TheMitchells
    2
Everything posted by TheMitchells
  1. I am sure that I read somewhere that its very hard to make blown cellulose burn as it is so tightly packed in there is no oxygen to burn. And in the recent Build It awards, I saw a product which looks really good and may be worth considering; its Automist Smartscan which is like a sprinkler system but it is triggered by heat, rather than smoke, and the spray head swivels to where ever the heat is and targets the area with a powerful jet of water. The idea being that it only targets the danger area and the rest of the house is protected. It is ideal for open plan living and helps compliance with Building Regs.
  2. Here is Oxfordshire we get charged to take plasterboard to the tip. It seems to be £5 for a bootful and I pack it into rubble bags and save it up till I have a bootful. So far it has cost me £10 and the rest I break up and drop into the rubbish wheelie bin every other week. And once all the bins are out along the street I sometimes deposit a few bits in other bins that are not very full - naughty I know! we seem okay taking lots of cardboard to the tip so far and I always make a point of saying hello to the chaps there and being nice. Makes it harder for them to be nasty and charge me, I hope.
  3. I do love learning from others mistakes! Thanks 8Ball.
  4. Just to give an update; we have had a quote from another firm, which a friend used and recommended. They are a third cheaper than the first and were hapy for me to source the stove, have it delivered to them and then they will bring it to instal. which is a huge benefit as our access is awful and would have been difficult. We have given up on the idea of doing it ourselves as the regulations require it all to be certificed and finding someone to certify it after we did the work was proving difficult. And as it would have been the first time we'd have done it, we are happy to watch and learn this time. We have gone for a multifuel in the middle room and just leave the front room as an open fire. It already had an old Jetmaster Open fire which seemed in reasonable condition. but the fire chap advised us against it as it needed insulating which was not cheap(unless we used the Rockwool that we took out but I am not sure that was the correct insulating stuff for a fire surround. He siad to just take out the old Jetmaster and instal a basket. After I clarified that he did mean a FIRE basket and not a floral arrngement (I wasnt sure!! so had to ask), I was straight onto Ebay and got a nice one for £40 and we hope to sell the Jetmaster for about the same. However, the next problem was the state of the walls within the fire itself, once the Jetmaster had been removed. There were holes galore in the brickwork and looked like stones had just been shoved in, higglety pigglety. I had some cement left over so today started filling in some of the larger holes with the intention of finishing off soon. But just thought I'd check; does PeterW's comment still stand? Should I be using lime and sand, rather than my normal cement mix? I intend to make it sound and smooth the walls and sit the fire basket inside. A friend has given me sone wood logs so i cant wait to try it. Luckily the weather hasnt been too cold but it will soon be getting very cold in the house and a fire would be wonderful. This is after I had filled in some of the worst holes. The dark grey stuff is my work. My bargain purchase.
  5. Thanks for all that - makes a little more sense - hadnt realised the metal things were called straps. Waiting for the builder to return to do the chimney pointing now. then its all inside work.
  6. Not sure I understand all that but will take your suggestion re the noggins. thanks.
  7. On our renovation project roof, the surveyor had pointed out that the top of the gable wall was bowing out and was not tied to any of the rafters in the attic, and this would need sorting before it all fell off. Also, there was no or little overhang so we were worried about the wall getting damp, which may explain why some of the bedroom wall plaster was loose and needed removing. A couple of the ridge tiles were loose and there was a slate missing near the ridge line. So we got our builder to come and sort it out. I'm not good with heights and we didnt really know exactly what needed doing, although now its done, it seems quite straightforward. By the end of the first day, the render at the top of the gable had been removed so we could see the area that was bowed out. We were all a bit suprised to find that the actual wall was quite sound. we thought it would be fairly loose and unstable but it wasnt and the render was sound too. So the decision was made to only remove the top 18'' which is the main part bowed out. The cracked render would be opened up, re-rendered and I will paint the whole wall, once everything is complete. The edge of the roof was exposed and the tiles were removed along the edge. The battens and felt seem okay apart from the very ends. When we investigated in the attic, we found that the double brick gable wall only went as far up as the top of the bedroom walls, then it continued as a single brick wall. There were two brick pillars which supported the two beams that support the roof, at knee height. (Purlins??) So it was suggested that we get another pillar built up in the centre which would support the top of the gable wall and help stop it bowing. And we need to tie the wall to the rafters. An unusual view of the inside of our attic. You can see the pile of cement blocks with which the builder will build a pillar in the centre on the wall, to tie it into the outside brick wall. And he brought 4 metal ties which will tie the wall to the rafters to ensure it does not bow out again. Day 2 - the gable wall has been rebuilt. the pillar in the attic has been built and metal ties added in four places. I think it looks really good - but then, I am no expert - so I would appreciate any comments from more experienced persons. Has he done a good job?? By the time I arrived on the morning of day 3, the new slates were being fitted. When I got back to the house by mid afternoon, it was all done. the slates look super and the ridge tiles have been fixed in place. I am a very happy bunny! And this is the pillar in the attic which is tied through to the outer wall. So my question is - has he done the correct things? I think it looks great.
  8. Ha-ha - I wish I knew what you were talking about - sounds fascinating! good luck
  9. In our renovation property, we have been having problems with damp in the cellar (who doesnt!). One corner was particularly wet with droplets of water on the Rockwool (I think) insulation shoved between the joists of the lounge floor. We have removed the insulation and increased ventilation of the cellar and plan to fit another airbrick in this corner. The back corner has one and isnt damp at all. Then as part of the renovation, we are either going to replace the joists as most of the ends are rotting where they sit on the external wall. The Structural engineer suggested that we could just cut off the ends and attach new lengths, which will sit on new engineering bricks on dpm on the external wall. Hopefully that will prevent any dampness in the new joists. My question is how to insulate the floor so the lounge is not subjected to draughts from below. I am loath to re-install the Rockwool as I am sure that was causing some of the problems. But we need some sort of insulation. Is there another good insulator that isnt going to cost the earth to pack between the joints or should we look at laying insulation above the joists with the problem than of raising the floor level. This may not be too much of an issue as we have to re-do the floor in the whole house anyway.
  10. yes, the first blog post gives all the details.
  11. Tuesday was the date given and, yippee, he turned up and got started. By the end of day, the render at the top of the gable had been removed so we could see the area that was bowed out. We were all a bit suprised to find that the actual wall was quite sound. we thought it would be fairly loose but it wasnt and the render was sound too. So the decision was made to only remove the top 18'' which is the main part bowed out. The cracked render would be opened up, re-rendered and I will paint the whole wall, once everything is complete. The edge of the roof was exposed and the tiles were removed along the edge. The battens and felt seem okay apart from the very ends. The first three ridge tiles are loose and will need fixing. this is an unusual view of the inside of our attic - we'll not see this again after tomorrow. You can see the pile of cement blocks with which he will build a pillar in the centre on the wall, to tie it into the outside brick wall. And there are 4 metal ties which will tie the wall to the rafters to ensure it does not bow out again. Day 2 - the gable wall has been rebuilt. the pillar in the attic has been built and metal ties added in four places. I think it looks really good - but then, I am no expert - any comments welcomed from more experienced persons. By the time I arrived this morning, (day 3), the new slates were being fitted. When I got back to the house by mid afternoon, it was all done. the slates look super and the ridge tiles have been fixed in place. I am a very happy bunny! And this is the pillar in the attic. Although the garden/patio area now needs some tlc
  12. Well another month has passed and the OH is now only 2 months away from retiring. He can't wait to get cracking on the house full time - no rest for the wicked. We have been doing various things, fitting in with our usual work but nothing major; we are waiting for the builder to arrive to start the outside work. the scaffolding has been up for 2 weeks and the builder should have been there at the beginning of the month but its nearly the end of Sept and no sign yet. I have been chasing him up and he promises to be there tomorrow...... We want him to repair the top of the gable wall and add an internal pillar in the attic to support the single brick wall, repair the render and check the overhang of the roof, which isnt too good. As well as repoint the chimney breast. The great thing of having the scaffolding is that we can get a better look at what needs doing. There is one point where we can see the wooden battens, there is a gap of about 2 inches at the worst place. the end ridge tile is completely loose and the next two look like they'll be loose too. there is quite a lot to check but hopefully not too much unexpected. On a completely different subject, its great fun looking at all the other properties around. I did get told off for pointing at a neighbours garden. There was no one looking! So - updates on the cellar dampness. Having spoken to several of the neighbours it seems that the area does have a high water table. Most of our neighbours and the local Waitrose, 300yds away, regularly has a flooded basement and so I am not worrying so much as before. Also, we realised that the front porch guttering was emptying into a water butt but the butt has no overflow and as it was damaged/cracked halfway up, it just overflowed onto the patio area, directly above the corner which was damp. I have now installed a new water butt and am keeping an eye on it to make sure it doesnt overflow. But this is just a temporary solution until we can find a long term way of taking the water away - there isnt a drain anywhere handy so it needs sorting long term. In the cellar itself, we have removed all the Rockwool insulation that had been stuffed between all the beams, beneath the lounge cellar. The Rockwool was soaking wet in places and of course the beams and flooring above it was also damp. A hygrometer I bought showed the humidity at 99% and there was mould forming all over that front corner of the cellar. To help dry it out, we need to add an airbrick at the front corner - it has one at the back corner but not at the front. in the meantime, the OH installed a fan which is moving the air around and since then, the humidity has dropped to 93% with a definite difference in the feel of the place. The moulds have disappeared and it has lost its damp smell. Obviously there is still damp there, but its a lot less than before. We shall see how it changes once the winter rains start. One question I now have is with regards the removed insulation. we oviously need insulation between the cellar and the lounge above. We dont want to replace the Rockwool as I am sure it was adding to the problem. So we need to find a different method - I shall ask on the forum for suggestions. Maybe wood fibre board to replace the lounge boards?? Or a better insulation between the beams?? I need to research this. In several blog posts, I have mentioned the dilemma of the bathroom location. However, the dilemma is no more - its staying where it is. We have tried it in all sorts of places but for various reasons, it just didnt work anywhere. And after an Estate Agent came round, we are reasonably happy to leave it on the ground floor, next to the middle room. He was not too concerned and said that while families would rather have a bathroom upstairs, it was less of a problem for young couples, which is likely to be our target market. However, that then created a problem in that the middle room is quite dark and small and it does not work with the small kitchen. The obvious solution is to remove the large pillar and wall between the two rooms. But as it holds up the whole of the thick rubble back wall of the house, its not an easy undertaking. So as well as maybe removing the pillar to open up the kitchen and middle room, creating larger, more usable space, we plan to add a sunpipe to the top of the stairs and then open up the stairs into the middle room. That way, there will be loads of light coming into the centre of the house which we hope will add to the sellability. It didnt take the OH long to open up the stairs. and it looks great. The uprights look like some branches that have been cut to length and stuck in. They have all the marks of the lathes s well as bark and I love them. It would be great to clean them up and leave them, but the OH thinks I am mad and says 'No'. I'll work on him Watch this space..... As well as giving more light, opening up the stairs means we can remove the bottom most upright (to the right out of sight in the above photo) which will help enormously in moving furniture in and out of the room. And it feels really nice, coming from the lounge and seeing the room open up. Hopefully it will not be too cold and cause draughts once the house is finished. One of things that amazes me about this house is the fact that it is still standing. Almost everytime I remove some plaster, I find holes - lots of them. And loose bricks/rubble. This is the top of that pillar between the kitchen and dining room - the one holding up the whole back wall of the house. There are bits of wood, gaps, loose bricks! And below is the upstairs front bedroom window. I assume someone changed the size of the window and bricked it up - but why didnt they brick it up both sides, rather than just the outside?? There are lots of places where i think I may have to add some mortar, just to ensure the walls are stabilised before we do anything else. I have looked into doing a Lime course but realisticlly it will probably be cement mortar. Today we had a visit from a local structural engineer. We want details of the beam needed to hold up the back wall, if we remove the pillar as well as confirmation of the beam sizes to replace those under the lounge. Our builder has used him before and his price for a visit and report was reasonable compared to others I contacted. (£260 plus vat). At least he turned up which is more than our builder has done... Anyway, he had a look round and suggested that we use three beams side by side to minimise their size (its a very wide wall), cutting the ceiling beams that hold up the bedroom floor, and refixing them to the new beams with joist hangers. That would keep the height between the two rooms. I had not thought of doing it that way but then I havent done this before, so we are learning, which was the idea. Then he had a look at the cellar. He said that he'd leave the beams in place. he agreed with our 'expert' brother in law, to remove some of the wall under each beam end, and fix in place an engineering brick with a piece of dpm on top to keep the beams dry. but he then said rather than replace all the beams, just check each one and if needed, cut off the end, then add/bolt on extensions either side which will sit on the new dpm. Again, not something we had thought of doing. He will provide details of new beams, in case we want to do that. But he doesnt think we need to. We will have a chat with our builder to get his opinion then probably decide once we see how bad they are. I am hoping that as the cellar is drier and we have removed the Rockwool, the beams are not getting worse. However, the SE did not have any suggestions for what to use in the place of the Rockwool. Maybe we need to leave the beams bare to breathe and stay dry and think about adding the insulation to the top of the beams, replacing the boards in the lounge. We intend to eventually lay bamboo flooring throughout the whole downstairs so maybe we can consider that. The last thing to report is that we now have a 2 bedrromed house instead of the 3 bedroomed that we bought. We had great fun the other weekend, removing the stud walls from between the front two bedrooms. Both were too small to be of any real use and openign them up has created a lovely large room. The estate agent agreed that two large bedrooms was a better idea for this house - it will not be bought by a family that needs the extra bedroom and if whoever buys the place really needs it, they can always put the stud wall back again. And having two large bedrooms has helped convince the OH that we should add insulation to the inside of the external walls to help create a much warmer home. He was concerned that the additional thickness would have made small rooms even smaller but as they are larger, loosing a little of the space is not likely to be noticed at all. And I have costed up the additional costs to be around £4-500. I realise that we may not get that back when we come to sell but hopefully the EPC report will show the benefits and I will feel happier knowing we did something to help keep the new occupants warmer. I know - I should not be doing anything that does not give twice the value back. But it is the right thing to do - even if it does cost us more. Oh, and we have had a new boiler fitted so hot water again in the kitchen. It allowed us to finally get rid of the boiler from the upstairs bedroom which was really nice. The new boiler is in the kitchen in the alcove, the other side of the bathroom wall, which was perfect for taking the pipes into the bathroom and straight down into the cellar, ready for the plumbing when we get to that. Well, I think thats all the news to date. Hopefully the next post will have pictures of our nice, new gable wall!! Keep you fingers crossed that the builder actually turns up tomorrow and gets started. I keep telling myself that there's no rush but the weather is changing and it would be nice to get the roof and gable wall done while its still quite dry. Patience, Mrs Mitchell!!
  13. Okay- what am I supposed to be looking at here? What is the schoolboy error? Help please for a total plumbing novice.
  14. I think so as a first time self builder, with no experience of dealing with contractors and builders. Obviously some of the stuff will be out of date with regards health and Safety but I tink the rest should be fine. Cant you borrow it from the library first to have a look?
  15. Wall width is about 350mm from what I remember and they use some sort of bead insulation system which gets pumped into the timber frames. I cant remember what it is made of but its some sort of by product of the petrochemical industry iirc as I would like to use cellulose/warmcell but the chap claims theirs is better. I have a little which I can post to you, if you PM me your address. But the impression I get is that they can make it to suit you so should be worth investigating. Good luck.
  16. Another company worth trying is Beattie Passive. They have a system which can be added to any building. We went to see one where they extended above a garage with their system and I cant see thats much different to yours. They do a T Cozy which they drop over the top of the existing house to make it as energy efficient as possible and usually you dont even have to move out. www.beattiepassive.com
  17. Its really amazing how much some of these national companies charge and lots of poor unsuspecting customers think they are getting a good deal. We had a quote for about £5k to replace all our windows and patio doors. My friend was just about to get hers done - identical house - by Anglian for £11k. Luckily I told her about my company (distinguished Windows - excellent and highly recommended) and she changed over, saving her £6000. The owner said the worst he had experienced was a house that Everest quoted over £50k and he only charged them £11,000. And I cant see any difference in the quality.
  18. I think you could go into production! looks really good.
  19. Hmm - its certainly an area where we need help. My father is having nightmares involving lots of house walls falling down! And we are only just talking about it......
  20. is it going to have legs?? Are those holes for the beers? to stop them falling off the table? Looking forward to seeing it finished
  21. yes, I did consider using a camera for the drains. Not sure how much they cost but will look into it. The current thinking is that it will be far easier to leave the bathroom where it is and have two large bedrooms upstairs. But that leaves us with a dark small middle room. One way of improving the middle room (and adding a little wow factor into the resale value) is to remove the 18inch thick stone wall/pillar between the room and the kitchen which will give a larger single room kitchen diner. The issue is the thick rubble stone wall thats above the wall/pillar. We will need some help on deciding whether that worth doing and if it is, how we go about doing it without the whole back wall of the house falling in! This is the only shot I have of the pillar (taken before the previous owners moved their things out) - its the bit with the clock on it. The open doorway used to be a window and was made into a door sometime ago. So there is some sort of lintel above it anyway. where the coats are is only one brick thick and to the right of that is the wall between our house and next door but it does not look strong enough to take the weight of a large lintel/rsj. so I am thinking that we will need to build a brick pillar on the right of the coat store. But how do we support the weight of the back upstairs wall, while putting in a lintel. I think that will need an experienced builder and structural surveyor to get right. More to think about. Good job we are not in a hurry to do this job - it gives us time to change our minds! To clarify - the small kitchen is a single storey extension so that wall with the clock and coats is the main back wall fo the house and is very think rubble stones. In the meantime, I may get those coat hangers out and see if I can find the drains. Got to be worth a try.
  22. They gave me an account and I'm not in the trade. though I think I said I was and I had to show an invoice from an account for TP which I have, that seemed enough. I have used them for a couple of kitchens and each time, they have to resurect the account as it drops off the system after a year without use.
  23. Please do start the threat re diy DPC in solid walls - may be of use to me.
  24. Sounds about right - you obviously have met my husband!
