Mr Punter
Internal door locks.
Mr Punter replied to Russell griffiths's topic in General Self Build & DIY Discussion
I like internal thumbturn. Much safer in the event of fire. -
Plasterboard before screed... any major issues?
Mr Punter replied to eandg's topic in General Self Build & DIY Discussion
Sounds fine to me. -
Decking without footings - bad idea?
Mr Punter replied to MarkH's topic in Landscaping, Decking & Patios
Yes, silly idea. You need a footing for each post. https://www.wickes.co.uk/how-to-guides/garden-landscaping/plan-build-a-raised-deck -
Stiff brush, jetwash.
If this is a new build you will need a lot more wall insulation. Also, the tanking slurry may well not keep it dry and does not seem to be for habitable basement space.
No, they don't normally in England except for flat entrance doors and (I think) connecting to garages.
It would be about an inch all round. Ask the supplier if the door would be suitable.
You could buy a 2032mm x 813mm door and have it cut down.
Can the BCO require a job to be done by a given date?
Mr Punter replied to ToughButterCup's topic in Building Regulations
The temporary habitation certificate is a Scottish thing. Here, you can move in when you want if you have satisfied planning conditions. -
I think the material mix is highly engineered. Not just any old sand and cement. Also the process will be sensitive to environmental conditions - temperature, humidity, sun, wind, rain. I don't see it is a viable means of building low to mid range housing but I am sure with the effort going in to improve it there will be applications elsewhere.
Three phase supply installed instead of single phase
Mr Punter replied to MarkW1979's topic in Electrics - Other
Did the meter box come with ready broken hinges? I really hate the poor quality of the things. -
Metal Stud Walls - How much acoustic protection is too much?
Mr Punter replied to Tony K's topic in Sound Insulation
The difference will be huge. The doors will be the weak point. -
Patio Aco Drain Installation
Mr Punter replied to machtucker's topic in Landscaping, Decking & Patios
You could put it in level but I would prefer a very slight fall. Even 10 to 20mm over the length of drain would be fine. -
He is not actually using a shovel, that is a broom. He is tidying up, bless him. He soon lost that habit.
Even if there is no mention in the title deeds, if the drainage has been in place for at least 20 years and you (or your predecessors) have not had to pay for use, you may have the right to use the pipe via prescriptive easement.
The soil pipe from the Geberit is 90mm so you need to fiddle about to adapt it to your 110mm.
Screw or nail timber cladding?!
Mr Punter replied to DC5's topic in General Self Build & DIY Discussion
+1 the Fischer ones are fairly cheap too. If you are using a Paslode first fix gun, get a "no mar" tip and make sure you adjust the depth. -
The EA a fairly hopeless when it comes to communication or preventing illegal discharges. The system you have needs replacing. You probably need to focus on the total cost and how the cost will be split. If there are 5 properties, splitting 5 ways sounds logical. I am not sure where the "landowner" fits into this but as long as you have their consent to do the work on their land it should not be an issue. None of this will come cheap or be quick to resolve. Quite why none of this was covered when you bought the property is a separate issue that you could consider.
Just be a bit cautious as some policies have a right for the issuer to cancel if work is not completed in a timely manner. Check the wording.
What are your thoughts on this project estimate?
Mr Punter replied to James Frome's topic in Costing & Estimating
I nominate this for the Buildhub "Best Mixed Metaphor". Love it! -
Can't you just fix a handrail to the wall on the right and get rid of the stub wall?
