Nickfromwales
    345
  1. Oh, and +1 on a back to wall wc .
  2. What's the vertical drop between the wc outlet and the bend in the soil run ( to horizontal ) ?
  3. Your timing is terrible, that's all
  4. Personally I'd want the timer so I could specifically dictate when the events were. Have you considered remote PIR's so you can aim them accordingly ? That would avoid unwanted / nuisance triggers.
  5. Sika do a system for exactly that Demo here
  6. Rotund plumbers?
  7. Your on your own here mate
  8. The convenience needs to be a two way street. If there's an excess tax accrued via the arrangement then it would have to be at least a 50/50 split IMO. It's just down to how much you want to get 'out' of the old house and into the new one tbh. Cant say I've ever heard of such an agreement / arrangement, but I've often thought about it.
  9. What about slender Americans?
  10. Seems quite easy to source One example
  11. I'll reply later . In a 'high power' business meeting at the mo ??
  12. Download the MI's for the boiler you wish to fit, and the specs / stats should all be in there
  13. The mesh reinforces the slab, adding immensely to the integrity for one. I'd not even think about not fitting it tbh as it's cheap as chips and gives you a grid to attach the pipes to. Has your engineer / BCO specified no re-bar ( mesh ) ? I'd have thought it would be a given.
  14. Dont kick a man when he's down eh?
  15. I was welling up reading that. I feel your pain. I still won't sell or give away my first Dewalt combi drill which went around the world with me for 5 & 1/2 years.......and STILL bloody works ! It'll stay up the attic until I get buried with it. At least you 'other child' is only 15 mins away, so you can visit whenever you like. Couldn't you have arranged custody ? Every other weekend or something ?!?
  16. Intergas gets a good mention here, but as I've stated here, and on EB, I'm a Baxi or Vaillant man myself. I've been around boilers for over 20 years and have based my findings around breakdowns / failures, longevity, dhw production and price. Viessmann are over priced IMHO, and likewise for WB. They both survive off their pedigree and following IMO, with WB being just synonymous with British Gas. Vaillant are very robust, well built and reliable machines, which seem to be free from any early / mid term failures. Baxi are my instant second choice below them, should budget be a constraint. The Baxis are a little cheaper but are also very, very reliable too and have equally good dhw flow rates. The vaillant 938 ERP is a heat-store combi with the equivalent dhw output of a small UVC. They're incredibly good at supplying hot water and don't suffer any delay in producing dhw, as regular combis do. If you want to be able to shower whilst other hot / cold outlets are used elsewhere in the house then this is the one to have
  17. Self build meets CSI Miami
  18. I disagree with your plumbers. The buffer will do little when the house needs heating from cold, but when the house is up to temperature, and that heat is being maintained, it will become quite important indeed. If your boiler is left to short cycle, which there are no measures to mitigate afaik ( and the whole reason a buffer is implemented ), then it will also drop below the point where ideal condensing temperature is achieved, thus reducing the boiler efficiency accordingly. If a buffer is used, preferably in the airing cupboard so it kills two birds with one stone, then it can be fitted with a cylinder stat which will dictate the temp that the buffer gets maintained at. The hysteresis of the cyl stat will allow you to pulse heat from the boiler, at it's user defined flow temp, therefore allowing you to set that cycle to happen at the optimum temp for maximum condensing efficiency to be achieved. Its not a good idea to run Ufh directly off a combi boiler unless you intend to implement a heat loss circuit, such as paralleling the towel rads to heat in unison, as a form of passive buffer. If you have any reasonable dhw demand then I'd consider a heat store combi tbh, and look twice at the claims from WB about the dhw rates! Their own website had my last 'Worcester insistent' customer cross-examining me as the 30kw combi clearly stated that it was typically suited for a flat or small 1 bedroom house . When I stated that a baxi 28kw gave excellent dhw flow rates, so a 30kw equivalent should be an improvement, said customer made me look at the wording for myself. Barking mad. I'm a Baxi or Vaillant man myself, and don't personally rate the WB boilers.
  19. You're right, apologies. It's open flue that's dependant on adventitious air from within the dwelling Balanced will rely upon the seals of the combustion / burner chamber for air tightness but should be ok for PH as its not allowed to leak products of combustion into the dwelling aka air / gas tight. Most system boilers would be RS tbh, so choosing well should mitigate most of the concern. The issue of the air tightness of the penetration for the flue, from inside to out, still remains the key to keeping the house 'sealed'.
  20. FYI balanced flue appliances draw air from the room and use convection or fans to blow the fumes out to atmosphere.
  21. A new boiler will be called an RS ( room sealed ) appliance, unless you choose a balanced flue which I presume you wouldn't want. The combustion chamber, air in / fumes out ) is all entirely sealed to the outside atmosphere via the coaxial flue. Airtightness will only be compromised by making the penetration for the flue. I'll post some pics of the last MBC build where I had the same thing to do.
  22. Just ordered this one from eBay which arrived today. Was going with your one until I saw it had a longer lead time from the land of the bratwurst . If you turn the pressure down then the small vessel should suffice, but I'm pumping into a 200 ltr acc on my job from break tanks. Maybe an idea to fit some flow restrictors in the bog inlets to reduce the flow velocity a bit.
