3 hours ago, Ferdinand said:
It also has a "pet tool", whatever that is. It sounds like you can pluck the dog
Sounds like something derogatory from Geordieland.
  • 3 weeks later...
5 minutes ago, ProDave said:
No idea how long this lasts for.
I presume that Travis Perkins and Toolstation are part of the same company then?
I assume so, but I don't think you have to prove you have (or have not) got a TP account.  Just enter that code for the discount.
I once went to the local TP with an urgent need for drain pipe fittings, lots of them. They were reluctant to  give me a price , but eventually quoted about £15 each less 10%. I knew the price at TS was about £5.
They weren't best pleased that I knew and then admitted that they were being squeezed out of a lot of business by their own joint owner.
They must have made enough of these £10 additions from the local builders to justify the policy.
Benchmarx bottom of the range used to overlap with Wickes top of the range kitchens. I don't know the current situation.
You all get the 10% discount from Wickes I trust.
Assuming that is good quality then that is a good price for temperature controlled tool. Keep the receipt as I have had very good and very poor stuff with that badge and others from Lidl.
Yes is seems okay.  The weakness I would say is the bits screw in. From past experience years ago that tended to corrode to the point you could not unscrew the bit.  This is Something like my 5th or 6th soldering iron, the old Weller was definitely the longest lasting, but near to falling apart now and obsolete so unable to buy parts.
I had an old bakalite body Antex, a 15 or 17W iron and it was *so* much better then the more modern 25W one that replaced it.
I have had a couple of Irodo gas irons and they're great to keep in the toolbag.
6 hours ago, ProDave said:
Just bought one of these from the middle of Lidl to replace my vintage weller soldering station that is falling apart
https://www.lidl.co.uk/p/diy-projects/parkside-soldering-station/p50335
I have one, the tips are crap.  Just today I have bought some from eBay.
https://www.ebay.co.uk/itm/283586511272
No idea if any good, shall report back if I remember.
Edited by SteamyTea
Thank you, worth knowing about.
Got my tip today, works alright.
Though I do think at £2.60 for 1, it is expensive.  But shall see how well it lasts.
Soldered the pins to the GY-302 pretty easily, now see if I can detect light with it.
  • 2 weeks later...
4 for 3 Discounts on Flooring from B&Q
First one I have seen for some time, and available on a selection of vinyl sheet, luxury tile and other styles.
Also applies to a selection of a laminate floor.
https://www.diy.com/landingpage/flooring#icamp=HP_Hero_Flooring
*Including a couple of Quickstep products.*
Here, for example, is Quickstep Aquanto Oak for (I make it) £15 per sq. metre. I did half a house with one of these.
https://www.diy.com/departments/quick-step-aquanto-varnished-natural-oak-effect-laminate-flooring-1-84m-pack-of-7/1294428_BQ.prd
Some of them review well.
  • 3 weeks later...
12 hours ago, PeterW said:
Anyone wanting Makita LXT batteries this is a bargain
https://www.screwfix.com/p/makita-dhp453ste-18v-5-0ah-li-ion-lxt-cordless-combi-drill/487kg
Pair of 5Ah batteries for £139 with a drill  and charger thrown in for free.
To give some idea of how good a deal this is, Screwfix is also selling a single 5 Ah battery for £100.
A pair of these batteries on Amazon is £150, so as you say, it's literally a free drill and charger on top of a better price than you'd generally be able to find for just the batteries.
If anyone's thinking about getting into the Makita 18 V ecosystem, this would be a great way to start.
I wonder if I could buy this for £140, take out one battery, put the drill, one battery and case on ebay for £140 and anyone would be stupid enough to buy it?
