Flue height incorrect
Russell griffiths replied to BotusBuild's topic in General Alternative Energy Issues
Is it a flue or a chimney for a woodburner. -
Will we hit 500+ man days on-site?
Russell griffiths replied to Benpointer's topic in Costing & Estimating
6 years, just me, have I gone over. 🤣🤣 -
Lead leached onto Resin roof - Cleaning suggestions
Russell griffiths replied to paro's topic in Flat Roofs
Stop looking at it, and go to the pub. -
You are not solving this problem and keeping that stone exposed. not unless you dig down outside and tank it out there.
Week 8 - And pause... or not.
Russell griffiths commented on Benpointer's blog entry in Contemporary build in north Dorset
That plywood lifter is genius. 👍👍 -
Wooden external cladding identifcation
Russell griffiths replied to rah212's topic in Building Materials
Go to a local timber merchants they will have a spindle molder and match the profile. -
Cash discounts, scaffolding
Russell griffiths replied to Drellingore's topic in General Self Build & DIY Discussion
Scaffolding, digger hire, concrete pumps, anything you can’t claim back. -
Would an outward opening door allow you to comply with the disability regs, I personally would avoid one if you can, my parents had one and opening it on a windy day was a near death experience.
Drilling hole through existing foundation
Russell griffiths replied to LSB's topic in General Construction Issues
Do not go down the macerator route. end of. -
External door, internal threshold Q
Russell griffiths replied to BotusBuild's topic in Doors & Door Frames
You said this wasn’t your disability access, you don’t need two just the one. no ramp needed. -
Timber frame internal wall load for pull up bar
Russell griffiths replied to skeg0's topic in Timber Frame
You can screw into those studs, but the plasterboard will start to crush with repetitive loading. solid timber needed like a piece of 18 mm mdf painted to match the wall to spread the load, screw through the mdf into the studs. the mdf is like a big washer, the surface area of those brackets is small and will eat into the plasterboard. -
Is this your disability access door or not. -
200+ metre utility connection
Russell griffiths replied to Oz07's topic in General Self Build & DIY Discussion
I think covering is down to ground conditions, clean dirt no stones then I believe you can use the dug material, stones bigger than 25-40mm then clean gravel surrounding the pipe. -
You shouldn’t be putting 110mm in a 9inch trench, not enough room for the pea gravel to come up to required spec. 12inch bucket on the digger for 110mm pipe. -
I nailed all my thermo modified poplar, it’s inside on a ceiling so isn’t catching the weather. secret nailed through the tongue. this method may not be substantial enough for outside use.
Vastern sawmill has a huge display of every type of timber they do on display outside. TBH they all look identical from 10 m away they have all weathered to a really dark colour. so I’m unsure if changing type actually makes any difference after it’s been sitting outside for a couple of years.
Just buy solid timber no need to trench the heads, glue and screw before fitting, get in the habit of pre knotting the timber and giving it a coat of primer before fitting, far better than your painter doing only the front face afterwards.
Ideal drainage pipe gradient advice needed.
Russell griffiths replied to SteeVeeDee's topic in Waste & Sewerage
I thought clay pipe now uses plastic and rubber connectors, no sockets and hemp packing any more. the clay is straight and the connector looks just like a plastic slip coupler. -
Coach screws do not require a nut on the end. coach bolts do.
All in plastic, why use clay unless it’s been specifically asked for. ideal fall is 1::40. -
Door stops, butt or mitre
Russell griffiths replied to MortarThePoint's topic in Doors & Door Frames
Butt join. top in first then the two sides. -
Doesn’t the whole installation look a bit shit.
If it’s a detached property with a couple of metre gap between you and the neighbours, 100mm up or down wouldn’t even notice, so I don’t think they care that much. i would set it up as high as you dare, it will help with drainage runs and run off from the field behind, and your retaining wall will be shorter.
Retained side pillars
Russell griffiths replied to OldieNewbie's topic in Bricklaying, Blockwork & Mortar
The side your not knocking down ??? -
For this area get a screed company in, they will be in and out in a day and it will be spot on, I did traditional screed with fibres. fantastic finish from a company that does it all day everyday.
