Everything posted by Simplysimon
done! being wired differently
apart from that, you get excellent technical support on the end of the phone, if you need it of course. can't fault them
Ground floor for bungalow: joists better than a slab?
Simplysimon replied to Dreadnaught's topic in Timber Frame
if you chop them down it'll only get boggy again, would break up the soil though. heard yesterday on gqt about a guy planting sugar beet on his ground, waited until roots had gone deep and broke the soil down and dug it all in to improve the quality. -
at least she was insured, it's the ones who come here on purpose, use the NHS and then go back home and don't pay their bill.
plenty of reading to be had here http://www.nhbc.co.uk/Builders/ProductsandServices/TechZone/nhbcstandards/
Urgent MVHR help needed
Simplysimon replied to vivienz's topic in Mechanical Ventilation with Heat Recovery (MVHR)
what's a kindle? -
it was the successor to the clay tablet, don't you read history? -
unfair, we came down the lecht in a 5ton motorhome, coasting in neutral.....good fun, wife wasn't amused though
https://www.reddiplex.com/custom-extrusions/ may be a tad expensive for the amount required though
https://coh-baines.co.uk/product-category/rubber-extrusions/rubber-t-section/page/3/ rhs, slightly wider than yours
of any use? https://www.woolies-trim.co.uk/category/322/rubber-extrusion
unless you get caught behind the usual sunday driver doing 40mph or tractor and very few places to overtake, lovely road to drive but not if you're in a hurry
200mm of kooltherm under the pipes here though not a refurb so easier to install
@scottishjohn, just read the particulars - 'and has good road networks to Ayrshire, Glasgow and beyond.' don't know how that truth was stretched without breaking unless they mean, drive along the a75 to the m74 then drive to glasgow and south to ayrshire.
@Roz, i'm trying to understand the reason for the 150x150 oak, if the underside is seen, then the wallplate will be seen as well and won't match? if you use joist hangers they will be seen on the underside, housing the trimmers in would be neater.
hell no ??? though i'm not a registered psychiatrist, but you must be close. that's sounds like quite a project, how much work does the falling down grade 2 need? welcome to the forum of those with varying degrees of lunacy.
don't mention the first again, no, no, you haven't found out why yet? ?, the second, isn't that standard sectional size? advice, for now, given. drawing for steels and founds would be appreciated to see why so expensive unless already posted?
Worktop joint issue - need advice!
Simplysimon replied to jcameron's topic in Kitchen Units & Worktops
if it's laminate they shouldn't be sanding the surface to remove glue, as you say it will remove the finish, and i can see where they've done it. -
is the 'fag packet' sketch with the collared truss the working drawing?
@zoothorn you're saying the overall (outside to outside) wall dimension is 4200mm? and that the truss dimension from corner of birdsmouth to internal junction of tie and rafter is also 4200mm?
Too much of a good thing
Simplysimon replied to daiking's topic in General Self Build & DIY Discussion
pic three left hand side, one not level, what does that say? -
Locker knob will not not tighten on screw
Simplysimon replied to Moggaman's topic in General Joinery
araldite it on -
a dpm then celotex/cooltherm. same/better properties
Airtightness and first fix
Simplysimon replied to dnoble's topic in Environmental Materials & Construction Methods
and i would think if you get a good result it will improve once the cellulose goes in.
