Everything posted by Simplysimon
need to do that, as apparently you can - ' Create a GUI interface that simulates the spread of an infectious disease throughout a population.' just what we need, - woohoohan
nobody to blame because he said, she said, they said, it's all ok
oooh err.....
is it really worth it? what is the cost of moving a wall 200mm?
one other thing we had against a gas combi boiler was the hot water runs, turn on the hot tap, wait, use, turn off tap. turn on hot tap, may get warm water then cold, finally hot.
don't allow the se to stagger the beams, put in a block thick wall to carry the ends of both beams it will save cutting a lot of blocks. for all the extra cost of founds and a block wall, i would also not span any more than 3m without a dwarf wall it's surprising how much bounce there is in them and that was with the beams doubled up. even with the concrete pourd on top if you jump there is slight movement.
all slabs should be insulated to meet regs. however, a pasive slab will have a greater amount of insulation below as well as to the sides to avoid cold bridging
treatment of existing leaking / cold lintel
Simplysimon replied to Moonshine's topic in RSJs, Lintels & Steelwork
stick a dry verge on it -
Removing old fence post concrete
Simplysimon replied to Moonshine's topic in Landscaping, Decking & Patios
when putting in new posts it was good to make up a shoe in lead to the depth of the concrete, silicone around the top edge to prevent water ingress and when required lift old post and replace, this would depend upon the number of posts. as suggested above wrapping and sealing in dpc/dpm would do a similar job. -
First Self Builders on Pilot Scheme in Glasgow!
Simplysimon replied to Joanna Susskind's topic in Introduce Yourself
if you have the time then you're not paying labour on the manufacture of the kit, what's the insulation?- 26 replies
- selfbuild
- timberframe
(and 4 more)
Trimming the size of a scaffolding board.
Simplysimon replied to epsilonGreedy's topic in General Self Build & DIY Discussion
and won't be able to span the full distance in future -
standpipe near meter, then remove standpipe and connect meter to house. they don't bother up here, as long as where you're correctly connected to whatever you've specified the connection is going to, they're happy
what are you converting from, a standard large domestic property?
as a suggestion, only have a standpipe fitted. if you have a pipe from the house to the toby, they will check everything is compliant prior to making the connection to the main which i didn't realise, not that i was planning to do it incorrectly, but it meant more double check valves, taps and ensuring to correct depth prior to connection. if it had been to a standpipe it would have been quick and easy. if i had only specified to a standpipe they would have checked it was correct and not bothered with what i did, however, as i had specified connection to house and caravan this all had to be checked prior to connection.
i suppose it would need to be costed as to whether it's cheaper to replace with new roof lights or whether it would be possible/cheaper to increase the angle and keep existing windows
Proposed house cross section - WIP
Simplysimon replied to Moonshine's topic in New House & Self Build Design
could we have a bit more detail as to what we're looking at? -
Trying to install linux on a VERY old laptop
Simplysimon replied to ProDave's topic in Boffin's Corner
tbh the laptop runs fine it is a few years old but it was well specced at the time, just had a new keyboard and battery. it was more that win 7 is no longer supported that i thought to update having followed this post. an ssd in the future would be the logical option -
just to highjack this thread, running win 7 and this could be a realistic option to win 10. is it worth paying for the ultimate over the core? cheers -
just because you ask a sensible question, does not automatically mean you will receive a sensible answer here ?
MVHR design considerations
Simplysimon replied to JFDevon's topic in Mechanical Ventilation with Heat Recovery (MVHR)
fit a door properly and leave it open when finished or if you've been married for 20+ it won't matter -
downloads and opens in acrobat
New garage - make room above
Simplysimon replied to Robert Clark's topic in New House & Self Build Design
what would the future use be, garage or accomodation? if accomodation it could be done later if eveything is there and you are only applying for a garage -
make provision for both but wait until completed and signed off -
Making our own window cills (sills)
Simplysimon replied to ToughButterCup's topic in Windows & Glazing
nice and neatly done, i would say, to aid removal, a slight splay at the ends would help, as would oiling the timber and cable. used to be whale oil, stank to high heaven and there are less lethal oils on the market now. -
nothing in NHBC, https://nhbc-standards.co.uk/6-superstructure-excluding-roofs/6-2-external-timber-framed-walls/6-2-4-load-bearing-walls/ 95mm galv nail gun nails would be fine
