Mr Punter
I am not sure of your setup but a raised tray can help if the fall is tight. They can look fine and can allow better access. Noggins or joist trimming may also be an option.
And I think there may be a small issue with the dust extraction...
If it is the case that you could buy the plot without needing to sell your place it would be a more compelling proposition. Is your offer subject to anything else (planning, easements, etc.)?
+1 I have used these and they work well. You do need a perimeter edge to retain the paving but that is the case whatever you do.
Fermacell vs backer board in bathroom
Mr Punter replied to divorcingjack's topic in Wall Tiles & Tiling
Fermacell is Gypsum based, like plasterboard. It is not as brittle as cement board. No special requirements for tiling as far as I know. You have done well if you have managed to line the whole place with Fermacell as it is heavy and difficult to cut and fix. -
Wheelchair access and patio (part M)
Mr Punter replied to iMCaan's topic in Landscaping, Decking & Patios
You should keep your patio level 150mm below DPC to avoid damp issues. Patio level with internal floor level is asking for trouble. -
Should builder correct bottle gulley mistake?
Mr Punter replied to flanagaj's topic in Waste & Sewerage
I think coring a hole and installing as per your drawing will be good. I have not seen these before but they look decent. -
Any less would be bouncy and not reassuring to walk on. Rafters would need to be 400 as well.
It will be fine if the rainwater connects into a combined drain. I don't know anyone who has ever changed the limestone chippings in the soakaway version.
Cavity closure timber frame
Mr Punter replied to Selfbuildsarah's topic in New House & Self Build Design
Cavity barriers and firestopping is often left to "others". They often get left out as nobody really knows what to specify or order or fit. Were they specified and detailed on the architects drawings? Rockwool would be a decent choice for non-vented and Envirograf for intumescent, vented rainscreen applications. I would want detailed spec and drawings, so nothing gets missed on your order or on site. -
Backer board or plasterboard
Mr Punter replied to Super_Paulie's topic in Bathrooms, Ensuites & Wetrooms
I really like the XPS backer boards. Lots of thicknesses, lightweight, easy to cut and fix, waterproof. Fix with adhesive foam or screws and washers. -
Can you clarify if you intend to extend the existing ground floor, also adding a basement under? Without a floor plan there is a limited amount anyone can suggest. I think that having a measured survey of the existing building and plot would be a good start. Have it include a section through the house / plot, neighbouring properties, front and rear elevations. Budget £1,200. Make sure you own the rights to use the plans.
Anyone have any ideas of rooflight / Part K situation?
Mr Punter replied to GEO-PAR's topic in Building Regulations
If the rooflights are toughened and laminated the requirement for balustrade may be reduced anyway. Don't forget access for cleaning with all that glass. -
Howdens are buying DIY Kitchens
Mr Punter replied to saveasteading's topic in Kitchen Units & Worktops
Well that is good to hear. My experience has been that they have been difficult to deal with, I could not get the online part to work. They often want to send out a salesperson but I had issues getting prices. I would like to use them, as they have a branch near me but they are not easy to do business with. -
A shame because I have found Howdens arseholes to deal with and have bought about a dozen from DIY kitchens. -
Noisy clicky corrugated metal roof- please help!
Mr Punter replied to jakeR's topic in Roofing, Tiling & Slating
If you have a 50mm layer of rockwool compressed under the sheets it helps a lot, but you would need to take the sheets off and refit. -
Electrical conduit for bringing armoured cable into house?
Mr Punter replied to flanagaj's topic in Electrics - Other
Where we are, if you don't have the right ducting the DNO (UKPN) won't run the cable. They will tell you what they need. Just re read and I see this is your side of the meter, so 100mm rigid duct will be OK. -
The bricks you have shown do not look standard size of 215 x 100 x 65 they look longer or not as high. There are quite a few foreign bricks non-standard sizes. The proper lime mortar looks good. I would be tempted to get local clay stock bricks as anything imported can have a fair lead time and delivery charges.
Agree with @BotusBuild. Aco drain will work well here. Hopefully there is somewhere you could connect it to at the end.
Tell them you can set the test up and they can come and witness it. I would not want to spend £400 just because someone is being a numpty. Part of what you pay for is inspections.
