If i put the main light on in the living room I get things chucked at me. Table and wall for us ( her ).
PVC is cheap enough tbh, and if this is in sight I'd rather it looked consistent if it were me .
To suck or blow - that is the question
Nickfromwales replied to PeterW's topic in Rainwater, Guttering & SuDS
Are you using a medium sized accumulator as a buffer? Much better than pumping direct as the pressure / flow switch will be quite coarse on its own? I'd deffo avoid the submersible and pump from upstream. Easier to clean / maintain and less crud to reduce longevity. Its 'suck' for me -
lol. Bodrer adhesive for me. Ps @TerryE, have you discovered asbestos in your new build or is that a fashion statement ?
There would be a significant 'shoulder' if you used that upside down. Its a no I'm afraid . I genuine can't think of a job ive ever done like this, without using a sleeve.
It'll go into cast and leave PVC out the top, but I'm not sure of it'll do the other combination. Why are you going back to cast? Just renew the vent in PVC ?
Why HVDC for the inter-country interconnect cables?
Nickfromwales replied to readiescards's topic in Electrics - Other
Set of jump leads, a bit of digging, and violá......off grid with as much free juice as you want . -
Just bin those and buy some standard flexis ?
The Soudal family of products is good quality and I use them regularly, mostly the L/E foam. We are all complicated, strange creatures of our own reasoning. ?
I don't use white CT1 for ANYTHING. It goes near custard yellow. I will only, and reluctantly, use colour matched silicones to give a job the cherry on the cake IF I can't do the cosmetic / final sealing with a clear bead of CT1. This siliconing is done over a fundamental seal and accepted as 'sacrificial' sealing for aesthetics only. That can be quickly and easily removed and replaced as the silicone gets tired / grotty. The reason for the mix of makes is that I've not actually seen a clear Sikaflex tbh ( and haven't really looked for one either, for whatever reason ). Also, comparing the two, I maintain that Sikaflex is unrivalled for use as an adhesive, complimented with excellent 'sealing' properties, and stays white. You could quite easily tool and finish white Sikaflex and have it as the final product on display, but definitely not so with white CT1. Fwiw, the colured CT1's seem fine and maintain their colour so a shame the white goes 'off'. Hold the press....Bingo I'll get some and give it a whirl.
£300 doesn't sound too bad tbh, once you factor in all the grief you'll be avoiding trying not to fit one Simple, straightforward, looks the nuts and is a 10 minute fit. Get your wallet out me thinks
Tough guy eh?
I have to do exactly the same thing next week......Tap washers gave up the ghost so the carcase got soaked over time and it all swelled up so I have to remove and refit the sink and renew the cabinet. Not looking forward to it tbh, and it's a riven, ceramic tile I'm going to cut the unit into firewood and remove one bonded side at a time. I hope the tiles stay on the wall !
I'll read that later if the Coors Light don't blur the words too much. Work in the morning so only a 6-pack ?
I did.....up to the point I was sweating, effing and jeffing, and looking like a cheerleader. Cant be done. End of. Anybody know what I'm on about? And split one ? Just me then ?
Panel all 3 vertical walls. If you have an 1100 tray then an 1100 wall panel will have very little meat left for screwing / fixing the chrome wall channel ( for the glass ) to. I don't like the idea of water ever getting to a painted plastered wall. At the very least I'd want an Upstand of similar material for the tray / wall junction.
I'd buy 1100 or 1200mm wall panels for each end and make a splash proof area, in the interest of longevity. I don't like to see the cubicle finishing tight on the edge but that's just me.
Neither are silicones. These are marketed as combined sealant, adhesive, gap filling goop. Sikalfex is extraordinarily good stuff IMO and is my weapon of choice for setting in and fundamentally sealing shower trays / formers and bonding baths etc into place. The merchants often have a 'sample' box with two pieces of wood bonded together with a ~6mm bead of sikaflex and the challenge is to get the two apart. It can't be done, I've tried twisting and tearing it and it just doesn't die. CT1 is pretty much as good but can be torn / pulled apart. I use the clear one for sealing between trays and tiles as it doesn't degrade, go mouldy or fail like clear silicone does. For 'chemicular dissection', don't ask me .
My floating home, More 4 Thursday's
Nickfromwales replied to ProDave's topic in Property TV Programmes
