Painting house internals - any tips
Russell griffiths replied to Lincolnshire Ian's topic in Decorating
Work backwards look at your finish paint, then read up on the primer / undercoat for that paint. do not rely on a mist coat of watered down cheap arse contract Matt everyone does this, but it’s not 1980 anymore, the top coat anti scuff Matt paints don’t like sticking to it, there are lots of videos on problem jobs. don’t put £100 a tin top coat over £10 a tin primer. I’ve got a couple of horror walls that might have to go back to bare plaster. -
DPM External Flap - what to do with it?
Russell griffiths replied to AppleDown's topic in General Construction Issues
Water works with gravity everything travels downwards ( apart from a bit of capillary action ) so lap everything downwards, just sit and look, pretend your a water droplet where will you get trapped, how would you run under that sole plate and into the house. lap everything down and out. -
You need to consider the temperature for pointing, needs to be 5 degrees and rising for the duration that it will take to dry. fix the problem of water hitting the wall first and the pointing can be done in April.
That’s your problem fix that and let the wall dry out, then re point it in the spring.
What’s that black plastic pipe. zoom the picture out.
I did exactly the same floor screed down boards on walls big fat squirt of foam all around entire house let it cure and cut flush fit skirting. don’t be buying one tin, get a box of 12 at a time and use it everywhere.
Are you sure, you have a mixture of two floors there, you wouldn’t put block n beam in then an insulated raft on top. are you sure it’s not just insulation on top of block n beam then screed. post a drawing up. if your keen on an insulated raft then look for a SE that specifically works on them regularly.
Spray painting - is it any good?
If you spray it your still supposed to back roll over it to get the correct finish, straight from a sprayer is too perfect. -
So as they swing out and along they put a load on the edge in a sort of pulling motion ? is that what you mean.
I’ve just re read your original post, I thought you were proposing to build a beam 178mm high, which I based my answer on, but looking again your saying plate both sides in ply 600mm high. Now that would work. I would want to extend the plywood onto both side walls, not finish the ends level with the sides of the opening.
You won’t be spanning four metres with timber alone. with that wall above it will definitely deflect too much. steel flitch beams or some sort of steel beam with insulation and timber all sandwiched together.
What am I missing here. I see no need to fireproof the framing, you wouldn’t fire proof the frame of a house, so why a garage. timberframe as the structural part, steel sheets on the outside as non flammable exterior, then if you wanted you could put cement sheets on the the inside. but being as it’s in jock land what do they want.
SIPs quote
Russell griffiths replied to Kevan Marshall's topic in Structural Insulated Panels (SIPs)
What score do they say they will achieve with the airtightness test. -
Nope. most of those hangers rely on having brick work above them to secure them to the wall. you need to sketch up what you think your verge detail will be, you say no soffit but you will have a small drip edge coming down from your roof finish. This needs to be on the outside of the render. I think Nick mentioned oversailing the top cord of the joists. this is an easy way of not having to fit a rim board/ pole plate. fit a wall plate cut at an angle then top hang the rafters/ joists. Infill between them with noggins then sail over your ply / osb, then roof trim will hang down and cover the ends of the rafters and ply. get your crayons out and sketch up what you want it to look like.
Steel frame agricultural barn type thing. steel c sections bolt to the slab, clad on the outside so non flammable construction, insulation on the inside and then osb clad on the inside. im not sure of any regs for a garage apart from fire regulations close to other properties. as far as I’m aware there are very few regs for a garage. I would get the detailed drawings from the agricultural barn company and send that to the council.
Why would you build a permanent structure on land that is leased, unless you have a long lease. Does your lease state that you have to put the structure back to the state it was before you built, meaning you will need to remove your garage. depending on what you want to put in the garage maybe a shipping container or pre fabricated sectional garage would be better.
Remember if you take this up In block work you need to treat it like a gable wall. so angled ties at ceiling joists level, then more ties at rafter level. the ties stop the wall bowing out and restrain the ceiling and roof rafters, it all works together. with the icf walls you have done there wasn’t such a need as the structure is very rigid and stiff on its own, a block cavity wall can be a bit wobbly.
It wouldn’t as you would have a cavity all the way to the floor. and being an open carport I presume a bit of moisture will quickly dry out if there’s a bit of breeze to blow through it.
You will also need a substantial way of keeping any moisture from behind the render board running backwards into the structure I would use a wide dpc from the top of the ceiling joists downwards to create a tray damp to deflect any moisture outwards.
If render is your preferred finish why are you changing from brick to timber. wouldn’t it be more straightforward to continue up in a concrete block and render that. If you are happier in timber then i w put a dpc on top of the wall, then a treated sole plate first, use this to span the cavity and close the cavity in one go. then ceiling joists on top of sole plate, put noggins between joists and then another sole plate on top of joists then stud wall up from there. you want an angled top plate, or a flat top plate then an angled trimmer to take the metal web roof timbers. that’s a shit drawing.
Before you start any ideas about drilling into this wall you need to actually figure out what the problem is. start by clearing the top area and all that growth that is obstructing you getting a clear understanding of what is going on. it is clear from the picture that the water is running over the top of the wall, it should not be, so figure that out before knee jerking and drilling holes in an otherwise perfectly good retaining wall.
Why do you think it needs reinforcement the weight of the tiles is determined by what base board you fix too, not the stud strength, do you have a picture of it. unless it’s been butchered before it’s probably strong enough. you could add extra noggins into areas that will have fixings, or you could sheet it with plywood before you board it.
