Have you priced any of this stuff up, the last time I looked at an osma chamber base I thought it should come with a free Rolex.
Insulating a shed for laundry room?
Russell griffiths replied to flanagaj's topic in General Self Build & DIY Discussion
I’m not sure I like the shed idea, I think it would be too small, after a couple of years the fun of heading into the shed to do the washing will be wearing thin, I think I would either build something better or drag in a shipping container welfare container that’s already insulated, add a heated clothes rail and you can do drying in there as well. -
Windows & Doors into ICF openings....
Russell griffiths replied to Mulberry View's topic in Insulated Concrete Formwork (ICF)
Norrsken wanted 30mm clearance above my door for deflection of the rsj above the door, I told them it was icf construction so no rsj, they couldn’t understand how it held itself up. do your own research and make a decision, a few companies arse covering goes to silly levels. -
Straight onto the eps, we discussed this a while back, the windows are heavy, but divide the weight by the area and the downwards pressure is very minimal. -
Available in thin coat for internal tape n fill, widely used in America and Australia where they tape n fill far more than us they do a massive amount of decorative beads including shadow gap and ones that take led strip. we are a bit stuck in 1960.
They don’t dent, they get bashed, the plaster pops off, you can then re fill the damaged area without changing the whole bead.
How far is it too the outlet, could you clean backwards ? nothing of what you linked to is necessary you don’t need any form of trap, and don’t need any form of gulley 110mm pipe then a rest bend then a bit of pipe and a square plastic grid. if a blockage occurs you lift the mesh lid and stick the hosepipe down it. if you have a long run parallel to the house you could put a rodding eye on the end if you wanted. no solids going down it just some dust from the gutters. and no smells coming back up. just be sure the ditch doesn’t overflow and back up your pipe, you might need a flood prevention valve on the end.
Plastic beads, the only proper way to get a sharp external corner IMHO
Electrical supply to static caravan
Open an account and go and discuss your prices. -
Our attached garage is lined with 18mm osb, then pink fire board and skimmed. pits made a lovely room and I’m happy it’s sort of safe.
floor joists into "I"beam
Russell griffiths replied to carlos21's topic in RSJs, Lintels & Steelwork
Notching takes time but costs nothing but labour bolting a plate in needs joist hangers, nails and bolts. if your fast and accurate at cutting timber then notch them in. obviously you can’t make the notch to a size that it takes the strength away from the joist, if this is the case then joist hangers will retain the full size of the joist so retaining the strength rating that it was designed for. -
sweet chestnut cladding - opinions please
Russell griffiths replied to marmic's topic in General Joinery
Have a look at Vastern timbers range of heat treated timbers. TBH who will know you used chestnut after a couple of years it will look like any other timber. chestnut is well known for splitting, it’s actually used for split railings. -
Car Port - Concealed Roof Restraint Straps?
Russell griffiths replied to Mulberry View's topic in Brick & Block
Put stainless studding down the cavity between the two leaves of brickwork, let it poke up past the top course drill a hole in the wall plate and drop them over the studding. you could just drop the restraint strap down the cavity and build it in, but it would be hard to terminate it neat at the wall plate. you could use a twist strap and go onto the side of a rafter. it all depends what you want to see or what you don’t. if it’s fully open underneath you will want no straps on show. -
Laundry room sink / appliance plumbing wobble…
Russell griffiths replied to Omnibuswoman's topic in General Plumbing
Why is the waste so high up the wall? what is on the other side of that wall, could/ should the waste be lower -
Static caravan on site!
Russell griffiths commented on flanagaj's blog entry in Contemporary Ball Ache
Try to make living there more pleasant look for some patio slabs free on Facebook, build a small patio, build a path to the washing line, put up a small shed that you take your boots off in and work clothes, if the wife starts walking mud in it will start eating in to the dream. build good steps to the static, keep her warm and happy and you can probably put up with the house build. -
You will have many more stressful days like that. just think how that plywood saved the day, then every time you have a day like this planned think what could go wrong, and what would save the day, whatever you think will save the day make sure you have it ready. it could be an extra man on concrete pour day or that stack of 4x2 that you found free on Facebook, get it all ready you will find the majority of lads are used to solving problems. -
Roller blinds.
Russell griffiths replied to Russell griffiths's topic in General Self Build & DIY Discussion
Indoor, needs to roll down and then up again, can’t be £50 worth of material on a steel pole and £10 worth of Chinese motor. too many people making their bit of markup on a £250 product. -
Roller blinds.
I had a quote for 7 it was a tad under £12000 fitted, so I asked for just one supply only, that’s the one that’s a grand. absolutely bloody mystified.
