Marvin
    3
Everything posted by Marvin
  1. Yup MOT type 1
  2. If the surface is to be left exposed then the areas of fines will wear away easily. Like driving on a beach. The mix is important. In Ministry of Transport type 1 fill the different grades are blended at source for maximum when compacted. This material is known as subbase.
  3. I understood to make a good surface the crushed concrete should be mixed fines, small and large items. The maximum size of the crushed concrete should be no more than half the thickness of the layer to be compacted and the fines should fill all the voids when compacted avoiding the fines in the ground below rising up to fill the voids causing the area to sink. I usually compact the filling until no more fines will go in. the fines hold the larger pieces from moving. Good luck. M
  4. As far as I understand - yes. M
  5. I understand these heights are set so when you sit in a wheel chair you can reach the sockets/switches and consumer unit.... in case you get old and frail and don't want to spend 6k a month for a care home because you can't turn a light on.
  6. Well I know little, but first suggest that if you do go ahead with the insulating without BC about, make sure you take plenty of photos which clearly show both the work being done and that it's your building. Secondly in my experience I think that you have to have at least 25mm insulation between the joists and the plasterboard to achieve BC requirements. When the joists are insulated in between and the plasterboard fixed directly on to the bottom of the joists to form the ceiling, this can cause cold lines on the ceiling where the timber is which can cause condensation to collect and leave marks. And as Faz says still need to achieve the U value. So I don't see a way around it. Best of luck Marvin
  7. I'm with Nickfromwales. Board suitable for fixings, coverd with fire board. I also insulated the walls to reduce the excessive heat escaping.
  8. So no other soil pipe air venting on your property in the design. Its possible that the Architect is just being cautious. May have been a problem before on another job. During high winds here I have witnessed strong airflow out of soil stacks... M
  9. Could be the Architect is just being cautious. Any chance of a quick call to ask the Architect Tomorrow? Maybe a retrofit? Sorry I don't know how difficult that would be with your roof design. M.
  10. Hi Conor As we know an AAV let's air in and a vented soil stack let's air in and out. It may be that the Architect feels there is the possibility of air pressure building up enough in the soil pipes to cause some of the water traps to fail expelling smells into the building. This possibility requires consideration of the pipework in the building as well as all the way down to the first vented soil stack which could be several houses away. So I wouldn't just slap an AAV in without checking. It may also be a smaller pipe will do the job.... Then again a possible retrofit if you have a problem? Best of luck Conor Marvin
  11. Is that tin foil or an inflamable alternative?
  12. Is the wall an external one or a party wall one?
  13. ? If you use the same scale rule on your build surely the result would actually be a smaller property.
  14. On my renovation I installed 80mm pipe in a pea shingle trench wrapped in geotextile. My narrow trench was against the external wall all around the building. I didn't put any soil on the top, just wrapped the shingle completely round and just added 2 inches of shingle on top for show. The shingle sits between the external wall and the block paving. We have timber joist floors and the top of the pipe lies just below the top of the floor slab. As there is no soil between the external wall and the geotextile I feel it won't easily clog whilst I feel the geotextile will keep the clay fines out of the shingle on the paving side. Good luck M
  15. Yes you are right. Renting, selling or to take up some of the green deals, you would need to have an EPC. So if you never want any of those then I guess your ok. And yes, if you were wanting verified insulation layers then an EPC inspections when building should give you verification, however on the ASHP deal they would only accept an EPC less than 2 years old. So you just crack on.? M.
  16. Adsibob, bit of a side issue. When we were renovating our home we were advised to keep the EPC assessor informed of the progress so the assessor can inspect /confirm insulation, espically where insulation was more than the minimum for Building Regulations. Expect you've got this covered. Best of luck. Marvin.
  17. 250 foot hosepipe! Big garden you've got!
  18. Where would you draw the air from to cool the upstairs loft rooms -assuming from the outside, so the system would not be on during a hot day only during the night?
  19. A PIV system may be your best bet in your situation. This is, of course, quite different from an MVHR system. I was considering the running costs as well. Where roughly is your project?
  20. I thought that the lead could not be longer than in 1.5 meter pieces overlapped by 100mm? That's what I have always done. Perhaps someone will correct me... It's good to learn.....
  21. I think you need to be carefull about mixing different systems resulting in them not working properly. As I understand it (and I installed our MVHR) an MVHR system works by controling air in and out of the building and in the box where they cross the temprature is exchanged between the 2. The efficency is related to a few things: Airtightness including no trickle vents. Correctly sized units and ducting. Correct adjustment of the flows from each inlet and outlet. The idea behind the layout of the inlets and outlets is that the air is ducted into the dry areas and out of the wet areas causing the air to circulate. I'll let other people tell you that they have MVHR and open windows on some occasions, and have extractor fans in the kitchen. However the MVHR needs to be able to work correctly when the windows are closed and the fans are off. Remember the MVHR or the MV will run for almost 9000 hours a year and so you need it to work as effortlessly as possible. Good luck Marvin
  22. As you probably know it's air in = air out. So, do you have a drafty building? Do you have trickle vents in the windows? Do you have any other form of air being ducted into the building? And general questions which will help to understand if this is a big or small system: I guess 2 stories high? How many square meters floor area? Questions about your proposed system that just provides cool air: If in the winter ( yes another thing that it would help to know) it gets cold, would you turn the system off and if so how would you obtain fresh air? Help us to help ? Good luck Marvin
  23. You'll soon get sorted. Just plan ahead. Good luck Marvin
  24. Any idea how many times a day that would happen? Would it use and lose more energy when it's colder and the ASHP less efficient?
  25. MHVR location - utility room or garage? Can't say except that more pipe = more insulation= more cost. As commented by joth: as a yard stick not good positioning outside thermal envelope because of heat loss/gain. We have found a MVHR very good (but I'm not saying perfect) but the further away from perfect the further away from perfect the results. I would check carefully the installation instructions for guidance. Good luck.
