Temp
    43
Everything posted by Temp
  1. Firstly they need planning permission to raise ground levels more than about 150mm. Comes under "raised platforms". However the planners may ask if you have any evidence the level has been raised. There is also a 4 year "statute of limitations" so if more than 4 years ago the planners can't take action. Normally retaining walls are the responsibility of the supported land. I think you need to decide if you want to own the wall and how heavy you want to get at this stage. It doesn't look too bad to me at the moment. If it's your wall and they have raised the ground levels and it's damaging the walI I believe they could be liable but you might have to prove it in court. http://www.boundary-problems.co.uk/boundary-problems/fences.html If it's their wall and it fails they are not obliged to repair it (There is no obligation to fence land). However if it becomes dangerous or causes injuries they can be held liable. Retaining walls can be very dangerous and Building Control may take an interest. http://www.bbc.co.uk/news/uk-wales-north-east-wales-19841005 If it's your wall you are not obliged to replace it with another wall unless they have acquired a right to rely on it for support. Let's suppose you detect the wall getting worse and a friendly chat fails to get them to lower ground levels. Then I supose you would have to get a solicitor involved. I would expect a solicitor would write to them and say something like.. You are concerned that rising ground levels is causing the wall to lean and might be putting the wall at risk. He might point out that you do not know who owns the wall but that.. a) If it's yours and it falls down due to their actions you may hold them liable for repair costs. You do not believe they have a right of support and you do not consent to them using it for support (aka a retaining wall). b) if it's their wall then they are liable for it's maintenance (if they want to keep the wall) and any injuries or damages it causes if it fails. Copy BBC article. You could also add that if someone continues with actions after being warned of the danger (as you are doing in this letter) and that leads to damage to life or property they can also be held liable for additional damages for negligence. Meanwhile I would check your own house insurance.
  2. With UFH "they" recommend keeping the TOG value below 2.2-2.5. Lower is better for UFH. You can get special underlays with a TOG of 0.7 leaving around 1.6 to 1.8 for the carpet. Some warnings... It's rare for carpet showrooms to display the TOG value but it's frequently on the technical spec or data sheet. Ask the retailer for a photocopy. If the retailer can't be arsed to do that go elsewhere. Don't accept a verbal answer. Ignore anyone that tells you all their carpet is suitable for UFH. They mean the UFH won't damage the carpet not that it will let the heat through. When you order check the small print. Some carpet is made in two versions -Hessian and foam backed. The Hessian backed version has a lower TOG than the foam backed. Sometimes the small print allows them to supply either version. Do ask for a sample of both underlay and carpet so you can walk on it as it will be when delivered. Very Low TOG combinations can feel a bit hard.
  3. I recommend creating a mock up. Find a table or sheet of cardboard and stools the right size and arrange them somewhere. Actually sit on the stools and adjust the position so you are comfortable. Then get off without moving them so you can walk around and see if there will be enough space to work. Some Architects CAD models of tables, chairs and sofas tend to be on the small side compared to what you actually need. I think they were designed for estate agents to make rooms look bigger on plans :-).
  4. Ideally you would just have wood flooring. Not floorboards and wood flooring. We have 21mm wood flooring over UFH and it does work but we have found we need higher flow temperatures than expected. Typically we set our programable room stats to 16C at night (aka "set back") and have them increase to 20/21C about an hour before we get up. It takes about that long to warm up the floor and raise the room temperature.
  5. We paid our builder in arrears not in advance. On one occasion he asked for help with his cash flow and I agreed to pay him in advance for our windows. I paid the amount the window co had quoted less VAT because I couldn't reclaim it. We had a pretty good relationship and I never had any concerns about him. If I had I would have paid the window co direct. We had agreed a %5 retainer and deducted that from each stage payment rather than the whole 5% from the last one. At least twice our builder proposed changes that were going to cost more. Easy time we asked him to formally write to us ammending the quote before agreeing them. Both times his proposals were a good idea. Example, adding a velux to a store room in the roof space.
  6. If you have paid him for materials that haven't arrived what makes you think the windows will? I'd pay the window co direct by credit card as others have suggested. If they are reluctant then as long as you pay at least £100 on the card the whole lot is covered. But it has to be for the windows themselves not "fitting" or "designing" the windows.
  7. Heard on the radio today... What colour should the new Kent passport be?
  8. As I understand under WTO rules we have to impose the same tariff on imports from all countries unless we have a trade agreement with them. So for example we currently impose 6% duty on imports of Aluminium products from non-eu countries. After the end of the year we have to decide if we will impose 6% duty on imports from the EU as well or some other rate. If we decide to reduce it to zero for the EU we have to reduce it to zero for all countries that we don't have a trade agreement with. We risk allowing cheap imports from say China to wipe out UK based manufacturing - the reason we have a tariff at the moment.
  9. They can "own" it. Exactly what do you and their deeds and other documents say about the pipe? Forget what they are asking for, what do the existing documents say? They sometimes give both parties rights specifically for eventualities like this.
  10. First thing to do is find out if the electric co (DNO) have a wayleave for the pole. If there isn't that will help bargain down the cost of moving it. Bear in mind that to move your pole may require additional poles.
  11. Bit of googling suggests that with a stone wall you cut a straight slot 1.5" deep into the stone with an angle grinder about 125-150mm above the tiles. The slot should slope upwards as it goes into the wall.
  12. Looks like you need to learn how to flash a roof with profiled tiles to a wall. There are some youtube vids.. This example is on a short porch roof. For a taller roof the lead will have to be in several sections. Start at the bottom so that subsequent sections go on top as you work up towards the ridge. Each section should overlap the one below like roof tiles do. My only hesitation is the wall. Is it brick or stone? Im not sure if you can do this type of flashing with a stone wall. Make sure the lead is wide enough to reach over to the low point of the tile. I would bring it out to this point..
  13. The best way to preserve existing ceilings is to avoid putting any new load on the existing ceiling joists. Arrange for the bottom of new floor joists (or bottom of attic trusses) to be about 1" above the top of the plasterboard. Avoid bolting or nailing new joists to the side of existing ceiling joists except at the ends where the existing joist is supported by a wall. That way when you load them up and they bend they do not transfer any load to the existing ceiling. This should really help avoid cracks in ceiling plaster.
  14. With air you need to loose a lot to see a reduction in pressure. With water not so much.
  15. They have a trade card which gets 5% cashback and discounts elsewhere but no idea if a self builder can get one.
  16. A push mower might work as well?
  17. I have used a TCT jigsaw blade for small openings but its still hard work and blade wear is fast.. Score and snap for straight lines..
  18. I have a blower but find a ride on mower collects them better.
  19. I think if I was doing it again I'd look at something like this... https://www.ledkia.com/uk/buy-basic-ultraslim-led-downlights/218-round-6w-ultraslim-led-panel.html Not used that company before but there are lots of similar out there.
  20. My electrician did exactly the same in our bathroom.
  21. Ok that sounds like Wedi Board. I have used that to make a wash stand. Nice to use for that because it cuts easily. Mine is hung with travertine stone and has been fine. However I did insert wooden blocks to provide anchor points for towel rails etc. I don't think it would survive if we wanted to remove the stone and retile with something else later. This fire rating relates to just the board not a stud wall clad with board.. https://materialdistrict.com/material/wedi-panel/ For the rest of our room we used Hardi Backer Board. That's a solid cement board that is virtually bomb proof. Quite hard to cut but no problem fixing things to it (if you can't find a stud in the right place). We used the 12mm thickness straight over studs. Hardi Backer Board doesn't burn but it can conduct heat to other flammable materials. So I'm not sure exactly what fire rating a stud wall clad with Hardi Backer Board has. Our BCO didn't question it (if he noticed). Best ask yours. https://www.jameshardie.com/product-support/resource-center/technical-documents/fire-prevention-faq This fire rating relates to just the board not a stud wall clad with board but compare with above.. https://www.jameshardie.co.uk/import/Documents/HardieBacker Multi Fuel Installation Guide.pdf
  22. You also need to think about the battery and wiring carefully. 7000W at 24V = 290A.
  23. I used the Protect VP400 on an out building. Was exposed on both walls and roof for many months with no problems.
  24. Pine can be rather soft. https://www.antiquewoodenfloors.co.uk/original-pine-floorboards.htm
  25. 350mm might be wide enough for the services but not sure I could dig a trench in such a confined space. I think i would use it to bargain a better price from the owner of the yellow land.
