Temp
Everything posted by Temp
Garden Design with Low Retaining wall
Temp replied to Richini's topic in Landscaping, Decking & Patios
This is roughly what we did. the plastic sheet and french drain on the uphill side seems to keep enough water out of the wall that moss doesn't grow on it. The top of the wall was/is capped with same stone used for patio but some sections have come loose over 15 years. Perhaps no SBR used? The armoured cable for wall lights has potted junction boxes one per light. The Paving Expert web site is also good for all things related. They have a slightly more robust design.. https://www.pavingexpert.com/featur03#retain Perhaps bookmark their site index. https://www.pavingexpert.com/pavindex -
Ground Floor Extension Planning and Party Wall Advice
Temp replied to Can_Do's topic in Introduce Yourself
Because you are building close to the neighbours the Party Wall Act will probably apply. If the neighbour knows their way around the Act they can make it quite expensive for you in terms of surveyors fees. If he was happy with your project all you would need do is give him notice and plans and he would give you a letter in return, no surveyors involved. If he's not happy he can ignore your notification or object to it and you are obliged to get surveyor(s) involved. He can agree to share your surveyor or have you pay for one of his own. There is no penalty for not complying with the PWA only risk. If the neighbour wanted to cause trouble they could ask a court for an injunction stopping work on the grounds that your work is causing cracks etc. The court would take a dim view of your decision not to comply and might be more likely to grant the injunction abs possibly costs. If his facia boards are timber perhaps offer to replace those facing you with uPVC to get his support? Perhaps point out if he agrees to your project you won't raise the issue of his gutters overhanging the boundary. If he's still not happy you may have to get PWA surveyors involved. -
Built in microwave that doesn't keep beeping?
Temp replied to Mr Punter's topic in Kitchen & Household Appliances
What's Going on With This Brickwork
Temp replied to Richini's topic in Bricklaying, Blockwork & Mortar
You could get another block leaf built but it might be easier to build the new floor then add internal wall insulation and plasterboard. Treat it a bit like a garage conversion. This would take less internal space. -
Does the patio have a decent fall on it away from buildings and where does it drain to? We have something similar in our garden to your proposed solution. We have a brick retaining wall about the same height. There is a French drain on the uphill side of the wall and a linear drain on the lower/patio side. Seems to work OK. Will try to post a drawing later. -
Your two thread are likely related. https://forum.buildhub.org.uk/topic/33522-whats-going-on-with-this-brickwork/#comment-493044 -
Just seen your other thread, -
It looks like there are 2 DPC, one just above the drain cover and another two bricks above it. Is that a linear drain around the whole perimeter? If the drain fills up with water there will probably be penetration below the lower DPC. There may also be some rain splashing up above the lower DPC. My guess is they painted the inside with a liquid DPM of some sort to try and minimise water penetration but a single skin wall is never a great idea. Perhaps consider raising the floor inside.. install a DPM lapped up the walls above the top DPC. Fit insulation and new floor screed to raise the floor. -
This is what I did on a bigger outbuilding with tiled roof. How much is necessary I don't know.. Install duct for electricity. I used rebar hammered into ground and cable ties to hold duct in position. Level ground and compact with wacker plate. Add hardcore and compact in two layers. Add 25mm sand blind and compact. Add shuttering and plastic sheet to stop concrete losing water before it sets up. Pour concrete and level with top of shuttering. Push heads of long bolts into the concrete to later bolt building down. I used threaded rod and nuts. Support while concrete sets if necessary. Put lengths of pipe over bolts to stop you being impaled if you trip over.
Don't just put a shed on a concrete base that's bigger. Rain lands on the perimeter and runs under or rots out the bottom. Either raise the shed on a coarse of engineering bricks or make the slab slightly smaller than the shed and raised above the surrounding ground. The idea is rain hitting the walls of the shed drips off onto the ground not the top of the slab. You can also put gravel filled trenches around to reduce splashing up onto the walls.. I'd probably go for 100 + 100mm.
Can we use an i joist instead of ecojoists on an 8.1 span?
Temp replied to CalvinHobbes's topic in General Structural Issues
Perhaps I'm missing something but I don't see the connection between the use of a structural ridge beam to support the roof and the type of floor joist. Are there posts under the ridge beam that bear on the joists? Normally the beam would be supported on the gable end walls, interior walls or posts that go all the way down to the ground floor. -
Advice on Insulating under rafter instead of between
Temp replied to MarkH395's topic in Heat Insulation
I'd get the membrane on at least in case it rains. Then 75mm glass wool batts (allowing 25mm for the membrane drape. Then as much PIR below the rafters as you can afford. Expanding foam where the PIR meets the purlins. Tape any joints.- 9 replies
- insulate
- vaulted ceiling
If it was mine I'd lift the lid on the cover and see the cable could be lowered. If so then cut the concrete either side of the cable with disc in angle grinder. Chisel out a channel in the concrere. Split a plastic pipe lengthwise to get it over the cable. Concrete it into the slot cut.
The reason the dpc should be 150mm above patio is to prevent rain splashing up above DPC. That may not matter at a threshold because the rain splashes onto a door or glass etc. Thus is what Building Regs recommend for a level access threshold..
Google found.. https://www.monsterplumb.co.uk/lockable-half-inch-hose-union-bib-cock-quarter turn lever-1?gclid=CjwKCAjwg-GjBhBnEiwAMUvNW5HZqt6MhWZ_ByfhfzDdFCUNfyy6hXCrTwhbf8RT55lSf2pvPG0IJRoCDbsQAvD_BwE
I always forget its lower case n for newtons but N when abrieviating.
I'm a bit late to this thread but.. To calculate a force you multiply the mass by the acceleration due to gravity g = 9.81m/s^2 (or 10 if you want to make the calculation easier) and you get an answer in Newtons (N). So a 60kg top hung pocket door exerts a force of about 60 * 10 = 600 N or 0.6kN on the track it hangs from. This is a point load as it acts more or less in one place. If you had a floor that you planed to tile with heavy stone that has a mass of 60kg/m^2 (60 kg per square meter) the extra force on each square meter would be 600N or 0.6kN. If your floor had an area of say 20 square meters the total force on the walls would be 20 * 600 = 12,000 N or 12kN. This is a distributed load as its spread over the area of the floor.
Is There A Self Build Case To Meet An Identified Housing Need Policy?
Temp replied to EViS's topic in Planning Permission
My thinking is that answering the FOI request is work the planners would rather not have to do. If it turns out the info doesn't help your case you can leave it out of the application and they can't link the request to you. -
Search Google or Amazon for Decor Grates.. https://www.amazon.co.uk/s?k=Decor+Grates&i=diy&crid=1CBYXQIUJJCBN&sprefix=decor+grates%2Cdiy%2C311&ref=nb_sb_noss_2 They appear to be floor vents and come with a back box and no mesh? Might be possible to add mesh yourself.
I'd say 510 is too small. Perhaps run rails front to back rather than sideways? Hang front to back rails from a shelf?
Fire barriers required behind cladding.
Temp replied to Big Jimbo's topic in General Construction Issues
And something similar where the cladding has a window in it?
