MikeGrahamT21
Everything posted by MikeGrahamT21
Dot and dab plasterboards on wall by any chance?
Are these (leaking) Velux installed correctly?
MikeGrahamT21 replied to sniederb's topic in Windows & Glazing
The tiles under the flashing at the bottom of the window haven’t been prepared properly by looks of it, you are supposed to chamfer them to reduce the amount they stick up to increase water run off, this is done at a horizontal plane… hope that makes sense? from a non install perspective, give everything a good clean, and consider replacing the seals -
Rather than totally diverting the flow entirely through another radiator, would it be instead feasible to use 2x reducing tees on the main flow pipe out of the boiler, keeping the 22mm straight through, with 2x 15mm pipes going to and from an additional radiator? I've had a look at heating pipe designs, and think this small section would fall into a 1 pipe heating system with bypass, with the remainder being a 2 pipe? Would it just mean a slightly prolonged heating period for the additional radiator on the 1 pipe? Alternative to keep a two pipe would be a total diversion through the radiator before manifold, but then going through a 1/2 valve (which would be permenantly open) would this lead to too much pressure loss? I'm thinking using the 1 pipe with bypass may be an ideal neat solution for a little extra heat in the one room which is struggling?
Mitigation for potentially shrinking PIR board
MikeGrahamT21 replied to Beau's topic in Heat Insulation
There are products designed exactly for this, though quite expensive https://gapogroup.com or you can opt for what most do on here, as I have done, get it as tight as you can and inject some flexible expanding foam around the perimeter and joins, which will move with any shrinkage. it’s hard to say just how much PIR will shrink over time, seen some photos of crazy shrinkage, I’ve installed quite a bit in my place over the years, closed stuff off and gone back to do other work and it looked the same as it did when I put it in, 10 years down the line. It’s possible that there have been many bad batches -
+1 for ATAG, mine has been flawless since install
Steico flex 100mm WF compression tolerances
MikeGrahamT21 replied to sb1202's topic in Heat Insulation
It’ll be a variable vapour control layer, during the warmer months it allows moisture to pass but not during the colder months -
Wow, yeah just a slight gap! lol Had a look other day with the Thermal Image camera, and could see a point on the bottom bar around half way where the temperature differed on each side, so I'm guessing there must be a flow restrictor in there. The big ones of these are 8 bars wide, the first 4 bars were slightly hotter than the second 4 bars, which married up with the point where it seems there is a flow restrictor, so it seems in my case this may not be the issue, and the whole of the rad generally showed quite evenly hot. If they ever come off for any reason, i'll be sure to check this, very useful thank you
Musty smell, worried about interstitial condensation
MikeGrahamT21 replied to Archer's topic in Damp & DPCs
Its certainly been cold this past month, especially for the amount of water involved in plastering. I feel any mould and the smell has come through rather quickly, even given that scenario. Are there are plug sockets/switches on this stretch of wall that you could maybe remove, and have a chance of some additional investigation, whether that be with a camera or just your sniffing gear? https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/1019707/iwi-guidance.pdf This may help answer some questions, one example which may be appropriate: You may have inadvertently left a small air gap between your insulation and the old plasterboard, giving a space for condensation to collect. Was the original wall completely flat? I've been through a few guides for retrofitting and none specify that you have to remove any plasterboard before application, its not recommended however, the emphasis is on ensuring no gaps are present. How about getting in touch with British Gypsum, or Kingspan and ask for a potential solution for IWI, with existing plasterboard and see what they specify? Examples of differing opinions: https://www.kingspan.com/gb/en/knowledge-articles/can-you-fix-insulated-plasterboard-to-existing-plastered-walls/ (though this is from 2022 and guidance has since changed) https://insulationgo.co.uk/blog/insulated-plasterboard-over-existing-plasterboard -
Expectations around MVHR
MikeGrahamT21 replied to IanofEpping's topic in Mechanical Ventilation with Heat Recovery (MVHR)
First off, you can continue with carpets and doors as you've suggested, this is normal practice for MVHR ventilated homes. What sort of temperatures are your bathrooms at currently? My bathroom tends to sit around 22C and any condensation clears really quickly, its quite a large space so have 2 extract vents in different locations with 1x 75mm flexible pipe into each. The soft gentle airflow from the vents is how its supposed to be, its an incredibly low throughput system that does its job by doing both the push and pull of the air on its own, rather than traditional extract which creates low pressure which has to be balanced from air leaks. I would not expect an MVHR to be whistling under the doors, that in itself would be wrong. Please take some photos of your MVHR install so we can spot any errors!- 13 replies
Target temp is 18.7C which I find more than warm enough, today is another miserable day but milder, and already above this target. Overnight i've had it set to Off for some years now, which works in most cases, its just the cold cold days where it struggles a bit. This year, from 1st to 28th (so far), this room has consumed 347.51 kWh in gas according to the Tado calculation. I'll have a mess with overnight temps rather than it being off completely, and see how it compares. There are 4 controlled zones, Dining room (this one which also includes snug and kitchen), Bedroom 1, Living Room and Garden Room (includes Bedroom 2). Other zones are Utility and Bathroom which just act as bypass radiators taking whatever heat they can whilst the system is on. I hadn't heard they were poor, they were amongst the highest in heat output when i was looking at new rads for a given size. Wouldn't be able to swap for anything else really as don't want to mess with flooring and break airtightness, so restricted with width. There is the possibility of getting a triple version of the vertical, currently have double. This was the calculation I did a while ago, but the flow temperature has been reduced 10C compared to 55C which i was originally aiming for. Having lived in it, i don't think it needs a huge amount more output, which is why I was wondering if a small radiator branched off of the flow run would work, and not compromise flow to the rest of the system? And this is more future planning than anything else.
I have one area which is quite large in total, covered by a fairly big double vertical radiator, i was hoping once i'd finished and everything was fully insulated and sealed up, it would be up the job of heating the whole space, but I think the kitchen lets it down (furthest away from the rad), which is dot and dab (which i've tried to foam behind, but still get air leakage, probably due to thermalite blocks shrinking), and poorly fitting spot lights (which is on my to-do list), with 4 double glazed circa 2011 velux windows. Heating graph shows a fairly normal, dark winters day: When its sunny the thermal gain is good enough to help heat the room quickly: I've no more ports available on the manifold, and the days of taking the floor up to feed pipes through is now gone, however I've had a thought, and wanted to know whether it was feasible... So the boiler is on the wall right next to where the kitchen is, and i'd wondered about drilling two holes through the wall and tapping into the 22mm flow feed (which goes to the manifold), and making it another bypass radiator to go with bathroom (though this goes via manifold). Had a look and found some 22mm valves, with a 3/4" inlet fitting, but radiators with this seem few and far between, will keep looking. Boiler Flow Pipe > Small Rad > Flow Pipe to Manifold > to rest of rads > and then Return back to boiler Another idea, which would give out much less heat, would be to make a radiator from 22mm copper pipe. What I want to know is basically is this feasible? I'm thinking it could impact flow rates to the manifold hence why i've gone looking for large bore fittings? Any one ever done anything like this before? Radiator sizing would have an output of between 1000 and 2000 BTU, just pinching a small amount of energy on its way to the rest of the bungalow. Just to add current flow temp is set at a max of 46C, but my Tado optimises this based upon the weather, and it generally sits around 42/43C. Of course this could be turned up which would help, but i'm trying to future proof in case I have to have an ASHP at some point. Thoughts? Cheers Mike
Advice on prepping/painting over interior mould/damp
MikeGrahamT21 replied to Dee's topic in Decorating
Yeah, white vinegar is a traditional solution, but a proprietary mould remover is also ideal, just not bleach -
probably a bit late, but bleach on mould is a no-no, it doesn't get rid of the mould, just hides it away. Use a purpose made mould killer or equal parts white vinegar and water solution to properly get rid of it, leave it to sit for an hour before wiping, and don't forget to extend the treated area beyond the bit you can see, for all the bits which aren't yet visible to the eye. -
Looking for recommendation for Triple glazed Windows/doors.
MikeGrahamT21 replied to ClairedM's topic in Windows & Glazing
I'm pleased with my windows from Modern UPVC Windows, but I self installed. They do provide installation now however: https://www.modernupvcwindows.co.uk/ -
Mine is like that and have no issues. I have an AAV outside, so after all of the connections on its way to sewer
Mortar mix for pointing granite.
MikeGrahamT21 replied to sb1202's topic in Bricklaying, Blockwork & Mortar
Doesn’t look lime based, not light enough. as @nod said, 4-1 sand and cement will be ideal for granite -
Consider how your thermostat is connected too. The gradient (unless I’ve got the wrong gradient meaning) which @JohnMo speaks of is relevant when the boiler is connected to thermostat via an analog method (on/off), but once you connect via digital (opentherm/bus) the thermostat can then take over, and it’s basically weather compensation, a heating curve which tells the boiler the flow temperature for a given external temperature. how is your stat connected?
Some boiler controls have a hardwired minimum burn period, I know I’ve read it for Tado which I have, and I think this was set at 3mins, so maybe worth checking which the manufacturer of your controls. another thing you could try is seeing if you can turn down the pump speed on your boiler, I read about this whilst reading the Tado stuff and it can help with short cycles, with a few additional benefits, less pump noise, power consumption and presumably it’ll help it last longer. Most boiler pumps are preset for max pump speed from the factory, and with your oversized boiler, turning it a lot lower may be a really good idea
Soudal flexi foam is another product in the same category as IB330
New roof / Major condensation.
MikeGrahamT21 replied to Sparky321's topic in Roofing, Tiling & Slating
Yeah I know that’s what the guide shows but was meaning without the pipe, sounds like they’ve been installed correct anyway. Cross ventilation will be the key here, as ETC says, get some air flowing through the eaves, many different ways of achieving that
