Yes I understand. But if there is a fire they visit and look for the cause of the spread, then don't pay. If you never have a fire there is no problem. My moneysaving suggestion is to point out the low risks, as you have, and whether the door is necessary/ a help / or a danger.
Block Paving drive issues
saveasteading replied to Fletch G's topic in Landscaping, Decking & Patios
Much as the comments above. Whacker over the surface is a waste of time. Road planings are absolutely fine instead of sub-base, unless it is very fine stuff from footpath toppings. In fact it binds better than pure stone. The possible downside would be that rain doesn't get through and away, but probably not the problem. Road planings would not compact well though without care and attention due to the sticky surfaces, but would later under wheel loading.. The usual issue is lack of compaction. Digger drivers generally assume that driving over it with their tracks will compact it , but it won't. Neither will a whacker plate do much other than the very surface. Also most groundworkers put down too much thickness and the bottom remains uncompacted. More explanation upon request. 2 options. a proper job requires you to relay the sub-base in thin layers. 50mm suggested if a whacker plate, (rather than a vibrating plate which wont do much). Then the sand bedding and blocks, using vibrating plate.* OR at your own risk. remove the area of sunken blocks and relay sharp sand to the required higher level, perhaps with a bit of cement in it. There is a strong chance of more settlement esp as it is tricky to predict how much the new sand will compact. But this would be f few mm. Also be aware that blocks never go back in the same are and you will have to grind some edges off the last line to go back in. Perhaps 20 years ago, the standard design for driveways was blocks on sub-base. But then they changed it to having a layer of concrete or tarmac beneath, as problems like yours were becoming common. * £299 from Aldi plus compulsory delivery charge, and the same machine is at toolsation for £600+. nice profits there But aldi wot deliver to Inverness, even though they have a store there. -
Because Always assume an insurance company will try to find a reason not to pay up. If you don't do what the BCO requires then it is minor only in extent of works, not in risk of fire damage. My point really is that you could fit sprinklers, fit alarms, do a special door, and whatever else was suggested, all of them, and all the bco wants is the door. OR suggest the interlinked alarms ( which are now standard in Scotland) and ask if the door is still needed. I say this with some growling from the distant past when one fire officer insisted on some special measures in a particular situation, then another took over and required something completely different and discounted what his colleague had wanted. ie get the simplest/bes solution agreed by the person who matters, ie the bco. But take it out again at your own risk.
And may block up and need redrilling. If the supply is clean then it requires very little treatment. Ours emerges from a hillside with forest and moorland above. Even the theoretical dead sheep on the hill problem would be filtered out before the spring.
Is it worth asking the bco whether, if you fit the fire door you can ommit other precautions? I wonder what the insurance position would be if you remove a specifically required door.
It has lost the protection that the concrete gives to the reinforecement, so wll rust and fail over a year or 2. Cement paste or external filler in the cracks may give it some more life....but if the same has occurred underground then it is doomed.
We are having that, kitchen, stair, living room with no doors. Scottish rules, so interlinked fire alarms, and fire escape skylights. No sprinklers. Ceilings fire proof. If i didn't agree this was sensible then we wouldn't have proposed it. Early warning is fundamental. Too many designers can be a problem. Even 2 different fire officers or bcos will disagree and you end up with everything conceivable. If there was to be a fire in the kitchen, better hear and smell it and evacuate than it build up behind the closed fire door....in my opinion.
Possible unauthorised development notice
saveasteading replied to craikhill's topic in Planning Permission
I don't imagine the planner is looking for work. If you can show that the replacement is no bigger then that should be ok. Especially (though unlikely perhaps) if the old building was never completely removed, it is more like repair than replacement. It may be more about the use than the building itself, so get rid of the mattresses and personal effects of your tenants or slaves, and park some barrows and tools. Seriously, if it is an office or some such, or has plumbing, they might not be happy. -
A fire isn't going to burst through 40mm of oak. BCO may not understand or accept that though so new, rated doors seems the only way. Whichever pair of doors you use, the actual risk is at the joints so intumescent all round and at the junction. In fact your nice new doors would benefit from a latch to secure one of them, and add a stop, and the works in fitting seals will then be easy. Is the BCO expecting door closers too? Not much protection if standing open. This seems extreme so I assume this is not a standard domestic situation.
Google Earth will prove the previous iteration of the building. That will make it easy for the visiting inspector. That, and no signs of habitation. Just in case you don't know, click on the year and a box should appear showing a list of years, then click for multiple aerial views, sometimes back to Luftwaffe pictures. The officer should of course have done this already. -
Me too. You could still run a secondary supply very cheaply for gardening and car wash, and this could also fill the fifighting tank. 10m3 at £1.50 saved already. More importantly the water company will probably charge you for waste water, which presumably there will not bf, based on the water purchased. You must tell them that there is no waste and no runoff.
How does your garden grow?
saveasteading replied to recoveringbuilder's topic in Landscaping, Decking & Patios
Encourage ladybirds. Check what the larvae look like so you don't remove them The easy solution is to wash the blackfly off with a hose spray. They don't have much grip and if they can climb up again (I doubt it) then they are slow and you do it again. The ants will protect them. -
That is our decision too. It will normally be far too much, but the flow slows in summer and the big tank doesn't cost much more. Also if ever the well ran dry, this would be a useful volume to bring in by tanker. We also need a 10,000 litres tank for firefighting as there is no hydrant nearby. Water not tested yet but the neighbours survive and so do we. Frost. A long pipe will be vulnerable to freezing, so keep it buried and flowing.
Depending where you are...e g. .there is similar rainfall in Inverness and Tunbridge Wells. But the former has more wet days and drizzle, so the tank is more often topped up. The latter has more downpours so a small tank would overflow and lose the available water.
Building inspectors do some spot checks but are not expert on everything, and don't work for you. So please continue to check up yourself.
We should have installed air conditioning… now what?
saveasteading replied to Adsibob's topic in Other Heating Systems
Can't do much better than that in this case I suspect. -
Yes and that is good for blackout , but not what you want in the room to keep it cool. Reflect it back out. External blinds are tricky especially as retrofit. French style shutters? -
A notch or hole near top or bottom will greatly affect the strength and bounce, unless near the end. Just being a single hole isn't the point. Joiners and plumbers don't usually appreciate/understand this and can be dismissive. However in this case it is reasonably far up plus the additional timbers are adding to the strength.
Diy? Yes of course you can, if you have the skills and knowledge. Do you? How do you know that you do? Green roof etc. I have "green credentials" but never used a green roof where i had control. I would be telling the planners that you had considered it but discounted it on terms of....whatever. In my cases it was usually on the grounds of cradle to grave not actually being justifiable....or maintenace,...or safety. Fundamentally it requires a lot of extra structure, and after it has grown it doesn't reduce carbon. Trees are good. Shade in summer. But not the big varieties or the founds have to be deeper.
Silver or white internal blinds help significantly: more than I can logically explain. I suspect the main difference is in reflecting a large proportion stright back out as light. Perhaps the local pocket of heat also resists transfer. -
I was once persuaded to use upvc sprayed grey (by the manufacturer) It turned lilac over 4 years. Fortunately the school client didn't mind.
INTERNAL WALLS FINISH
saveasteading commented on Patrick's blog entry in Timber Portal Frame - but stick built
We are using 9mm everywhere it is needed. Feels totally solid and adequate. -
Stud wall sound insulation question
saveasteading replied to jfb's topic in General Self Build & DIY Discussion
I had never heard of this. Great idea for closing the weak link in a wall. Any permanently flexible putty would do for a one-off. Plumbers mait? -
I don't agree. Sound insulation isn't dense enough to transfer sound by impact/reverberation through to the next room. In any case the stud is probably doing that. For higher frequencies and especially airborne sound, keep the full thickness. Especially make sure the full area us filled to the edges as sound leaks through gaps. -
Screws for Oven Handles
saveasteading replied to Ferdinand's topic in Kitchen & Household Appliances
You must join the club of salvagers of handy screws. These things tend to be fairly universal so you need a tin of screws. Seriously, I find 9/10 that I have just the thing.
