Mr Punter
An extra layer of polythene is cheap and won't hurt but if you have taped carefully you should be fine but you are relying in the longevity of the tape.
2nd floor ICF install - chicken and egg
Mr Punter replied to BotusBuild's topic in General Construction Issues
Is this the dimpled stuff to allow water to flow under? How do you fix the studwork to it? -
Type C waterproofing can be a pain. Do the screed in 50mm concrete or sharp sand / cement and leave it exposed. If it can't stand getting wet it won't do well on the wet side of the waterproofing system, where they will flood test it upon commissioning. Are you actually building the structural studwork on top of the drainage membrane? -
Can anyone help me to design our foul waste system?
Mr Punter replied to Omnibuswoman's topic in Waste & Sewerage
You can often connect to the sewer pipe via a saddle on the top, subject to the pipe size. You do not have to connect via a manhole. So much better than a treatment plant. You should be able to get an asset plan from the water co and it will probably include the pipe material and diameter. -
Block and beam floor insulation with restrictive height
Mr Punter replied to DeanAlan's topic in Floor Structures
You may want to work out where the thinner stuff is going and build a 10mm step around the perimeter with levelling compound. Make sure it works with the sheet sizes. Bear in mind the beams tend to have an upward camber. Blocks are often only 95mm. -
Which ICF method should I use?
Mr Punter replied to Indy's topic in Insulated Concrete Formwork (ICF)
I have used Polarwall in the past for a basement. It seemed OK and they were good to deal with. I doubt I would use ICF again but never say never. -
You're on quite a steep slope with the tank below the house, so fine there. The drainage field size is done by calculation. The bit between the house and the tank is straightforward but you need to post up a floor plan. It would be best to have stack pipes on outside walls rather than the centre of the footprint. These are often internal, so the drainage is at the edge of the slab. Are you doing a separate system for rainwater? -
They use them a lots outside pubs and in industrial units.
Wind lifted membrane on loft extensiom
Mr Punter replied to Nocomp's topic in Roofing, Tiling & Slating
Contact your insurer. They will be able to advise what they need. If this is visible from inside, like a loft hatch, you could have a look and see if you can see daylight. -
Steelwork fire protection requirements
Mr Punter replied to AliG's topic in RSJs, Lintels & Steelwork
Typically rust bleeding through and the paint is soft and yellowing. Also for the paint to work you need to leave a space around it for it to expand. I hate the stuff. -
New build floorplans - opinions welcome
Mr Punter replied to Indy's topic in New House & Self Build Design
Deffo loads better than the basketweave brick / ashlar / mix. It looks more cohesive in the monochrome. I see the soffit depth is a fair bit deeper. Why is that? -
I have had the same row with an architect. I don't understand how a ceiling can be 1 hour fire resistant yet not suitable to protect a steel beam. BG were not much help and we reach an impasse where the architect specified intumescent paint and I will have a fight on site with the Building Inspector. -
Can you test it with a lighter or blow torch to see if it catches fire? Maybe try outside!
I think you need to treat this as a spec development. Don't overspend and overspec. Have you got a price from a builder to do the work on the current plans? If this is a 2 storey side, single storey rear extension plus loft conversion and dormers it will be very costly and take a long time. Not many purchasers will pay a premium if all they get is planning consent. It is quite difficult to add extra value to an existing house (in excess of build cost) by extending, unless it is a tiny house in an expensive area with room to extend.
Leave the old stuff it makes me itch just thinking about it. The newer Knauff insulation seems far nicer to work with.
How flush with the windows should internal PIR be placed?
Mr Punter replied to Thorfun's topic in Heat Insulation
Do it flush. Foam the window first. The weak point is where the frame and wall meet and if you cover some of that with insulation it will help reduce the cold bridge. Protect the frame with tape and cut and remove it after plastering / painting. -
I can only suggest making sure every tile is clipped and nailed but yours look like they are.
I think the 100mm stud would be OK. Can you make these up as timber framed panels and stand them up? You could even have OSB sheathing and breather paper on the outside to maintain the cavity.
Adhesive for bamboo flooring onto chipboard
Mr Punter replied to redtop's topic in Wood & Laminate Flooring
One that I did was 75mm Celotex, 22mm T&G chipboard and I think 16mm strand woven bamboo stuck down with silane adhesive. It felt very solid. -
I have found that bonding the floor gives a really solid finish. Whether it is £800 worth of solid is debatable. It also takes almost twice as long to fit. Maybe a thicker click fit floating floor with decent underlay would be just as good and less expense and ball ache. -
Wood Burner Installation Regulations
Mr Punter replied to patp's topic in Stoves, Fires & Fireplaces
From the Telegraph today: Domestic wood burning is the UK’s single largest source of PM2.5 air pollution, according to research – creating three times as much as road traffic, or 750 times more than an HGV. Analysis from Green Transition Denmark found that these tiny particles – emitted by eight per cent of the population, of whom almost half were affluent and chose a burner for aesthetic reasons – are small enough to enter the bloodstream and lodge themselves in organs. https://www.telegraph.co.uk/family/life/middle-england-getting-heated-wood-burners/ -
The version on the render gives a nice crisp horizontal break between the ceiling and tiled wall. Also, the column and left hand nib are set back from the section above and the ceiling into the alcove above the sink is level without a step. These small details can have quite an impact on the overall look but it is more than just tile / plaster and difficult to do now. I would be concerned about spending time and money ripping out the tiles and still not achieving the aesthetic in the render. The ceiling looks great btw.
Estate agent arranged for a surveyor
Mr Punter replied to Oceanjules's topic in Surveyors & Architects
They are acting as Managing Agents rather than Estate Agents. -
That is the brand in the picture.
Suspended ceiling at openings
Mr Punter replied to Pocster's topic in General Self Build & DIY Discussion
Remember losing this game to him yesterday?
