Mr Punter
Insulation upstand when not having skirting board?
Mr Punter replied to flanagaj's topic in General Flooring
Well that is great news for your project. Although you may find siblings tricky, at least they know your foibles and are not such a PITA as contractors can be. -
So when you say all the openings are the same, do they all have a crack running down from the bottom left / right edge to the floor? Nothing at the top? Ground and first floor?
Nooooooooooooooooooo!
Mr Punter replied to Square Feet's topic in General Self Build & DIY Discussion
Won't they deliver to you? -
No someone has messed up. Using mesh internally would be unusual.
Bifold doors tend to suffer from the issues you have experienced. I am not keen on them. I have had bifolds in the past and would not again. Lift and slide is my preferred option.
Build has descended into a xxxx show
Mr Punter replied to flanagaj's topic in General Self Build & DIY Discussion
I agree. Far from a shitshow this is barely a skidmark. -
I have often had to reduce some wall heights or taken down sections built with wrong DPC. You should be able to reuse the Marmox, which is good considering the price! Ground bearing slab is nicer in the winter as you don't have freezing air circulating underneath. So is it MOT, gas membrane, concrete, insulation then screed or are they in a different order? Either way I can't see too many issues that can't be worked around. -
The circular columns are great.
They often set the levels with several small tripods and work to them. That way they don't need the laser level and staff/receiver while they are pouring.
Castle 10 checkmate 10 year warranty
Mr Punter replied to PSC88's topic in New House & Structural Warranties
Structural warranties are a bit strange, as the cover is often for 10 years with a one-off premium. Rebuild costs in 10 years could possibly double so it is difficult to judge what level you would need. -
Threshold details are a right pain. I guess he is concerned that there may be cracking between the different substrates. Who knows if he is right? I guess you either do as he asks if he is willing to take responsibility in the event of it being defective or you leave it as is and you take the responsibility. And maybe stop wearing stilettos around the house.
I think you need to increase the cover. Sadly it will probably significantly increase the premium.
Supporting a sink with two bowls (1.5) ?
Mr Punter replied to Spinny's topic in Kitchen & Household Appliances
A photo would be useful. Mostly sinks are supported all round, either by kitchen unit carcase or by worktop. -
Danum TLE roof tile disappointment
Mr Punter replied to Selfbuildsarah's topic in Roofing, Tiling & Slating
I see what you mean about the slight plum tinge but there is not much you can do about it now. Once you have fascia, gutters and external wall finishes installed and after a year of weathering I doubt you or anyone would notice. I had some dark grey Sandtoft 2020 clay tiles fitted on a project and was surprised that the grey colour was a coating rather than the natural clay colour. -
Yes, an error there. It would take a lot of paint to cover 1.5km2, as it is 1.5 million square metres and would take about 150,000 litres of paint to do a single coat.
Keep the windows and doors open during the day when it is warm and dry outside. If you have a dehumidifier, close doors and windows and run it at night.
Opening and stirring paint, moving hoses, cleaning up, moving sprayer, demasking. They were 3 x 3 storey houses. The spraying was less than 2 days. A lot of paint. They also had a roller that was fed paint by a hose that they used for rendered walls, so no faffing with a scuttle.
Spraying is quick but the prep can take ages. Also, any touching in looks bad and tape and fill jointing really shows up under some lighting. I had some houses sprayed and they had a team of 4 with 1 guy on the nozzle.
Yes I would fix a temporary timber to the face of the brickwork and cast a sand cement infill on top of the ali cill for the back of the first paver to rest on.
I am not sure of your setup but a raised tray can help if the fall is tight. They can look fine and can allow better access. Noggins or joist trimming may also be an option.
And I think there may be a small issue with the dust extraction...
If it is the case that you could buy the plot without needing to sell your place it would be a more compelling proposition. Is your offer subject to anything else (planning, easements, etc.)?
