One our site managers called me 'the skip inspector'. That other MD I mentioned, also took to allowing a limited number of skips per project. He then found that site managers were hiring grab lorries instead....hardly buying into it. But he did spot this so it was stopped. One of our managers got the message, but dealt with it by squashing down the contents with a digger. Good idea but again hadn't got the fundamental principle. He was rather good at recycling copper from a demo though....none of that in the skip. Happy to pass on more tips on request....I got an award for it. Actually it was more for efficiency of design, but it is all waste whether dumped or used unnecessarily.
Highly recommended. we don't have one on what is effectively a £400k job. My pet subject. In my business we allocated a fixed, and low, number of skips, but also had a plan for what could go in them and what to do with the rest. On occasions I had skips emptied and refilled properly: Air is very expensive to cart to tip and pay landfill on, and the skip companies make a lot by sorting and consolidating. Site manager had to fill in a form of approximate contents.....so it became easier to think rather than dump. A couple of examples of savings. A few contractors really bought into this, and I once found our electrician's boss flattening lighting boxes and tying them up neatly, reducing volume by 90%...he then took them to a recycling centre. Another company MD (we were in a waste reduction group) banned skips on a house project and used hippo bags, allocated to different products. His surprise saving was in battens. Prior to this the roofers got to the eaves and sawed off the timber , and it fell to ground then was skipped. With Hippo bags they didn't fit so might as well take them up and reuse as cut to put in the bag. Similarly, a bag full of half bricks is fairly obvious and unjustifiable. Damaged bricks can obv be hardcore. In a skip they disappear. In our study we found that the cost of a skip is not £300 or whatever, but about £2,000 when you included materials that were being dumped without thought , or shouldn't have been bought in the first place. Timber packaging from steel deliveries we gave to schools for woodwork if we hadn't used it for shuttering. The big contractors claimed and boasted of 'zero waste'. But it wasn't true....they defined zero as 'what couldn't reasonably be recycled'.
Where for best PIR EPS slab prices?
saveasteading replied to saveasteading's topic in Heat Insulation
No reason why not, but a few lean mixes in the mixer won't break the bank, and won't scuff.- 12 replies
Post and Beam 2m over 18m is rather steep. OK but not comfortable for most cars or people. Also remember you need to level off at the road, so that uses some of your 18m. 2m over 16m will be 12.5% Kelvin, The bellmouth entrance is likely to be required as tarmac, to stop stones getting on the road. Whatever the material, if you can contrive a slight rise onto your plot then no water will run in. With option 2 a slight crossfall (as the existing slope) will shed the water off the side. If you have any abnormally steep country roads near you, then try driving them and imagine as your drive.
OK sounds unusual. Just check in the attic that there isn't a lump of chimney missing. If a fireplace is taken out to make a bigger room then then it needs a bracket in the attic, which is easy but not always done.
And delivered next day! btw, I had the family do a detailed level survey of the slab, and they found a lot more variation than they had expected. As you can't easily change thicknesses, we have gone for 25 +100, all PIR. Local hollows are being filled with screed to avoid any voids under the PIR. Also btw, the diy concrete slab with fibres has been a great success. Contraction joints cut on day 4 (pushing their luck a bit) and NO signs of shrinkage cracks at all. Recommended for ease and economy. Saved us £2,000 of mesh, plus the labour and nuisance of it, and the pour of 11m3 was done by 5 amateurs- 12 replies
I sat through many a talk by BRE about SAP, EPC and Breeam and never got a sensible answer about any queries. The presenters were simply that. The boffins I met who created the nonsense computer suites (garbage in , garbage out) didn't really understand what they were doing either, and it is they who put in the stuff about turbines, air conditioning....and for Breeam, whether there are buses running or furry animals introduced. We bought the EPC computer suite and played with it, to get good answers. Not what you are supposed to do, but showed where the junk bits of formulae were, to avoid them. Then all these years pass and .....no change. I think you get bonus points for a water turbine too, regardless of its efficiency. (See Prodave experiment).
NO. It is a gimmick and an expensive one. To put it in perspective, about 15 years ago at Ecobuild in London there were 20 companies displaying wind turbines. I spoke to every one, and they were all commercially unviable, just gimmicks. That dropped to none over a few years. I haven't been for 3 years but there was one at last visit and it was basically a yacht model, plus another fixed to a lamp-post, so it could run an led light for one night, off mains.
Dig a hole to bury the clay? clever. Advice....use your prep time to talk to people. Good tradespersons will have other good contacts. Bad tradespersons will have bad contacts. Builders merchants have business cards up on their walls usually, but that doesn't mean they are good. Look at other projects. Be cheeky and speak to the workers, and the client if possible.
Would this be a Victorian age house, or slightly later. They were surprisingly standard whoever built them, and so the chimneys are very predictable and , yes, the 2 pots on your side are yours. I agree with all said. Repair chimney and keep the rain out. Change the flue, which is the cheapest part of the work. In the upstairs rooms, are there still chimney breasts or have they been removed? Often they are knocked out and not supported.
Agreed. I can understand why people specify fancy non-shrink grout (actually expanding is better), because it is easy, pretty good, and moderately idiot proof. The trouble is you have no idea whether it is in contact with the steel or not, unless you drill holes in the plate. I have seen removed columns where there was only 50% contact. Having been responsible for say 5,000 columns I prefer as Tonyshouse says. It is lo-tech, easily done by any builder whether experienced or not as long as they do as told. Dryish mix* with small aggregate, pushed into place and then banged in with a stick against a timber on the opposite face. The flaunching gives a little more pressure into place and prevents any suggestion of edge displacement. This isn't possible though if the column is recessed and doesn't allow access....then the specialist grout is the way. * manageable and doesn't shrink. Then tighten the bolts again.
Feedback time. Thanks for the info, which was used in further research and contacts. I am very pleased to report that the local, friendly, non-national, builders merchant came out best by a bit. they beat the online specialists by a bit, and delivery their standard £15 instead of £100 or more. National BM prices silly. The published price was very much higher, but I suppose is reasonable for a single board. Always worth giving the locals a try.- 12 replies
How does your garden grow?
saveasteading replied to recoveringbuilder's topic in Landscaping, Decking & Patios
Snap an end off, and if it comes off clean, then no need to destring. If a string comes with it then it needs to be pulled off. If the end is bendy then past its best. -
Fixing plastic shed to concrete base
saveasteading replied to canalsiderenovation's topic in Landscaping, Decking & Patios
I favour chemical anchors over mechanical. I have known expanding bolts to come free after repeated movement, which wind might provide. On the other hand, chemical anchors require due care to install. My greenhouse is fixed down by 9 screws into plastic pugs, into paving slabs and has survived several named storms. For your shed, the plastic at the fixings is the likeliest weak point, so I agree as above. Square washers for fencing are very sturdy.- 5 replies
- lifetime
- plastic shed
Today I looked up the NHBC tolerances for floors. Shockingly tolerant. The 3mm over a 3m straight-edge is sensible and reasonable. But 20mm overall variation over 6m being acceptable? Therefore if you are worried about 10mm, as we all should be, then it seems you have to write our own specification.
Bitten off more than I can chew but persevering
saveasteading replied to OutdoorsDolly's topic in Introduce Yourself
these photos didn't come through, not to me anyway. As TBC says, Read. Read buildhub and search back to older discussions as most of it is on here somewhere. Read up about other projects near you, and look over their hedges. Read the Building Regulations...(in stages) : builders mostly don't. I have been in construction 45 years and am learning from BH and as the project proceeds. Every project is different. -
new windows just fitted but with issues...
saveasteading replied to New home's topic in Windows & Glazing
I must have been lucky then, or have quality windows. But noted that the conditions may state to lubricate frequently. -
How a planner got planning permission.
saveasteading replied to Tony K's topic in Planning Permission
A lot are available online, although it may need a variety of search terms to find them. I suggest looking at every one even if it looks vague, the wrong subject matter or of the wrong era, because they sometimes link in to other versions. Also zoom in as they may change map completely in the process, or have a timeline. For example a geological map may morph into a general local map. Plus Google Earth has a timeline, with the oldest maps being wartime reconnaissance photos overlaid on the map. -
Have anyone's windows failed or stuck or become squeaky inside 5 years? 10 years? Maintenance is good, but there seems to be something wrong when this happens with new windows. -
if it stinks it will do. but water it down a lot for use. -
So the floor is going in. The second half of the sub-floor area of concrete was done diy by family and friends, using fibre reinforced concrete. A great success, and who needs groundworkers, as long as you have one skilled person and 4 barrows with 4 helpers? 150mm of insulation is next. Planning on 2 layers, 100 over 50, thanks to the very helpful older discussions. as it is slightly cheaper, allows laps, and also better for cutting in isolated pipes and ducts. Then there will be 50mm Cemfloor with UFH. Maybe use 50EPS for the bottom as it will save about £1,000 and there is a diminishing return as it gets thicker. On the other hand, for a big order perhaps PIR will reduce in price enough. Any suggestions as to buying from the national specialist merchants, local merchants or the online companies? I think someone said that PIR only comes via merchants but EPS can come from manufacturers. Total area is 270m2, so pretty well a small lorry load. Perhaps that can come straight from the manufacturer and save double handling by the merchant that takes an easy fee. FYI online prices are, per single sheet, PIR 50mm £22 or EPS £11 100mm £39 150.. £62 (and sometimes 125mm is dearer than 150.)
- 12 replies
Help - Drainage Condition
saveasteading replied to bob the builder 2's topic in General Self Build & DIY Discussion
it is all explained here too. https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/442889/BR_PDF_AD_H_2015.pdf
