I considered thin joint mortar when I was looking at different construction methods for my build. This looks like a modern version. This paper might give some more details. https://images.ffx.co.uk/documents/R_RPP-MORTAR ITB Approval 15_9752_2016_GB.PDF
I would probably use Soudal Fix All Crystal Clear. https://www.platinumchemicals.co.uk/products/soudal-fix-all-crystal-clear
I made one out of heavy duty bubble wrap for the front door when we had the Icynene installed as they were dragging heavy flexible pipes inside.
The pipe ends should be chamfered so they don't push the seal out of it's housing and a small amount of silicone grease applied to the seal. The pipe should be fully inserted into the fitting. Using washing up liquid will damage the seals but is a lot cheaper than silicone grease hence why builders use it.
Welcome to the forum and good luck with the project. We built a timber I-beam portal framed house. It was the second of the type built in Kent, the first being an art studio. https://conker.cc/projects/passivhaus-artists-studio-canterbury/
- 8 replies
- portal frame
- pir
(and 2 more)
Would we need any other heating source?
Gone West replied to ZacP's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Three small electric towel rails and an EASHP that warms the supply air from the MVHR. -
Excellent, like the style.
Hard to clean pitfalls? Cleaning dreams?
Gone West replied to puntloos's topic in New House & Self Build Design
Phew, at least I haven't missed out on that one then . -
Never owned one so never tried, but are rimless toilets easier to keep clean? -
I didn't put anything up unless I had deep holes in the front and then I hung rope around it with a laminated piece of A4 as the sign.
A Prickly, Edible Hedge - Blackthorn
Gone West commented on Ferdinand's blog entry in The BuildHub Gardening Blog
I couldn't remember what the spacing is so just went out and measured it at 300mm and they're in a straight line. You can just about see the plants behind the wire mesh. I prefer hedges to fences and I just put a rabbit proof fence in front of the hawthorns and blackthorns. In the past I have found holly to be very slow growing and we grow Trachelospermum jasminoides (Star Jasmine) up our posts and trellis. It is covered in flowers in the summer and smells gorgeous. -
In that case I wouldn't change anything and if there are no problems leave well alone.
Permitted Development Question - rear/side extension
Gone West replied to tp1's topic in House Extensions & Conservatories
Around here it would be time, cost and aggravation. -
Hi, welcome to the forum. Yes I have a Genvex combined unit, but they only work in a very well insulated house. Why not leave your MVHR as it is and add an air to air heat pump to the house if that is the route you want to take. What is your existing heating?
Around here the leaves can stay on until the end of the year, almost as long as the alders. Just depends on the weather. -
Yes there are sloes on there every year but not in huge quantities. There are enough for the blackbirds though. For a large crop it needs to grow 2m to 3m tall and untrimmed. -
We have a mixed blackthorn and hawthorn hedge at the front of the property which I keep at around 1m high. All went in as two year old bare rooted whips and was completely filled in after four years and is around 0.8m thick. The sparrows love it, and when the sparrowhawk visits and sits on the top of the hedge the sparrows make so much noise that we go outside and scare the predator away. -
Washing Machine / Dishwasher Cleaner
Gone West replied to Onoff's topic in Kitchen & Household Appliances
Don't like to disappoint . -
Could always fit a water softener if you had one lying around . -
Thanks, yes your figure looks more accurate. That is a table I've had for some time and I'd never noticed, I'll have to correct it.
Self Demolishing A House
Gone West replied to Internet Know How's topic in New House & Self Build Design
I asked Building Control what they wanted and they said a notice to demolish form completed. So I sent that in and then proceeded to take the bungalow apart. -
The Openreach engineer that removed my line just cut it with a pair of side cutters and coiled it up on the side of the pole. With our system we use VoIP for our landline telephone.
We had Openreach disconnect and remove their cable from our house. It was FREE. They said it was their only free service. We never had it replaced and use WiiMax which is both a lot faster and cheaper in this area.
