Basic silly question
Russell griffiths replied to Nic's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Have seen this done exactly how you have drawn it. you will need to ensure that plenums for the mvhr are scrupulously sealed around, and also where the ducts drop into the plant room area. -
Oiling doors - before or after fitting
Russell griffiths replied to Thorfun's topic in Doors & Door Frames
I’ve just osmo oil my oak doors, one coat before fitting to protect the grain from picking up dust, and a second coat once fitted. absolutely no chance of drips if you apply lightly as it says on the tin, and then use a lint free cloth to rub it in and spread evenly. -
I suggest you do some testing. It sticks eps to eps but try sticking the cement board to the eps, been there tried that. The only method I found has been mentioned, a coat of render then tile adhesive, or just render it. James hardie make a board for exterior use it comes in various sizes and colours.
Clear everything, but you must also clear all the debris, do not leave any piles of timber just in case it’s used by some rare newt or something. Literally strim it down to a flat lawn. If planning was unsuccessful could the adjacent houses be interested in putting a couple of garages on it, just a back up plan to cover your investment.
I can recommend James hardie boards, however you will struggle to stick anything onto the eps. Unless you have found some miraculous sticky thing, I rendered my plinth with a waterproof render finished with a marble/ silicon top coat. Finished in a dark grey so it looks like a traditional renderered plinth.
Building a habitable room under that roof without fully replacing it, is probably the silliest thing I’ve heard in a while. Any wind driven rain will just leak through onto the insulation, it will then track down the insulation until it finds a way out onto the plasterboard ceiling, you won’t be able to pinpoint the leak as it won’t appear where it originally came from.
Complain or not
Russell griffiths replied to crispy_wafer's topic in General Self Build & DIY Discussion
Pull it out put a screw in, fill the hole. It will take longer to drive to the merchant to take it back. -
Which internal doors have to be fire doors? if any
Russell griffiths replied to Post and beam's topic in Doors & Door Frames
From those figures it’s £60 times 12-14 doors that’s a grand. My 35mm solid cores turned up today, I really don’t want them a lot heavier they where a pig to carry around the house. -
Buy solid core doors not hollow core. You can also go 44mm for a heavy feel. -
Depending on what your outer wall finish is I wouldn’t want dissimilar materials. Rendering across eps onto concrete blocks is asking for a crack in my opinion.
if this is what your after then bite the bullet and get it done, strip foundation, two courses of Nudura, couple of lengths of floor beam and a dozen blocks, build it in to the side pillars. Strip of the Nudura to the pillars on the inside faces, resin fix in some rebar and pour it.
Don’t you have half a dozen Nudura blocks spare. I would get it done in one continuous material.
Looking for a dual fuel hob.
Russell griffiths replied to ProDave's topic in Kitchen & Household Appliances
If you have gas, I cannot for the life of me see why you want induction, what do you think it’s benefits are. -
You need a few things, but first you need to get all these answers and collate them so you can get a system installed that will do what you want. Then you need to tell your installer exactly how it must be done, without pictures we are guessing a bit, so it might take a few days to get the exact remedy for this. Timberframe house with a brick skin, the chances are that the timber he ripped out was actually a fire stop, these are installed at window and door reveals to prevent the spread of fire within the cavity. They can also act as a cavity closer. The chances are your cavity is cold and draughty so the block of timber was holding the draft at bay, by removing this and fitting insulation badly he’s allowed the cold to whistle behind the plasterboard and come in at any tiny hole. You need to find a method to fix 4 things fire stopping damp from outside to inside cold from the cavity cold from the outer brickwork you might find one one of the new fangled cavity closers will do all of these when fitted correctly or you might find they will do a couple of the points and you need to add something else to complete it properly. You might find you you don’t need fire stopping on the ground floor doors. Someone on here will will be able to clarify that. Im just trying to get the ball rolling for you. Just to throw a spanner in the works, did you move the door to Within the insulated part of the house or are the still in the cold brickwork.
The AAV needs to be accessible, I believe it’s a building regs thing. They do fail so this would be the first point I would look.
Tile levelling using spacers under tiles
Russell griffiths replied to skeg0's topic in Wall Tiles & Tiling
No. This is a stupid idea. Sorry but it is. Lay them properly and check level with with a straightedge, it’s how it’s been done for years before levelling systems came about. -
Pitched Roof Thermal vs Acoustic insulation trade off
Russell griffiths replied to Nye's topic in Heat Insulation
In my opinion the tec sound and vcl are in the wrong place, I would have them on the room side of the pir. Have tec sound said this this is where it should go. I would also also look at the weight you are adding, have you had it calculated with two layers of 12.5 plasterboard. That is a huge weight. -
Concrete footings turned out to be 1m wide with a 300mm slab on top, I had guessed it would be 100 mm thick at best.
That looks really good, I take it you got some professional in to help you.
Garden Room - Insulated plasterboard, yay or nay?
Russell griffiths replied to Amelia Winters's topic in Heat Insulation
Tape all the pir with foil tape, over the studs and any fixing holes. You might need a bit of ventilation in there. Maybe one of the new fangled positive input things, not my thing so ask on here for some guidance. -
You could probably do with saying how big this is, and what the floor is made up of. My wife has a garden office that is poorly insulated in my view, but stays warm enough for her to work very comfortable all year round, with only a small oil filled electric heater, I think this is due to its small size. I think if you doubled its size the cost to heat it would be painful. You only buy the insulation once, you will pay to heat it forever.
