Temp
Everything posted by Temp
Wind spinners/ mini turbines?
Temp replied to Moira Niedzwiecka's topic in General Self Build & DIY Discussion
When you connect them to a generator or pump they become a wind turbine :-) The ones in your original picture don't look that different to this type of vertical axis wind turbine. Smaller ones are sometimes used on boats. -
I guess that would be possible but they will be a less efficient than a regular wind turbine of similar size. There may also be a planning issue. -
Lead trays for windows & doors in a timber frame?
Temp replied to Nick1c's topic in Windows & Glazing
I don't know about trays but I used lead flashing above windows in a timber clad building to prevent water getting in. It basically extends the membrane behind the cladding out over the head of the window. -
An LCD TV might not be a bad idea. Some can play slideshows and video from a usb memory stick so you could have any image you like. If networked you might be able to display the real time view of say a beach in Hawaii or some other web can.
Reminds me of this YouTube video. Skip to about half way.
No. The duty is an amount in £. The tariff is the rate in % used to to calculate the duty. If you order something like a lorry load of bricks or timber the cost to you should be calculated as follows.. Total = [(Cost of goods + shipping + insurance) + duty] + VAT In addition there might be a fee (and VAT on the fee) from the customs broker (company that processes the goods through customs. For example they may have to store the goods while they contact you and collect your payment of duty and VAT).
As I understand it the UK is planning temporary tarrifs on a range of goods... https://www.gov.uk/government/publications/temporary-rates-of-customs-duty-on-imports-after-eu-exit It says the tarrif will be zero on goods not listed. Couldn't find windows listed, nor bricks. As for VAT.. I believe the UK will charge VAT on goods arriving from the EU at the ports. So I believe you need to get EU suppliers to give you export prices or you will end up paying both EU and UK VAT. I'm guessing only UK VAT will be reclaimable under the self build reclaim scheme. The treatment of small parcels is different. Lots of info in here.. https://www.gov.uk/government/publications/vat-for-businesses-if-theres-no-brexit-deal/vat-for-businesses-if-theres-no-brexit-deal
Yes welcome. Did you manage to avoid any awkward planning conditions? Next stop CIL exemption claim forms :-)
New House with 4 self contained Minimalist Apartments
Temp replied to Adrian Walker's topic in New House & Self Build Design
Some years ago when looking a for a flat to purchase as a buy-to-let an estate agent showed us a new build tiny bedsit. So cramped that three of us got in each others way. The whole place had just one window serving the living room/bed room. No window in kitchen or shower/WC. We couldn't see it being a good investment. We eventually found a two bedroom flat with shared garden for the same price about half a mile further out of town. -
Here... https://www.buildingboards.co.uk/products/rcm-cemboard/ It says...
+1 If you don't have a nervous twitch you will after dealing with the planners.
Just a heads up... We only have 80mm of PIR insulation under our UFH. I now consider that a bare minimum and would put in more if building again. Perhaps 160mm PIR or 200mm EPS? See what others suggest.
The idea with a raft is that everything sits on it and its strong enough that it can bridge poor/made up ground, bit like a raft on water bridges between wave crests. Hence the walls must sit on the raft as well.
That will be because of the pool. He means good ground everywhere except where filling in the pool.
Small article in today's Times mentions planned changes to the way VAT is paid in the construction industry. Called "Reverse charged VAT" is says buyers will pay VAT direct to HMRC rather than to suppliers. Due to be introduced in October it is apparently aimed at reducing VAT fraud. Doesn't say if it applies to self builders.
VAT and public utilities
Temp replied to Conor's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Make sure you get your CIL exemption paperwork done before starting any work on site. -
You dont have to officially start work for something to be zero rated. The guide VAT 708 just says the work must be "closely connected" with the construction of a new dwelling. See section 3.3.6 https://www.gov.uk/government/publications/vat-notice-708-buildings-and-construction/vat-notice-708-buildings-and-construction It says it can be zero rated except in the case where. I think outline PP or full PP with some conditions not yet met might be enough. I would tell them its for a new dwelling that should be zero rated and ask for a new quote showing zero vat, see what they say. -
Our water main diversion was zero rated. -
New Phone Line/Broadband: trench and ducting req'ts?
Temp replied to Piers's topic in Networks, AV, Security & Automation
My builder reckoned it was best just to run your own cable to the bottom of the pole and leave enough spare coiled up to reach the top. We had issues getting openreach to come out but once they arrived they were happy to connect up the cable we supplied. -
I think all "layers" are made the same. They just turned alternate layers over when it was assembled. I'd call it "Butt jointed, clockwise/anticlockwise on alternate layers"
If its a 12v lead acid cell they can benefit from being kept on a float charger when not being used. This is a mode available on some regular battery chargers. In float mode it charges to a slightly lower voltage so you can leave it connected all the time without it overcharging or "boiling" the cell dry. I found cells kept on float live longer (retain their capacity longer). If you leave them alone they self discharge and they really don't live long if left flat.
I would look up the rules for doing a credit card charge back. You probably have to give them time to deliver but there may also be a time limit on doing a charge back. Best not let one exceed the other. I noticed that although they list Paypal (as an option at the bottom of most pages) if you go to checkout there only seems to be an option to pay by credit card. So it's possible they are just harvesting credit card details and addresses? Keep an eye on your credit card statements!
This machine (Snapmaker 2.0) doesn't even appear to be available yet.. https://cogkart.com/products/printer-2-0 "£59.95" Manufacturers web site.. "Snapmaker 20. is the Most Funded Technology Project on Kickstarter history" https://shop.snapmaker.com/collections/machines/products/snapmaker-2-0-modular-3-in-1-3d-printers "Preorder" "$999" (down from $1499) "Your order will be shipped in March, 2020."
No worries I started using Google when Yahoo was the best portal and before Google had adverts.
