Mr Punter
    27
  1. Wet mop and sweaty feet do not bring to mind ideal conditions. I think you may need to take up a section of flooring or make a hole somewhere inconspicuous to see what is going on.
  2. Are you fitting this yourself? You may need to have some components supplied loose. If the wall is already there you will need a fair amount of wood butchery. The winders look odd. I think there should be minimum 50mm going on the short ends, so #6 would not work.
  3. It would give a much better fixing if you could fix the counter battens through to the purlins. Unless you go through the t & g boards I don't think it will be strong enough.
  4. The £1.80 per hour was for a 7kW charger, based on standard tariff electric at 25p per kWh.
  5. With a home charger it will cost less than £1.80 per hour while it is plugged in, so £30 would be difficult to reach unless they turned up in a car with a 120kWh flat battery and hung around for 24 hours.
  6. The advice from @Russell griffiths was good. A labourer would be useful, but not if they don't know what they are doing. You may as well get them to mix (with a mixer) rather than have it delivered. Make sure is it just moist enough that it holds into a ball if you squeeze it, but not wet. You are best with a polythene layer on top of the Celotex. A laser level may be helpful. A long aluminium straight edge to screed with. Use kneepads. I wouldn't fancy doing this myself as I would be too knackered after the 2nd hour.
  7. If you want decent insulation the Dritherm 32 are the ones to use. In the great scheme of things will not make much difference. Have you priced the actual difference in £? 150 cavity is simple as it works with digger bucket for foundations, standard wide lintels and standard long wall ties and standard cavity closers. Quite why you would build in brick on the inner leaf I have no idea unless you want an exposed brick inside, which I would not recommend as it will cause big problems with services and airtightness.
  8. It used to be possible to use pir in EWI. Post Grenfell I imagine most of the certifications have been withdrawn. Get in touch with a render firm (weber or whoever) to see what they suggest. Could be tricky.
  9. No, push back on the gulley. There is no reg that says you need a gulley for a bin. For a single dwelling this is silly.
  10. Sadly the bricklayers will find it very hard to work with and detail. I have never seen this installed correctly. You would be better off using Dritherm 32 batts, which are far easier to install. You will get a much better actual result.
  11. The timber sleepers will rot out pretty quickly. Your tarmac looks fine. Go over the whole lot with 3 passes with a Wacker. Make sure the bedding layer is an even thickness.
  12. If this is a sink cutout it will With bot circular and jigsaw you will get a much better finish if you cut it from underneath as it will help stop the laminate being torn off the chipboard. The sink edge hides a multitude of sins. Seal the exposed chipboard with some decent wood glue.
  13. I hate plumbing. It is the cause of the vast majority of defects. I think we should bring back the outside WC. The hidden cistern is probably going to haunt me.
  14. Well I have no idea how you would change these in a full tiled bathroom! I have 6 at home.
  15. If they are too tight they will snag and you will lose edges, esp if you need to take a board down etc.
  16. I have rewired places years ago where the vertical drops were in conduit. It made it much simpler than chasing in. For horizontal it was under floor.
  17. I would use medium density blockwork. It is about 1400-1600kg/m3. Your marble will be about 2700kg/m3. With 2 layers of 20mm tiles and a bit of adhesive on 100mm blocks, you will be around 260kg/m2. If you did porcelain it could be 10mm. I would not want to tile onto aircrete blocks.
  18. It may be worth connecting a rocker pipe immediately the drainage pipes exit the raft.
  19. This is the way of things. Lots of back covering and padding. It is not in anyone's interest (apart from, maybe, yours) to get you to underinsure. Shop around as the likelihood of a successful claim for the full amount is probably vanishingly small.
  20. It looks very difficult to reconfigure. Round here they often add an extra floor, remove most internal wall etc when doing a bungalow. Have you looked around to see if there are other properties that would suit you?
  21. The insurance rebuild costs are often higher than the actual build costs. It may take account of demolishing existing and maybe removing foundations and services before starting again, with a generous allowance for fees, prelims, contingency, overheads and profit.
  22. This arrangement happens all the time in England. Conditional Contract or Option Agreement are the standard means. With a conditional contract, you exchange contracts at an agreed price subject to, in your case, obtaining planning consent for erection of a new dwelling etc. There will be other constraints to cover time allowed, appeals, fencing and boundaries, access, working times etc. Once the conditions have been met you are obliged to complete the purchase.
  23. Unless you have someone in mind to take on the second plot, just offer for the one you like best. Major hassle and risk once you step outside the self builder role.
  24. It only seems to add water to bagged mix. If it could properly mix the dry ingredients (gravel, sand, cement, admix etc.) it would be worthwhile, so you could make concrete, screed, render, mortar etc.
