Yes we are happy, had a lot of good comments. The smaller sink is 160mm internal width and is called a half sink or N50 and the larger sink is called a three quarter sink or N75. We didn't want a full size sink as we don't do washing up etc. Schock produce a very large range of different styles and sizes.
I wouldn't say so. I set up ours starting with the level 2, which is 'at home', and getting it all balanced for that and then there is boost, level 4, which is 100%. Level three is set halfway between 2 and 4 and level 1, which is unoccupied, is set halfway between zero and level 2. Our system has run automatically, without a humidistat, for 2.5 years 24/7 on level 2. Our system has a built in EASHP which warms the air if required and, if running, that increases the speed to level 4 for around 15 seconds and then modulates down and varies the speed to what is required to provide the desired volume of air to maintain house temperature.
A farmer around here had a barn that hadn't been used for agricultural purposes on the dates required for Part Q. So he took the modern door off put a straw bale in the entrance took a picture and said it had been used for storing fertilizer. It's now been converted to offices.
What cost per m2 can we REALISTICALLY achieve?
Gone West replied to Mulberry View's topic in Costing & Estimating
What do you want to include in the costs? Do you have all the tools you are likely to need. Could easily spend several thousand if you need a lot to do it yourself. Are you going to use an architect for planning or building control. Are you going to include the cost of say a 100m2 terrace paved with Welsh slate. There are so many variables I don't think it is a good way of budgeting. On Buildhub you are comparing people who do it for a living with people who have never done it before with people on their fifth self build. Unfortunately you are not comparing apples with apples using cost/m2. -
That's something I just do not understand. Our system supply runs at 30% all the time and is not audible even with my ear next to the vent. The extract runs at 45% all the time and is audible but only in those rooms with an extract vent. I fitted an attenuator to the supply side but didn't to the extract side as I didn't think it was worth it, but with hindsight I might have fitted one. I wouldn't dream of reducing the ventilation at night.
I think you'll find it's very dependent on where you live as to how Part Q rules are interpreted. Down here it's pretty relaxed. There was a small timber framed barn in the orchard next to us which was dismantled and completely rebuilt with new timber and roofed with slate when the original was tin. Roughly the same size but looks completely different. On a farm a mile away from here they are at present dismantling a timber barn and there doesn't appear to much of the original left. As I said it's down to the local planners as to what you can get away with, not necessarily national guidance.
Hi Kastro, welcome to the forum. As you have probably already found there is plenty on here about UFH.
No you don't need a cavity as @PeterW says. Unless, in your case, a cavity wall has been specified for structural reasons because the original wall is not sound then EWI is a common way to improve single skin walls.
@LSB has already said they have permission to build the cavity wall outside the existing wall.
As the walls are single skin blockwork couldn't you fit external wall insulation and then use whatever rainscreen you want such as timber cladding, brick/stone slips or render. I would have thought that would be cheaper than building a cavity using blocks.
I like the look of it, not so sure about the price, but you're loaded so go for it.
Have you seen this thread?
Give your head a wobble
Gone West commented on canalsiderenovation's blog entry in Canalside Bungalow Renovation
What a lovely position. It looks like it's all coming along nicely. Well done. -
Yes we were in that boat, took us eight years. It's great when it's finished.
I used BuildDeskU which I managed to download on two occasions each for 30 days free. It had a similar looking output but I used it in 2009. http://www.builddesk.co.uk/software/builddesk-u/download-builddesk-u/
Install of Harvey twin water softener - initial set up problem?
Gone West replied to oranjeboom's topic in General Plumbing
1) Can't help I'm afraid. 2) It should not be dripping, but can't offer any advice why it is. 3) The blocks should be sitting in around 10mm of water all the time until regeneration otherwise there wouldn't be any brine. I would guess so, mine loses less than 10mm between regenerations and regenerates every day or two. -
When to replace 90 year old wooden floor joists?
Gone West replied to Adsibob's topic in House Extensions & Conservatories
The timber used 90 years ago would be a lot better quality than what would replace them. -
External oak, to treat or not to treat, that is the question?
Gone West replied to joe90's topic in Decorating
We haven't treated our cedar cladding on the house and the north facing wall has gone a nice even silver grey. The other walls are more patchy as it is the rain that washes the colour out rather than UV bleaching it. A friend clad his barn in oak and left it untreated and that went grey. It takes time for it all to even out. -
Hi and welcome to the forum.We did the same as you as a retirement project, good luck. We had an initial MVHR system design done by ADM Systems.
Our window supplier/installer was registered with Checkatrade, although we didn't know it when we placed the order. Initially we had some issues with the installation and they came back and fixed them. When we had some more problems they refused to come out again as it was too far for them. After lots of phone calls and emails they stopped answering any more, so I tried Trading Standards who weren't interested. I then put a bad review on Checkatrade and Checkatrade contacted me and I told them the problem. They contacted the company for me and effectively told the company to fix things to my satisfaction which they did straightaway. So I am pleased with Checkatrade, although this was several years ago.
Is that on top of the sand or underneath?
Have you looked at these. https://www.diywardrobes.co.uk/#cabinetdesigner
