Temp
Everything posted by Temp
A version of BRE365 digest is here.. https://www.eden.gov.uk/media/1072/bre_digest_soakawaysdesign.pdf
What does that include? Perhaps ask the BCO what he needs for the drainage. If he knows the ground is free draining he may not need you to justify the size of the soakaway. Search online for guides like this.. https://www.drainagepipe.co.uk/soakaways-and-membranes/how-do-i-know-what-size-my-soakaway-should-be/ http://www.pavingexpert.com/drain08.html If you have clay or the BCO wants to see it all justified with data you may need a percolation test. If you also need a ground condition report to justify the foundation design do both at same time. If you can provide a JCB and driver it will be cheaper (ask your builder/ground worker?). I think if they have to provide JCB you could be looking at £1500 with the rest being for the drainage design. I might be out of date on costs. The BRE publish a guide to soakaway design (BRE365) which needs data from the percolation test to calculate the size. As I recall the design method in BRE365 is complicated but you might find a simpler method on line that is conservative (eg gives a bigger than necessary size). That's not necessarily a bad thing. In addition to sizing the soakaways you need to specify the location on the site plan and the layout of the pipes (soil stacks, man hole etc). A lot of this is in the relevant approved documents but it takes some reading. If you posted your house and site plans here someone might be able to suggest a layout but you couldn't sue us if it all went wrong.
Outline planning permission application requirements?
Temp replied to PXR5's topic in Planning Permission
South Oxfordshire have a check list here.. http://www.southoxon.gov.uk/services-and-advice/planning-and-building/make-planning-application/validation-checklists -
We have two places where the gutter sometimes overflows. It's because gables and dormers create a lot of roof area feeding water to only a short length of gutter and one down pipe. Nothing we can easily do without fitting an enormous wide custom made gutter/hopper that would look ridiculous. Fortunately it only overflows in really heavy rain not the usual showers.
I think I would find 2200mm pretty darn oppressive and I'm not tall. In a design guide for London I found this... https://www.london.gov.uk/sites/default/files/housing_standards_malp_for_publication_7_april_2016.pdf The nationally described space standard sets a minimum ceiling height of 2.3 meters for at least 75% of the gross internal area of the dwelling. To address the unique heat island effect of London and the distinct density and flatted nature of most of its residential development, a minimum ceiling height of 2.5m for at least 75% of the gross internal area is strongly encouraged so that new housing is of adequate quality, especially in terms of light, ventilation and sense of space.
That's what I did.
I'm in Cambridgeshire where the weather men said it was 38c yesterday. Bedroom was 29C at 10pm. Felt cooler outside so i opened window and put a big oscillating fan on the sill. At midnight it was down to 27C. Fan ran all night blowing air in. Woke up about 6:30 to thunder and rain and stat says its 28C! We have mains pressure cold water at all taps. For last few days its been warm no matter how long you run it for.
Take lots of photos of anything you cover up just in case you need to switch back to the LABC.
Thread already running on green building forum.. http://www.greenbuildingforum.co.uk/newforum/comments.php?DiscussionID=16177&page=1#Item_0 Featured on BBC Radio4 last week.
Where do you stand regarding the building regs, escape from fire part B? Thought you needed windows that open. I mean getting fixed and opening windows to match up might be tricky?
I had a look to see if I could find a design guide from Westminster Council. Google found this which includes Policy CM28.4 on page 21. Google says "you" were consulted about it in October last year so it may have been formally adopted by now. Hope link works. http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=2ahUKEwifirbf28_jAhXwQUEAHeUnDFoQFjACegQIAhAC&url=http%3A%2F%2Ftransact.westminster.gov.uk%2Fdocstores%2Fpublications_store%2FDesign.pdf&usg=AOvVaw1Efq8zD6c4Z4Ik1p9NWxBK and I note it does NOT mention they must be setback only "subordinate" in other ways.
It's very common for planners to want extensions to appear differentiated or subordinate to an existing house. Sometimes it just looks wrong if you try to make an extension appear to be an original part of the house. The bricks rarely match perfectly and it can make the house look out of proportion. Many councils publish residential design guides that give examples of good and bad practice that mention this subordinate issue. Here is an example from Malvern in Worcs.. In a village near me they recently built a very large _new_ house and due to it's size (8 bedrooms?) they made it looks like a 4 bed house with about four side extensions on the left, each getting slightly smaller, some with set back and some in different materials. Looks fabulous.
We have a pocket/sliding door on an ensuite bathroom door. I would only have one as a last resort. In our case it was needed to save space. It may seem strange but the main problem is the extra time it takes to open and close them. You can't just whip them open and shut like a regular door. They feel heavier and you have to pull the door to get it moving then slow it down so it doesn't slam into the end stops as it opens or closes. That doesn't sound too bad but its enough to be annoying on regularly used doors. The door handle and set up also needs to be done carefully. The part of the door with the handle reduces the clear opening width because it cannot disappear into the frame (unless you have motorised doors?) so you need larger doors. If not set up correctly the handle can trap your fingers between itself and the frame when opened.
If I've understood your drawings correctly you want to add a room above the existing ground floor room. So the planners/architects proposal for a 200mm set back requires you to demolish the existing rear wall and rebuild it 200mm back before building the room above. Is it the need to demolish or the loss of 200mm that's the main problem for you? Would you have to demolish that wall anyway? You could stick with the original plan and offer to differentiate the extension in other ways, perhaps with a different external finish to the main house? Has anyone else done that?
Not sure exactly which model of the stat you have but the one I've been looking at has 4 wires (+,-,A1,A2). This will probably seem very obvious but the pinout is + A1 A2 - so make sure the pairs are connected like this.. Pair 1: + & - Pair 2: A1 & A2 not Pair 1: + & A1 Pair 2: - & A2 If that's OK you might try adding a 100nF ceramic capacitor between + & - at the stat end (but don't put one on A1/A2).
I don't think building it without planning permission means he has to pay to fix it. At best you might be able to claim damages for the cost of getting planning permission but that's just a few hundred £. Your best bet is to claim against any structural warranty he provided. NHBC policies require the builder to fix it in first instance and cover you if he goes bust.
The planners only have 4 years to initiate enforcement action (10 years if a change of use is/was required). So if it wasn't built with planning permission its now too late for the planners to do anything about it. If you wanted to regularise the situation officially you could apply for a certificate of lawfulness on the grounds that its too late for enforcement action and it should be granted no problem. Consider doing this before knocking it down. If the house has a structural warranty I would crack on and make a claim.
Their SmartStat has a feature called Ambient Light Dimming which if enabled turns down the brightness of the backlight when the room is dark.
I had a look at the manual and unfortunately there doesn't seem to be an optional feature to disable the proximity sensor. Earlier Heatmiser stats only light up when you press a button as they don't have a proximity sensor. Worth asking them to consider adding such a feature as pretty sure it would just be a software change.
Can they tell you how the proximity sensor works? Some sort of capacitive sensor or does it bounce IR off you? I think you have done everything to eliminate a faulty stat. I'm wondering if they have a design issue? Proximity sensor too sensitive? Picking up mobile phone? Noise on the wiring?
Where we lived in Belgium the recycling centre was in two parts for recyclables and non-recyclable. They had a weighbridge on the entrance and exit of the non-recyclable side to calculate your bill. However you could walk between the two sections. So drop the wife off at the entrance to the recycling centre with a bag. You drive into the non-recyclable side getting weighed on the way in. Off load and pick up the wife. If you aren't careful you can weight more on the way out than on the way in :-)
What does your planning consent say? Convert or knock down and rebuild? If its convert then you can't just knock all the walls down and rebuild them as that would breech your planning consent.
Typically the ground conditions dictate the design of type and size of foundations. When designing a new house on suspect ground, the first step would be to get a ground condition report done. That involves digging some holes and pushing instruments into the ground to measure its load bearing capability. That data can be given to an SE to use to design the foundations. Why did the SE say "underpin and keep fingers crossed"? Underpinning works well if the ground is suitable. If he thinks it might not be then perhaps best get it checked out. See what others here say.
Internal partition walls Stud work Vs block work
Temp replied to romario's topic in General Construction Issues
If you really wanted to go to town on sound proofing then it would be four layers of plasterboard - two each side. Staggered offset studs... https://www.plinthandchintz.com/glossary/staggered-stud-wall-construction/
