Everything posted by Simplysimon
looks like the protection needed to hold a drop bear
Old Cottage Restoration + Extension Project
Simplysimon replied to JulianB's topic in General Self Build & DIY Discussion
don't know wheher you've read this item, sounds as though it should be pertinent though- 74 replies
- cottage
- resoration
(and 3 more)
Source of narrow engineered oak flooring?
Simplysimon replied to Nick1c's topic in Wood & Laminate Flooring
https://www.nakedfloors.com/engineered-wood-flooring/narrow-oak/ searched for narrow oak boards and this was fifth and the second i looked at -
welcome to the forum, nice to see another close by
eaves detail required for no fascia
Simplysimon replied to Simplysimon's topic in Roofing, Tiling & Slating
hadn't considered a tilting fillet as i've not slated a roof on battens previously, i suppose it would work, the low pitch isn't an issue and that detail is appalling, for the sake of changing the angle of the fillet.- 9 replies
- no fascia
- tile batten
cheers that may be very useful i'd thought of nu-lok as well, though is there not something about having to go and get the materials. do you not still have the same problem of wind getting under the slates so curious as to how you are minimising that issue or is it not an issue? have you counter battened the roof prior to fitting the strips?- 9 replies
- no fascia
- tile batten
give the glazing company the inside/visible size and tell them to make the unit to suit
the only consideration would be the need for insulation in the web under the soleplate to avoid cold bridging
cheers, unfortunately it's the bit above the roofing membrane i'm looking at, when battened and counter battened there is a void which the wind will get under, great for ventilation, however, not so good for keeping slates in place.- 9 replies
- no fascia
- tile batten
Another mad idea. But who can tell me what exactly this Plywood is?
Simplysimon replied to Patrick's topic in General Joinery
the vapour permeability of the outside sheeting material will depend upon the insulation used in the kit wall. with cellulose it will need something which has plenty of permeability, don't want soggy paper in the kit. -
hi folks, does anyone have a detail for an eaves details for counter and tile batten but without a fascia? i'm trying to get this into my head and am swithering between leaving it open with insect mesh for ventilation, however, worried about the slates lifting and closing it off but can't figure how to finish cutting around the gutter brackets. i'm looking at putting the slates on battens as opposed to nailing through the roof covering as it's not sarking (medite vent) and it doesn't take a nail well. cheers
- 9 replies
- no fascia
- tile batten
Minimum Reasonable wall width for good U values?
Simplysimon replied to puntloos's topic in Heat Insulation
see no reason why not -
from outside in, timber cladding or render, 50mm cavity, pro200 breather paper, medite vent, i beam, medite propassive, 50mm service void and p/board -
350 i beams with blown cellulose 50mm service void, u value 0.11 -
Installing Burbidge Fusion System stair parts....
Simplysimon replied to ProDave's topic in General Joinery
do you have any small headed weans in the house likely to climb the stairs? -
Butlers pantry
Simplysimon replied to Russell griffiths's topic in General Self Build & DIY Discussion
a large utility with fancy units -
hi @Patrick, going by this site, https://www.metsawood.com/global/Tools/DoP/DOPOpenDocuments/DoP_MetsäWood_Birch_Plywood_PF_2019-12-2_en.pdfit states a vapour barrier can be used in the substrate. it does give a vapour permeability, however, i've no idea as to its effectiveness. they are useless for the outside as they definately won't be vapour open. you will need something akin to panelvent dwd, medite vent or egger dhf if you can get it. i went with medite in and out cheers -
if covered with breather paper it shouldn't matter whether waterproof or not, covering mine with mdf ? -
Curved corrugated roof ventilation and purlins
Simplysimon replied to cwr's topic in Roofing, Tiling & Slating
they work perfectly as long as there are no bubbles in the tube.
alternative would be to use corrugated cement fibre roof, no drips and quieter when it rains -
Slab vs beam and block foundations?
Simplysimon replied to Mike_scotland's topic in New House & Self Build Design
definately easy enough, though had the brickie known, he would have built a one block thick wall instead of half where they joined at the ends to avoid staggering them, he couldn't understand why it wasn't a slab as he said it would have been cheaper. -
yup, i ended up with one -
plastic insulation fixings with torch on felt
Simplysimon replied to netmonkey's topic in Flat Roofs
best practice places osb or ply on the top side of the insulation to help secure it. i wouldn't fit an external insulation layer without it and unless the felt is being fitted to a flat roof abutting a hose hair covered slated roof there is minimal risk of fire. i would these days, however, go with a monolayer rubber roof for ease of fixing and longevity.
