Fixing 10mm and 15mm feeds for kitchen sink
MikeSharp01 replied to markharro's topic in General Plumbing
Yep - try it with your eyes shut if you want a real balance challenge - I would have fallen over 5 times filling our kettle! -
Clean Heat Market Mechanism to incentivise heat pumps
MikeSharp01 replied to LnP's topic in Air Source Heat Pumps (ASHP)
If everything was IoT (Internet of Things) it could all be controlled by a remote system. It could even have look ahead capability to get ahead of the weather and be self tuning to the insulation / decrement delay. -
Christmas challenge: Faking a stove's radiative feel
MikeSharp01 replied to Sparrowhawk's topic in Boffin's Corner
You world need to surround the TV with radiant bars and reflectors then it would work provided you could stop the TV melting at the edges! -
The sunamp system has to be a winning idea, it's just it seems not to be implemented that well as it stands give this and other threads but still not fully put off.
Glue (probably a PU would be enough - it's pretty good in shear) would help as well but perhaps too late now.
I notice that they are offering a 10year Warranty on the heating element in their latest marketing material. Looks like the OSO is about half as good as the Sunamp in heat loss terms ( OSO (150 Litre): 1.2 kWh/24hr (source) and Sunamp 150 0.67 kWh/24hr (source) so if you charge it each day on night rates @ 20p/kWhr the OSO cost you 24p / day (£87.60 PA) while Sunamp costs you 13.5p / day (£48.91 PA) and in a passive house you get less unwanted warming and no plumber calling every year to check your system over and re-certify. Sounds like a good plan. Looks like element failure, even with 10 year warranty, is still a return to base, no heating (although you have two units so not so much a problem for you), challenge though - which sounds like poor design at the very least - why can it / they not be pocketed one wonders?
When it was working did it do what it says on the tin? If it did then you wonder why, in the forth manufacturing age, it cannot be built to last. We are still on track to get one but the more I read the less I like the idea.
Smoke problem from neighbours
MikeSharp01 replied to Savage87's topic in Mechanical Ventilation with Heat Recovery (MVHR)
That is around 50 times the WHO limit (5 µg/m³ since 2021) -
Yep that should do it as long as you don't have vast holes.
Not necessarily so... if you choose the same axis as the fan blade's rotational axis what are the implications?
But in which / what axis!
Rich beyond the dreams of avarice.
Right to light is not taken into account by planning IIRC. Just keep very good notes of everything as in the end it could end up at court where you neigbour can request compensation. If they have not allowed you to make appropriate measurement they will get less out of the judge one would hope.
Is the control algorithm not IP protected as you would need that to reliably control the phase changes along the flow pipe.
Very frustrating. We want to go Sunamp but I still worry about reliability. We will only have one so no redundancy - two seems like overkill and we would need to stack them and getting a block that heavy up on top of its sibbling is a problem.
Drilling joists and other supporting structure.
MikeSharp01 replied to andreas's topic in General Structural Issues
And avoid getting too close to the ends of the beam, as in stay several depths from the end EG 400mm plus if they are wooden joists the supplier will have a drilling chart you can use. -
Neither did they allow it for this build they discussed this at the end as you mention, bit of a dig by Kevin about the problem with the DNOs - so although they had the energy for export it could not be. The house does generate the 4 times but the DNO cannot take it away - ridiculous. I guess you need to find a way to keep stacking up 3 phase connections and all the standing charges that demands to make this work.
You perhaps need to work this out as the current in two resistors in parallel to see the full effects of doing this you don't want one cable carrying more than its capacity when the other has not reached its maximum.
Sounds like it will be fun.. having done a few already we guess you enjoy it. Keep us posted.
Classic systems problem - the tragedy of the commons!
