Everything posted by Conor
Struggling to get a gate we like at a sensible price. As suggested on a previous thread, I'm making my own. Keeping it quite basic, 4m clear opening, each leaf 1.5m tall, metal frame, hardwood panel infill: Some questions: Metal frame: assuming 50x50x3mm SHS OK for the job? Planning on using L shaped angle to fix the wood panels to. I'm OK at welding... Hinges: Any recommendations? Latch / Lock. I'm getting an opening kit. What kind of latch/lock do I need (if any?) Wood: Thinking 150x25mm hardwood planks for longevity. We'll be painting/staining. Do I need T&G panels, butt, biscuit join? Don't want cracking/splitting. Anything else to consider? Thanks
Condensate drain and soakaway. How's this for an idea?
Conor replied to ToughButterCup's topic in Waste & Sewerage
I'm planning similar, straight out the wall, down through a waste pipe in to the ground. Our entire house is backfilled with 25mm stone, one giant soakaway. It's easier than trying to tie it in to the main sewer. No need. -
Tiny amount. I've never gotten round to plumbing in my condensate pipe, so it current fills a large plastic lunch box. Only really have condensate when it's cold outside. Normally in winter it's about ~100ml per day. Nothing in summer. I empty it a couple times a week. -
Waterproofing Block Outbuilding for storage
Conor replied to HanleeHouse's topic in Waterproofing & Sealants
Render and a masonry paint. I'm not sure paint alone will do the job. -
Our spark refused to fit our consumer unit etc in the plant room until it was boarded over. And then Intumescant paint on the backboard for the CU, inverter etc. Fyi our ply sheets were fitted to the blocks using 50mm hammer in fixings. Seems to have been a spot on job. In hindsight would not have bothered at all as all the gubbins ended up on a separate board as the spark wanted to run the cables behind it. So I'd just stick a couple battens on the part of the wall where you'll be mounting your gear, and use fire rated backboard. For pipe clips etc, wee concrete screws are no bother. For light blocks you just drill a smaller pilot hole. E.g. 4mm isntrad of 5mm.
PD Extensions and floor plan advice
Conor replied to FreddieW's topic in New House & Self Build Design
Get an architect / technologist involved to help with the optimal layout. We did an extension and went ~600mm beyond PD under recommendation of architect... Slightly longer wait to get started but was worth it as the space was perfect. -
You run the risk of being asked to rebuild parts of the building. There's lots of arguments either way, e.g. retain structure in order to reduce embedded carbon cost, Vs demolish to get better insulation and lower long term CO2 emissions. Also, don't forget your mortgage company (need their permission, unlikely you'll get it for a full demo) and also insurance. Might be worth a word with the planning officer to see what they think
Get rid of the 10mm and have both 15mm. You need the flow rate. We insualted our long (15m+) run. Means if you go back to the sink a few mins after running the hot, it's still warm enough. Otherwise it's a 10 second wait for hot water.
The black pipe will be imperial sized alkathene. Remove the tee. Fit a universal coupler, something like 22-29mm OD to 25mm MDPE. Then a short length of 25mm MDPE pipe, then a 25mm tee. I'm assuming that's all 25mm, you've not specified. You'll need to make that hole a good bit better to get the space. Don't use brass compression fittings!!!!
Measure, and see if they are actually 25x50mm, and not 22x44mm. I think the coloured batten thing is regional/supplier specific.. All the ones I've seen here in NI are natural (with a green tint from the preserving process.) But are stamped and correct standard.
Existing water supply to temp
Conor replied to SarahG's topic in General Self Build & DIY Discussion
It's a domestic self build, commercial metering not required for your builder. Never speak of this again 🤫 -
1. Yes, the supply will need to be extended by the network operator to the permanent meter box in your house. The meter will also have to be moved, this is done by the electric provider. 2. BUT... You .might be able to keep the meter in the box as the permanent installation, and run your own cable from the main fuse I side you your co sumer unit.
A bit late now, but I wouldn't have contacted Thames at all. You have a supply, use it as you see fit. You can apply for the lead replacement once you have finished the build and you have laid your own plastic supply pipe to the stopcock. Thames will then replace the lead pipe on their side. -
Do you have a pressure gauge on the I coming supply? If you have a PRV, you should have one upstream and one downstream. Is both hot and cold affected? Does it vary across the day? How are your neighbours supplies? (My money is on a burst incoming supply pipe- on that topic, locate your meter box, flip the lid, see what the dial is doing)
Fit a threshold / Aco channel drain all along the porch and affected areas. Make sure it has somewhere to drain to that's effective.
Yeah, our BCO wanted a gap under the shelf that was covering it, to allow air in.
Nowt wrong with that. Use proper 110mm pipe brackets rather than builders band. For the boss from the shower, you'll find due to the depth of the trap and the position of the 110mm pipe, it'll probably be in a horizontal position, rather than vertical as you've described. Aim for a 1:40 or better fall in the soil pipe. Basin and shower pipes can be any angle (other than flat or backwards!) AAV is completely fine. As long as it's higher that the highest trap. You can box it in, but should be left accessible as they can sometimes stick and stop working. The building control documents are a really good guide for the do's and don'ts.
Using 75mm-wide blocks for inner skin, instead of 100mm?
Conor replied to ectoplasmosis's topic in Brick & Block
Good case for timber frame with block outer skin. -
Get yourself to your nearest builders merchant.
No, different trade. We got the one company to do the lot but he just subcontracted the tape and jointing part. If I'd known that from the start
Three possible problems. Could be one, some or all. 1. Configuration. Something not right with a pump/valve/controller. Impossible to say from here 2. Airlock / blockage in a pipe somewhere. 3. HP is incapable of delivering the additional heat load. And another, almost certain, Your plumber could be out of thier depth.
Would not recommend for office space. Metal box. No phone or WiFi. Get a container for storage, and a second hand touring caravan for office. We sold ours on two years later and only a £400 loss. Having a fridge and cooking area to yourself is invaluable on a muddy, cold wet site in he middle of winter. Ours had an awning so good for the summer and drying wet gear.
