addition to the buffer heating coil. First two months of heating boiler was in continuous short cycle trying run at very low temperatures with a buffer heating coil that was way to small for those temperatures. Used lots of gas while I got my head around the issue. These are issues no one tells you about building low energy homes. Learned loads in the process though. End of the heating season I was batch charging the UFH for around 6 hours at a time, using 20 to 30kWh a day. I was heating for half of April and the gas usage was 500kWh for heating and DHW. The last three months with 3.1kW of PV, my DHW has mostly been taken care of by PV. Bills on the region £15 to £20. Last month I used 60kWh of gas, 20 of those in two days, no solar production and doing a trial on the water heating system.
  2. We have 3.1 kW PV, offsets electric costs, diverter, supplies most of the DHW in the summer
  3. As it stands your heat loss is just slightly over ours, with slightly bigger floor area. 5kW ASHP or small system boiler would too large on anything else but the coldest day for central heating - UFH throughout, balance the system so when your living space is 19/20, your bedrooms are 18 degrees. Bathrooms at 20-21. Run as a single zone on weather compensation with a 2 degree setback at night. Your biggest demand will be keeping up with hot water, if your bedrooms are being utilised, which would drive a large cylinder and bigger boiler/HP, and a buffer on the central heating.
  4. The man delivering gravel this week also does concrete, he was saying lots of self builds are being put on hold, doing enough to initiate the project for building control and then stopping, they have lots of recent cancellations.
  5. I was told by materials engineer that it is best seal tubes. Any atmosphere (oxygen) inside the tube is used up and cause a small amount corrosion, once that process has happened the atmosphere is inert, so no further corrosion occurs. An open vent tube gets replenished with new oxygen so corrosion can continue.
  6. Your wall insulation is pretty pants, can you do anything improve? But as it is, your UFH will have no issues heating the place. So to get a heat pump or boiler to work, do a heat loss calculation. Good one here Then you'll know what your working with. Do the calculation and post your results. From that you flow temp and flow rate can be calculated.
  7. Your architect should have to deal with sort of thing on a daily basis. Ours had a go to man, your should have the same.
  8. Let's start with basics. Have you done a detailed heat loss calculations? What are your U values for floor, walls, roof and windows? We have a 6m high lounge and all other rooms go up to about 3.5m, we don't struggle to heat the house, with UFH. A heat pump heating system is fine as long as you design for low temperature heating.
  9. By EWI do really mean external roof insulation? Or something else. Are you building a hybrid roof? If so have you done an interstitial condensation calculation? If you panel over the whole lot, then add additional wood below. All would be secure, knowing everything is held in place correctly and you will end up with the same effect. I think if your not careful something could land on your head in 10 years time.
  10. Good observations. There will more issues now electric vehicles are becoming main stream. Most repairers not being suitably qualified to touch the high voltage side of things. The mainstream workshop not having a scrubbie where to start. The same is mostly true with heat pumps and more generally for any low temperature heating system, especially when also coupled with a low heating demand house. Everything they have been told for years, is now not really suitable or not going to work efficiently.
  11. The design for gas boiler is usually for a high temperature system. You can design it for a low temperature system (as ours is), but this totally confuses the normal plumper. But a low temp system is the same design broadly, the delta T can be the same for both a gas boiler or heat pump. Our boiler at 25 to 30 degree flow temps does so with a 4 degree delta T. Our heat load is low so the pipe sizes can be normal sizes. Most gas boilers in a low energy house will need a buffer to operate without short cycling, not just heat pumps. The trouble is to rejig the existing fleet of gas or oil boilers to run low temperatures; to get condensing mode all the time, a lot of homes would have plumbing of too small a diameter to get the mass flow through the system, at the required temperature. Plus they would need new radiators, new controller and a good possibility those with system boilers couldn't do low temperature for heating and high temps for DHW heating. So isn't a easy fix. Hybrid systems do work, but reducing heat demand is the real fix all.
  12. Was looking to go fast track G99 route, with zero export inverter.
  13. I only have 3.1 kW installed, but have a garage begging for some to be installed on it. Prices are too high at the moment due to a high demand and demand v supply issue.
  14. Couple of issues I see first off. The 3 zones, will play havoc with either a gas boiler or heat pump. As your heat demand on any one zone will be really low, a big buffer will be required for either system. Our heat demand is similar to yours (slightly higher), the min turndown on our boiler is 6kW, with a max demand of around 3kW (no sun, -5 degC). We installed a 180l buffer. We went with gas, as at the time I couldn't make the numbers work for an ASHP, with gas on the doorstep. Still can't really. We have a combi boiler, that can accept pre heated water. In the summer excess PV is diverted to the immersion in buffer, to heat it up, a DHW coil in the buffer heats water up on its way to the combi. A solar diverter valve is used, if above 45 degrees, water goes direct to the tap, if below 45 the water goes to the combi for further heating. Works well, our gas bill for the last couple of months has been mostly the standing charge. Couple of different ways you can run your heating, dump heat into the floor for about 6 hours, the heat will then trickle out over the next 18 hours, then repeat. Or very low flow temp constantly. The call on gas or electric is your to make, any system can work well, as long as thought goes into the design of a low temperature heating system. Then the system is pretty much future proof for any boiler design.
  15. So you could use something like. These are 25mm deep. 16+12.5, gives 27.7 height, if you are using 15mm plasterboard then 31mm height. https://www.toolstation.com/enlite-slim-fit-round-low-profile-led-downlight/p56573?store=LJ&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&mkwid=_dm&pcrid=&pkw=&pmt=&gclid=Cj0KCQjw_7KXBhCoARIsAPdPTfh3zjexFfspXlESIQ7o08bNkmHonb00JmuXlD4QTK_uFsPn5L0xW5caAsd4EALw_wcB&gclsrc=aw.ds
  16. You get down-lights that are about 15mm tall. A service batten 50mm tall will be enough space for the little control box.
  17. my floor build-up is slightly different from yours - concrete, insulation, concrete, rather than insulation then concrete. But I ran all the cold water to the different rooms, from a manifold below the insulation. Water is always cool, great for drinking. Building regs say the pipes have to be removable so I used pert-al-pert in conduit. So far no issues.
  18. Not sure about that, MCS best practice guide consists of about 25 pages of technical bits and 40 odd pages of contractual stuff.
  19. It's worth a look https://www.heatgeek.com/find-a-heat-geek/
  20. I think if you wet it first with water, things stick much better. Recently stuck stone slip to aerated blocks, it only worked if I wet the blocks. Think they suck the moisture from the cement be too quickly, so it doesn't dry correctly, so the same would be true of plaster.
  21. Think the problems may stem from a lot of monkey see monkey do, the trainer is giving a set syllabus and may not be that well versed in thermodynamics, have little or no understanding of when zoning is or isn't appropriate or the reason why. Or for that matter how to get a good CoP from a HP. Trouble is you can get away with a mediocre gas boiler installation and no one knows any different as gas is cheap. A mediocre HP install can have a bad CoP, electricity is expensive, so end with a big bill each month.
  22. You need reduce your pressure drops to/ from the outside world, so the size will depend on the length, number of bends and flow rate. As you say for now 200mm would be ok. I inserted plastic tube through the ICF, leaving an overhang either side of the wall and foamed into place and when I did the concrete pour the concrete just formed around it.
  23. I think the quality of general training on heat pumps for plumbers is almost non existent. Heat geek, do specialist training and have a database of people that have passed their training (as opposed to just attended). So may be worth a look. The basis of any good heating system starts with a heat loss calculation. You say you have paid for a design and supply, so assume you have the heat pump? Is this for a new or existing property?
  24. Forgot to add a note about my system, your combi has to be able to accept pre heated water at around 43degs. Most modulating boilers will, but some don't. So you need to check, not always that easy to find the info.
  25. But if the comment is applied to post above mine, where the inlet of the MVHR is to blocked, so it becomes a recirculation system, it is no longer MVHR and due to the flow rates a rubbish Aircon unit. So not fit for purpose. In a residential setting I have never seen Aircon that replenishes the air, just moved it through a heat exchanger with a fan unit.
