Run it through a proper analysis first, and then ascertain the level of any 'issue' you actually NEED to address. Consider maybe just the south and leave the east / vice-versa whichever works in your ( the dwellings ) favour. I would certainly look again at external blinds on the south so as not to cut off your nose during winter, as you're only going to be using the blinds a couple of months of the year in all likelihood. If this was full on passive it would be a very different story, but this property will need all the help it can get in the winter time, especially with the added decrement delay after you add the EWI.
Is the existing concrete base the correct size for your new office? If so simply lay a course of thermalite block around the perimeter, cutting them at around 70mm thick as a thermal break. Bed these down in 15-20mm of cement and tap down accordingly to get a nice straight ( flat and level ) top edge using the cement taking up any undulation. Use that then as an insulated footer for the stud walls with the thermalite blocks providing at least some thermal break. Then you can blind the remaining slab surface with sharp sand and lay 50mm or 75mm of EPS ( polystyrene ) insulation directly onto the slab. Put two layers of 18mm OSB3 atop the insulation, with the second layer perpendicular to the first and you'll then have a nice start point to get the stud frame walls up and have a pretty decent separation from the cold of mother earth. DPM goes over the thermalite and the EPS to make the damp barrier, so try to match that level as best you can by deciding on the thickness of insulation you desire and then cutting the thermalite blocks to suit. Leave the DPM overhang the thermalite by a good 150mm and then clad over it when sheathing the outside walls with your chosen rain barrier to keep it down-turned over the thermalite ( as that will attempt to bridge damp up / outward so cannot touch anything porous ). I've done a few 'garage conversions' with this method, and the double layer of OSB ( tongue and groove 2400x600mm sheets ) over the loose insulation feels rock solid underfoot. You will deffo need to blind the slab with sharp sand first ( after laying the perimeter blocks ) and get that nice and uniform for this to have little / no 'wobble' possible. Invest some time there as it'll pay dividends later on 3x2" timber at 400mm centres vertically for stud walls, with 25mm EPS across the whole of the internal walls and then screw 11mm OSB3 through the EPS and into the studs for final internal finish. Looks fine when painted, but you could plasterboard if you need a 'posh' finish. Monopitch roof is a doddle, and again, just timber for simplicity. Make the walls all level and fit some furring pieces on top to create a downward slope, from front to back, so the guttering is at the rear. 6x2 pearlings at 600mm centres atop the furring pieces, from left to right as you look at the front, and 18mm OSB3 atop the pearlings and whatever you want on top of that ( EDPM / felt / GRP etc ) but beware metal sheets as I found the rain made it nigh on impossible to have a conversation when it was lashing down. Solution will be; acoustic insulation and SB plasterboard most prob, but will be a job for a rainy day Depending upon your choice of roof material you can just get away with insulating the roof void with cheap attic roll in the depth of the 6x2"s and covering with green plasterboard.
Do you have the specs of the gate motors? They usually are geared and not that 'power hungry', so you may be able to glean power from an utility ring and then just a matter of drilling through the outside wall where there is power available back to back. Do you have any largely unused circuits? For eg, a cooker circuit with a 32a or 40a supply that is just servicing a hob igniter? Redundant shower supply etc where you've changed to a mixer shower / or as said, a garage with a dedicated feed which you can tap off? As far as lighting goes they will use very little and can be piggy backed off the gate supply. You could also use Quinetic wireless ( and battery-free ) technology to have switches in the house which bring these on and off. You can also put a switch in the car even, loose in the glove box, and use it to bring the lights on for welcome / approach illumination. These things are ridiculously good for wireless switching and still amaze me as to how far and how diverse an installation they will still work, reliably, in. You can also add PIR sensors, laid over these wireless switching circuits, for security / approach illumination for when you're not home. Upload some details and add the information requested earlier and we can work out just how much power they need, and where you can get it from. Also consider the future purchase of an EV, if you do end up running cables through the house, as that would be a good time to get a second cable ( or one very beefy one ) out for a car charger. If you do end up having to get power from the fuse-board ( aka CU ( Consumer Unit )) the easiest route is usually up from the CU, into the first floor ceiling void, and out to the appropriate external wall. A run of black or white conduit, down from a 'terminal box' fitted where you drill out, to ground level is normal practice. If you can get through the downstairs then even better.
And some good points here, Also feel free to ask the admins here for blog rights and you can also use that if it helps.
Hi Chris. Jump in and hijack this thread. And welcome. And
Just fit 40a or even 60a relays, simple. >Twice the CCC of the stock offering and much, much higher longevity. That's what I have had to do to 'load shift' SA's in the past on dual-fuel installs, fitting relays outside in project boxes and got my spark to fit the highest rating we could get hold of in a single module ( as it was a couple of tenners uplift for a lot of sleep ). On a previous SA install with their bespoke 'load shifting' controller, there was a time-clock inside the OEM equipment which made a lot of sense ( so the system only regenerated during the 3 x E10/24hr windows ). Options for that on the HW+I or eDuals would be handy as the electricity grid is becoming quite attractive for recharging, or at least topping up, even when gas is the primary fuel.
Oil spill decontamination.
Nickfromwales replied to ProDave's topic in General Self Build & DIY Discussion
Wonder why there isn't something out there to emulsify it. -
I've used 225x25mm a few times in passive builds where there has only been the 35mm service batten depth to play with. 300x25mm is also available if the runs are excessively long, but I know the dynamics for airflow aren't favourable with rectangular vs round so you'd need to do some checks for airflow vs distance inc deductions for bends etc. These guys do the fittings so assume the duct too? I am super-sceptical about retro-fitting MVHR into refurbishments though, at least anything worse than EnerFit standard refurbs, and would warn against it if you cannot get the 'air-tightness' addressed properly ( consistently ) according to the systems minimum requirements.
Dec caulk will be fine if it's not in direct rainfall. If you use silicone you wont be able to use any water-based products thereafter. Prob best to paint it all up and look at whats left. If necessary, then choose a product to fill with, probably frame sealant would be best at that stage and is over-paintable when you tart it up next..
The treads are actually wood-effect walk on glazing.....who'd have thought !!!!
"Dead man walking" ?
Ok. If it's directly on top of an insulated solid concrete slab, like 150mm of it, it will still work. I know, because I have done it ( back in the day when I was wet behind the ears, and the customer was 'always right' and it wasn't worth arguing...). That system is still in and working to this day, and is the only heat source for the ground floor. Is it efficient? No. Is it economical to run? I very much doubt it. Does it take a long time to heat up? Yes, but it also takes a long time to cool down so not the end of the world when you get used to its traits. The overlay systems work. they're just expensive for what they are. Your solution will certainly achieve what you are looking, for just on this forum we are all advocates of "fabric first" approach and advise as best we can to reduce heating needs vs increase the number of rads etc. So, that's where the resistance is coming from. So, if you have 60mm - 30mm PIR - 30mm of UFH pipes buried in liquid screed, what is going on top? I would seriously recommend a bonded engineered wooden floor or tiles as that will add to the thermal inertia and help with the way heat is injected into the floor and emitted into the room. My observations are that you are OK to accept some compromise here on running costs, as you don't envisage using it all year round to heat the room, and nor will it be the primary heat source ( at least until you see how the UFH performs without the rads ), so if you are asking id this approach will do WHAT YOU ASK FOR then the answer is 100% yes. You will feel the difference for sure, and the fact that you'll have a mix of rads and UFH on the same ground floor will help with any short cycling issues from the boiler. Don't ever dream of running this UFH on it's own as your boiler will hate you for it. FWIW I would use 12mm pipe here and run it at 100mm centres. That will give more volume for screed and greater total pipe surface area to conduct heat. You'll likely need 2 or 3 loops to make up the one 'zone' to ensure equal temperatures throughout the floor, so as to effectively offset how quickly the heat will dissipate from the smaller pipe. Bottom line is, it will work.
I used garage floor paint. Hard wearing and just nice to look at ( grey not terracotta )and cheap as chips. Also, it should act like a bit of a vapour barrier too. Moot most likely, but made sense to me and my small grey nodule. Takes a LONG time to dry so put on in lots of thin layers.
Stair porn at it's finest. We all salute you sir.
Stunning.....
Infrared heaters for a garage refurbishment?
Nickfromwales replied to howplum's topic in Other Heating Systems
The fan heaters I bought have a switch on the underside. If they tip over they cut out. Safety first, so if you’re working on cars you need to keep the fan heaters well away from the stuff that makes them go ! Also, if draught-proofing, you must watch for the accumulation of fumes. -
Are you saying that you’ve looked at the UVC history over the last 20 years? I can tell you now, that isn’t a history that reads exceptionally well so I’d look at this afresh to be fair. Last terminally ill UVC I went to was in a £1m+ property and the results were devastating. This was completely down to lack of G3 maintenance/ inspection, and totally avoidable, but if Joe Public isn’t aware of how vital these regular checks are then they don’t know what potential there is for disaster. Or look at something which doesn’t have such requirements. UVC’s have been around for a long time, and if you go looking for the many tales where they’ve failed you may think twice! Would you choose a car which could break down and you need to call the AA, or would you buy one that could blow up and make a crater in the road ( with both needing replacing )
....and you're soon to have one. LOL. Enjoy.
If you make the improvements as stated above, the fan heaters will become quite effective as there will be far less ventilation heat loss. I made my man shed super draught-proof and 5 mins with the 1500w fan heater and all is well. IR are fine if you are staying in one place, as they 'heat what they hit', so not what I would choose for my own needs. The heat is instant from IR though, so merits are plentiful either way TBH. I just prefer the whole space heated and clutter / shelving walls etc cannot be taken up by panels. The fan heater just sits in one corner on the floor and is plugged in on demand. I'm just not a fan of having so much local heat concentrated in one place only. -
Matters not one jot. And your solution for someone needing..... .......is? May need a "shatoff" also next to the urinal for when someone 'overloads' it, typically after walking to it 10cm dilated only to find out you just fitted a pissoir
Just like the wretched Portaloo, your idea will be flushed. Also, if you don't like banging sounds, best ask the carpenters to buy rubber mallets for knocking nails in.......
