Mr Punter
700mm is a lot over 3 steps. If it is just 3 risers, they would be 233mm and the maximum allowed is 220mm. I would hope that BC would allow handrail on one side only.
Yes you can look it up on YouTube. Just a series of holes drilled in the frame and the plastic vents fixed over.
What were the issues with the beams? If they see something on a visit that is high risk they should make you resolve it no matter that it was not picked up earlier. Standard inspections are often: Foundations Structure complete (this sounds like when you got pulled on the steels?) Wind and weather tight First fix Thermal insulation Completion – drains to be on test Some of these they will just go with photos.
I have used GRP tread covers before. They look good and are non slip but are expensive.
Downpipes and waste pipes over string course
Mr Punter replied to richo106's topic in Rainwater, Guttering & SuDS
They do the 5mm washers which I have used in the past. They also do a 50mm offset in the downpipe but that may not work for you. Alternatively, could you carefully grind out the part of the projecting string course that is in the way? -
Yes you need trickle vents, then replace the defective sealant.
Worktop overhanging on flush handless kitchen
Mr Punter replied to revelation's topic in Kitchen Units & Worktops
I think you will be really pleased with this when it is finished. I hope the lift up units have servo drive or you won't have spent enough! -
MVHR, Zones and UFH
Mr Punter replied to Post and beam's topic in Mechanical Ventilation with Heat Recovery (MVHR)
MVHR is only doing ventilation and has almost no impact on heat distribution, so just look at the UFH. Splitting living and bedrooms into 2 zones is fairly common. It means you can control the timing and temperature separately by zone. -
It is quite possibly asbestos cement.
What are your thoughts on this project estimate?
Mr Punter replied to James Frome's topic in Costing & Estimating
Because yours is a flat it will be less sought after. I would do it up to mid spec and sell to someone who wants the location at a (relatively) keen price. You have already had your pants pulled down by the architect. Don't go back for more. I see there is a house nearby https://www.rightmove.co.uk/properties/131305742#/ and that is asking price and unbroken freehold house. -
MVHR is Largely Bogus
Mr Punter replied to DavidHughes's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I have heard this can happen but I cannot work out why you cannot create a few leaks and have it re-tested? -
Based on these I would not recommend you go ahead. Find somewhere above ground and damp free.
Often you can but it is worth doing a condensation risk analysis.
I have used Fermacell instead of plasterboard. It holds a screw really well. It is an absolute pig to use though and expensive. Heavy and difficult to cut. It is sometimes used double boarded in prisons as it is very tough.
Fixing Wall Plate Restraint Straps
Mr Punter replied to richo106's topic in General Construction Issues
Yes 50mm 5s are fine, as is one per block. Wall plate would have been better half lapped but it is done now. -
Galvanised
Spring toggle fixings can work well.
'False ceiling' at roof apex/ridge for ventilation?
Mr Punter replied to GlanMenai's topic in Heat Insulation
OK I get you. Yes I assumed vented because I normally focus on new build. -
I guess it would still vent either side of the ridge board in any case. You don't need ventilation from one side to the other. You probably don't get much anyway, as the airflow will go up to the highest point then exit but I agree the flat ceiling area is worth doing. -
Boundry partwall issue
Mr Punter replied to virat bhavsar's topic in House Extensions & Conservatories
Party wall and boundary wall issues are rarely clear cut and often a source of dispute. It is not easy to establish whose land they are built on, who is responsible for repair etc. What are you hoping to achieve? There is a website at https://www.gardenlaw.co.uk/phpBB2/index.php where people discuss this in minute detail. -
It is fine to insulate right up to the apex. One benefit of having a flat area can be that lights are easier to place. It is good to have a small amount of PIR under the rafters as well to prevent cold bridging. 40mm helps a lot and it reduces the risk of condensation on the rafters.
