Everything posted by le-cerveau
If you want do do anything clever such as Guest network management (T&C, payment vouchers, .....) then you need a controller otherwise set it up with your MAC and then leave it alone. Every now and again you need to check and update the firmware but otherwise leave it alone.
No UniFi is Prosumer, and requires some configuration.
Yes people can connect to the AP and ignore the Hub, in theory you can turn off the hua Wi-Fi (not sure how though as I haven't used one for a while). You need a UniFi controller (Cloud Key, Web controller or on your PC) to set up and adopt the AP. Lots of help on the UniFi site https://community.ubnt.com/t5/UniFi/ct-p/UniFi. WHat are you using as your controller? If it is just on your PC and the PC is connected to the same hub as the AP then just use the Chrome extension to find the AP. Or if you AP is plugged in and you know the ip (from the Home Hub page), you can SSH into it and 'Set Inform' pointing it to the controller.
Problem with this type of device is that it needs the WI-Fi signal at its location to extend it (same as a plug in one), and by doing so is reducing the throughput capacity, It has to receive it then transmit so can only ever be half as good, and will add to the RF noise so aggravating an already non-optimal situation. It is no substitute for a wired in Access Point.
Window Companies Alu Timer/Alu PVC
le-cerveau replied to canalsiderenovation's topic in Windows & Glazing
No it is: JUB External Render Only system with a silicone finish; two coat application; circa 3mm thick nylon mesh reinforcement fully bedded in base coat, overal thickness 12mm (approx); white; applied to Econekt King Blok base; full preparation, bonding agent and application strictly in accordance with manufacturer's guidelines and recommendations from the contract. -
Some pictures from during the build. Dining room 2400mm wide, 1800mm high Obscured bedroom window (overlooking, 2000mm x 1200mm) External, the top left is the KF410 Bedroom and en-suite. -
I have Internorm aluclad pvc windows KV440's and one KF410 (non opening highlight). absolutely no issues. We were going to use HV350's with the KF440's only in the bathrooms (recommended not to put timber in bathrooms) and we thought just go pvc throughout, slightly cheaper but the quality is superb. You can have them coloured inside with wood effect Decor Foils if you want that wood look. -
My set up is similar though mine are pre UniQ but dual units. I have 2 x PCM34 units heated by my ASHP that pre-heat the DHW and the UFH. Then 2 x PCM58 units for the DHW .
I fitted 3 different lighting colours: 4000K in the kitchen, laundry and studies (I have two) 2700K in bedrooms 3000K elsewhere The 2700K is a gentle soft white whereas the 4000K is quite harsh but better for detail work Everything is LED, either downlighters, panels or recessed strips.
Why crimp plugs, when you should be using keystones on the ends which are fitted with a punch-down tool or can bey keyless, this is what my electrician used (punch-down CAT6 connectors). You then have sockets at each end of your fixed cable runs. Then you use short patch cables, bought or made. At node zero you either have a lot of sockets, or if you have enough connections a patch panel, which is again punch-down.
Controlling MVHR boost
le-cerveau replied to MarkyP's topic in Mechanical Ventilation with Heat Recovery (MVHR)
My MVHR is connected up to all the cisterns and extracts continuously from the bowl. as well as extract terminal(s) in WC wet rooms. -
I use RH sensors, I have 2 x Brink Renovent Excellent 400 Plus models one for Upstairs one for Downstairs with the options RH sensors fitted into the extract duct just before the unit. The first diagram shows a weeks recordings of the downstairs unit and you can see my mum going into the shower each morning and the MVHR ramping up. The second is an expansion of the first 24 hours: This works perfectly for me and allows me to run the system at a lower rate, it ramps up to the Building regs required extract rates. and still has more if required. The house was over warm at this point and I have since corrected the temperature to a more norman 21oC from 24oC -
mvhr and minimal other heating
le-cerveau replied to scottishjohn's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Our Pasive Style (not evaluate house) is currently drawing less than 0.5Wm2 to maintain an internal temperature of 21oC with the outside running between 7 and 10oC. I can make a fairly accurate estimate at the moment as the house is unoccupied and the DHW shut down (so no losses there), the ASHP is firing up about every 36 hours to re-charge the PCM34 SunAmps and drawing an average of 2.3kWh. Assuming a CoP of approximately 3 (will check details when next there) gives 7kWh every 36 hours giving 194W per hour, spread over a house with over 400m2 floor area, gives less than 0.5Wm2. The MVHR is ticking over and everything else shut down, Fridge running, one computer (other reasons of remote access) and the network equipment in the attic (inside envelope). We have UFH throughout as a unified temperature, upstairs runs about 1-2oC cooler than downstairs so it is fine for us. -
GF-Plan.pdfGF-Plan.pdfWe have a 150mm reveal in the lounge/kitchen/diner, picture of kitchen from lounge. 2900mm floor to higher parts, 2750mm to lower parts apart from kitchen island which is raised by 50mm to lift the extractors. SO a 150mm drop. I also have a 150mm service void above the ceiling. (here is the build up). 250mm pre-stressed concrete first floor (large span). The lower dropped ceiling is in the hall where the Ground floor MVHR manifolds are. The room is 10m by 8m plus the dining room, see plan. The lighting in the kitchen is 3000K, whilst in the lounge 2700K, giving bright working light in the kitchen and softer light in the lounge.
You can get multiswitches to support Sky Q (Sky no longer supply Sky+) they are DSCR ones (expensive). I have an 8 port one from Triax. With a DSCR switch you just use a Quattro LNB, not Quad and feed the 4 inputs, then you only need one COax to each TV output as all the Sat signals and TV signals go down the single line. I would run two cable though to each major TV point as TV takes one feed (plus Sat if you have a top of the range TV. Sky Q takes a Sat feed only no RF so you can get away with one but two covers future use. Sky engineers need to be told how to set it up though as it is considered as a flats install not domestic and they all dont know how to do it. Press home Scroll down to settings but don't press select Press 0 0 1 Select Change LNB type from Wideband to SCR Press home Pull power out back and reboot Future proofing with the cable runs is a good idea, you can add a DSCR multiswitch if/when you get SkyQ. If you are considering distribution I would recommend fitting a Quattro LNB (each of the 4 HV, HH, LV, LH channels is separate) and a multiswitch which also takes the terrestrial TV (and possibly Radio) around to each output and break out on a triplexer plate (SAT, TV, RADIO) with two of them behind you main TV.
Agree with @ProDave bathrooms won't work like that. Consider putting the kitchen at the West side to keep all the plumbing in the same location, reduce length of hot water runs. Storage, where is the general junk storage (do you have attic space)? The windows, long gives you more light (summer overheating), but robs you of usable wall space, especially in bedrooms where a chest of drawers/desk fits neatly under a window. Airing cupboard/hot press, nowhere enough space in with DHW tank/SunAmp. Does the Master en-suite need a bath (mine does but I have 5 1/2 bath rooms). You may have fire regs problems with kitchen open to stairs. Front porch, enclose to isolate the whole house from the elements in winter with the front door open, also hides offset door then. Not sure how the stairs will work.
Yes, ordinarly a PoE powered switch will use the PoE to power the switch and it will pass on PoE power to one port, the other ports will be unpowered. There are some that will power more than one device D-Link DGS-1100-05PD that can power 2 devices, within power limitations, but normally the PoE power can only do the switch and one other device. The safest way is to have a small powered switch on each floor and then run your AP, CCTV cameras (you can have more than one) from that, and also link to the other floors. So PoE switch on Ground Floor with Modem/Router to supply AP and CCTV and any fixed runs (TV......) It then links up to First Floor Powered switch to run AP and CCTV and any runs...
Late to the conversation but: How much Cat5 do you have installed? in a HMO you want an AP on each floor, this allows you to turn down the power and get better coverage. The Ubiquity AP are all PoE and most Cameras are PoE (Ubiquity also do cameras), so you need a PoE powered Cat5 run to each AP and camera. If you only have one CAt 5 run but require 2 devices then you will need a mains powered switch to provide 2 x PoE outputs, You get PoE powered switches with PoE passthrough though realistically only one, so you need mains power to power either a PoE switch or the device. You can ditch the BT hub and put in a modem (I use a Draytek Vigor 130) and Firewall (Ubiquity USG) and remote manage everything, including the modem. This however takes a reasonable amount of knowledge and effort. It all depends on your current Cat5 Install, required number of AP's and cameras and willingness to tinker. I have a Draytek Modem (Vodafone Business Fibre 70mb), Ubiquity USG Pro, 3 switches (48 port, 24 port PoE, 8 port PoE powered) 4 Ubiquity AC-AP-Pro and eventually 10 Ubiquity cameras (not yet installed). A VPN connection to my other house (overseas) that allows it to be in the UK at that address with Ubiquity equipment at that address. All internet at our overseas address is routed through the UK one (Hence fast fiber 20bm upload to overseas) and appears to be in the UK negating the VPN issues with UK TV providers. But this takes some management and effort!
Windows conundrum – living with triple glazing
le-cerveau replied to Simon R's topic in Windows & Glazing
Internorm (expensive) do large scale glazing PANORAMA HX300 which can be integrated into the building. -
You can get PCM34 SunAmp Units in the UniQ range, USe that as the buffer tank and DHW pre-heat, that is what I have, ASHP feeds the SunAmp and the UFH takes heat from the same circuit. The DHW is then on the other heat exchanger. No wourry about losses and you can up size as required for DHW pre heat. Cost is higher than a Buffer tank though!
All Electric House & DEAP (SAP-UK)
le-cerveau replied to mike2016's topic in Energy Efficient & Sustainable Design Concepts
My SA units were installed by SunAmp, though all the preparatory work was done by my plumber and electrician. -
My first comment would be flexible ducting (put in by builders) will cause massive flow losses. Looks like a Ventaxia Integra model, small 400mm x 400mm, that will be the issue getting a unit to fit in the space. The small Brink Sky150 is over twice a long! I suspect the developer put in the cheapest/nastiest unit they could find to say they had fitted MVHR!
My initial thoughts: Master en-suite is pokey yet family bath is huge, consider re-arranging the master bed with the en-suite back to back with the family bathroom (steal some space), give yourself a descent built in wardrobe where the current en-suite is. Also simplifies the plumbing putting everything over the utility room. A big master bed is nice (we have a massive one) but is mostly lost space, more importantly is that every bedroom can take a super king bed if required without compromise! Agree with @PeterW that kitchen open to stairs is an issue, fire regulations I think that would have to be engineered out, put an entrance hall at the bottom of the stairs to solve the problem. MVHR positioning does not lead to usable duct routes to the first floor, need to consider where the ducts will rise, through the corner of the bathroom/en-suite where the cylinder is, they are the largest service and everything need to work around it, otherwise it will be an afterthought (the plumbing will already be in) and will end up being a compromise/bodge! Consider a central service riser (where the utility cupboard is next to stairs) access to wet rooms above, vent trunking (option). Put your DHW cylinder/SunAmp and MVHR unit there Bin store, location and access in pouring rain! Service access to plot, meters in/on outside of Garage, build Garage first then you have on site services. You can also take dedicated feed for car charging. Car port beside garage for second car, and external charging point, second charging point in side garage. What about the attic, warm roof I presume, access, boarded out for storage…. We can all pick holes
Yes you can, it is specifically listed on the VAT431NB, page 15. SO you can claim the VAT on anything you buy. If having it installed (Supply and Fit) have it zero rated as you cannot claim back incorrectly charged contractor VAT. Just pay the invoice Without VAT and point them to the respective paperwork. If you don't pay the VAT and tell them it is not chargeable, you are done. They cannot pursue you for the VAT on a non VAT chargeable item.
Condensation on triple glazing
le-cerveau replied to Moira Niedzwiecka's topic in General Self Build & DIY Discussion
On the outside of our N facing windows, triple glazed with blinds and fourth pain!
