Now that is certainly a better thing to worry about, I would start a new post about fire proofing and ceilings. as soon as you start going 3 storey everyone gets a bit fidgety.
Nobody will be coming and counting light bulbs, get it in.
Can't find a brickie (Hampshire). Any suggestions?
Russell griffiths replied to flanagaj's topic in Brick & Block
I’m not sure i would be looking in the merchants you have a few things going on here you had a post asking how to get a certain mortar colour, and this is mainly down to quality tradesmen getting the local Joe who slashes up an extension every week is not the man I would want. for a whole hose with multiple openings I would want a quality team. cheap n cheerful is not what i would want. -
Maintaining air tightness with downlighter
Russell griffiths replied to Annker's topic in Heat Insulation
In that case you will need a full depth of joist box all taped up. make them bigger than needed. -
Show us a picture of the build, your times seam woefully low. -
Bending small aluminium sheets
Russell griffiths replied to Dunc's topic in General Self Build & DIY Discussion
2mm is far too thick to diy bend without the correct gear, either get some thinner material or just buy a pre bent piece. Most roof materials are well under 1mm the only thing I have in metal thicker than 1mm are the window cills and they are probably only 1.5mm. -
After living in Australia this is a common thing over there. a large plot of land is divided into a few dozen house plots, the local companies come in and buy and build their design house on that plot, punters then visit at the weekend and walk around all the show houses. you pick a builder you like and commission them to build on a plot you have or they will have other plots on other sites. I really hate the English way of a divided up estate all built by the same contractor in the same boring design to the same poor standard.
Can you not cover it in pvc trim the same as the windows, it will take up about 8mm.
Why do you have a steel lintel on show, shouldn’t it have a trim over it.
Your not going to drill a 210 mm hole with a hole saw definitely a jigsaw job as John said fit ply mark centre point for duct drill centre hole with a slight fall remove ply and trace outline of duct cut out hole in ply draw around off cut of ply on the pro passive cut out pro passive draw around cut out of ply on outer layer of truss cut out outer layer Fit duct and seal up well fit ply and seal up well. or leave the duct loose until you are ready for the mvhr. I would always cut the holes larger as I like a good squirt of illbruck foam around everything
Wooden subfloor with 4 inch joists and rockwool
Russell griffiths replied to Rocket Ron's topic in Heat Insulation
I’m going to say this is such a horrible job to do that you will end up doing it badly if done badly with air gaps then you might as well not do it. I would do room by room take the skirting off, lift the floor, re fit floor re fit skirting and then re decorate each room. -
Plant room 18mm ply direct to the walls then 2.4x1.2 sheets of fermacel jointed using their joint stick, then two good coats of eggshell paint. all the plumbers handprints and pencil marks wash off easily or a quick touch up and there gone. this is what I did. I cannot believe the amount of unpainted walls in plant rooms I see on here that then have ufh manifold fitted and tanks put in place before the walls are painted looks totally rubbish.
I had two different lads do two rooms both I wasn’t happy with the finish. in the end I had a recommendation from a lad on here, I used the bloke he recommended and he has since gone on and done another buildhub members house. £4 a metre gets you a site plasterer, smash and dash lots of work for the decorators. mine came in around £6 when I added it up, I could see an awkward layout or high ceilings costing a bit more. I seam to recall a conversation with him about £10 a metre for high quality pain in the arse stuff.
ICF Window Render Reveal
Russell griffiths replied to WiltshireLink's topic in Insulated Concrete Formwork (ICF)
Ask your rendering team to take you and show you how they normally finish this area, have a look and see if it fits in with what you’re after. I used the coloured trims and I think it’s very neat, but it takes a good man to run the render up to them neatly. the trims do have a tear off strip that protects the windows while they are being rendered. -
Site entrance gates
Russell griffiths replied to flanagaj's topic in General Self Build & DIY Discussion
Look on Facebook, normally a few sets on there knocking around for half what your quoting, will sell for same money at end.
