Unfortunately it has rained a couple of times recently and I've removed most of the roof, only the rafters to go. The floorboards have got wet and swollen so unless we have a dry spell they might not come up too easily.
@jack I have the softener drain pipe and overflow pipe both running into the same waste pipe. The drain pipe might cause some resistance if it remains at 10mm for a long distance but if it opens out to say 15mm I can't see any problem.
The Roughneck looks ok, I wonder how it would cope with thicker boards and cut nails. I guess there's only one way to find out.
@Onoff the Screwfix version looks a bit puny compared to yours. Isn't there more danger of the boards splitting if the lifting plates aren't articulated?
I demolished your house, but I'm not moving the debris!
Gone West replied to laurenco's topic in Demolition
Even the recommended ones sometimes come with cautionary tales. I asked @MikeSharp01 if he could recommend an asbestos removal company which he kindly did and he added that there were things they didn't do. When I asked them to quote I listed the things Mike said as well as every possible aspect of the removal I could think of and got it in writing. Fortunately it went smoothly.- 192 replies
- demolition
- cowboys
(and 2 more)
My slab had voids in the concrete as a result of the concrete 'going off' too quickly resulting in areas of weakness. Different solutions were proposed none of which I considered worth the risk so it was agreed that the slab would be replaced completely.
That is correct. I had never heard of MBC in 2009 when I was researching for my build. My frame was supplied by a local company and is a completely different type of design and construction to that of MBC.
Yeah they're cut nails. Thanks for the offer, I'll have to have a measure up when I've finished taking the roof off. It's a dismantling not a demolition of the bungalow so it's taking a while, but then so did the build.
I hadn't thought of that idea but that looks good for when I want to remove the floorboards in the old bungalow. I want to reuse them, along with the 4"x2" frame timber, to build a shed.
Well I wouldn't want one even if they had been proven to work. I want soft water with all it's advantages, not hard water that doesn't 'fur' up the pipes and kettle. Maybe I'm in a minority or maybe it's not a popular concept.
- 199 replies
- hard water
- water softener
That's not quite right. Icynene is open cell and the company will carry out an interstitial condensation analysis for your wall construction to see if a VCL is required.
Hi and welcome to the forum. It would be good to hear about your plans. Good luck with the project.
If there was a way to keep an even thickness I would be tempted to use a spray foam, such as Icynene, which would solve the airtightness and insulation issues in one go.
Insect Screen Corroding
Gone West replied to Gone West's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Yes I understand, I bought very nice looking stainless steel bullnose vents with built in insect screens but when considering the loss of flow through the 90 degree bend and the insect screen I decided not to fit them. Shame really they did look good. -
It's got 62% open area which is fine for my grille and ducting size. -
When we were building our house we took the hedge down to allow access for cranes etc. This left a nice large area of front garden which people thought nothing of parking in and then taking their dogs for a walk. One day I caught a chap parking and asked him what the hell he thought he was doing parking in my front garden. He was apologetic but said so you want me to move the car. I must have been having a bad day because I told him in no uncertain terms to shift it straightaway. After that several piles of pallets along the the frontage stopped further incursions.
Thanks for all the replies. Looks like I'll be ordering something like this https://www.themeshcompany.com/products/-12-Mesh---1.67mm-Aperture---0.45mm-Wire-Diameter---SS304-Grade---Woven-Wire-Mesh--68.html#SID=60 -
Gone West posted a topic in Mechanical Ventilation with Heat Recovery (MVHR)
I have aluminium outlet and intake vents for the MVHR with aluminium insect screens behind. They have been fitted for a couple of years or so and today while I was cleaning the crud off the intake vent insect screen I noticed the the aluminium had started to corrode. I could replace the aluminium insect screen or try brass or stainless steel. I originally used aluminium because I thought it would negate any possible galvanic action between the vent cover and the insect screen but if it's corroding anyway would brass or stainless steel be better? -
Remotely managing self build?
Gone West replied to Gary G's topic in General Self Build & DIY Discussion
I can second that. Without video evidence it would have been very difficult for me to get the foundations relaid after a complete cockup. It's all in my blog. -
That is correct. I have the main, 110mm, AAV in the bathroom behind a false wall which houses the concealed cistern. I also have an external vent around 600mm high in a flower bed near the sewage treatment plant. The BCO didn't have any problems with the setup.
Help with kitchen renovation/ 1st house.
Gone West replied to zoothorn's topic in Bathrooms, Ensuites & Wetrooms
I had wondered, but Clive's patience is amazing. -
Welcome to the forum Ed. It was similar for us as we needed 350mm Steico timber I-beams but found it was cheaper to have 300mm with a 47x47mm batten nailed to the flange. The 300mm beams were available off the shelf as well. It also made it easy to fit a 47mm ledger plate for hanging the metal web joists.
When we had to decide on grout colours, we've only got two different types of floor tiles, we ordered sample strips of grout in all the likely colours and just put them next to the tiles. I'm sure it didn't take more than a few minutes for Wendy to decide
I used BAL Micromax2 grout in the wetroom and the colour was smoke which looks very similar to your silver grey.
