MikeGrahamT21
    1
Everything posted by MikeGrahamT21
  1. Something like this would be ideal, cut to the relevant dimensions and put under the existing sill https://ewistore.co.uk/shop/external-wall-insulation/over-sill-2-5m-100mm-depth/
  2. Definitely fill the cavity which will end up internally, which will help to prevent the chimney effect of heat loss
  3. Looking at your original photos, it’s definitely an improvement how it is now. You will find the white powder appearing (efflorescence) as they dry out, and as they’ve been wet for so long this is bound to happen, keep brushing it off with a stiff brush to keep it to a minimum. when I dug out to do external wall insulation below the DPC, I went all the way down to the foundation and it took around 6 weeks of fine weather for it to be completely dry, it will take some prolonged time especially at this time of year when it’s cold and damp most days
  4. Yeah that’s right. The top guides on my unit can be moved slightly by hand so no load there at all. I was originally told that the bottom track supported units were more robust and also didn’t require any special lintel loading calculations so went with that
  5. I can honestly say I like mine, but my opening is only 2m, I would imagine with the amount of leaves you are planning as above it could start looking quite cluttered when they’re all stacked up fully open, and may well look cleaner with a sliding door, but if you are set on bifold, then yes they are good, as with most things, if you get a good one. Don’t get top hung as they aren’t as robust as ground bearing. If PVC, Liniar modlock are very good, what I’ve got, 10 years in and they’re as good as new, just don’t get chrome hardware outside!!
  6. They look very much like london bricks, as were widely used at that time, which are quite a soft and porous brick. Clear a bit more out of that trench, and then you're going to have to give it some real good time (and fine weather) to fully dry out, then it may be worth applying some brick protection, which allows the bricks to breathe, but essentially makes them water resistant. Of course also make sure the pointing is sound before filling the excavated area up with some gravel or a drain.
  7. Yes i've noticed Eon rates have gone down for export, i'm on their fixed Export Exclusive V2 at 16.5p, but the V3 one currently the one you'd be put on is now 12.5p
  8. I mean as annoying as it is, it was going to be changing to CPIH in 2030 anyway, so only looking at around 4 years with lower increases. the shadow pricing would be the one which would be an absolute no-no, that would mean no more yearly increases inline with inflation til the mid 2030’s. It’s would be technically difficult for them to achieve and therefore expensive so hopefully if any it’ll be option 1.
  9. Plenty of ways to meet insulation standards of today, not sure a whole load of steel is very ecological or economical, but as you rightly say you can add internal wall insulation, as long as you achieve the stated U value requirements with your build up then you are good. Just don’t forget to have the cavity pumped with blown beads too!
  10. Isn’t the 3m3/m2.h number related to this… It’s talking about carbon emissions rather than overall efficiency, of course the lower the ACH the better it will work but also doesn’t mean it won’t work at all. https://www.passivhaustrust.org.uk/UserFiles/File/research papers/MVHR/2020.04.27-The Case for MVHR-v7.pdf it is expensive though, I’ll give it that!
  11. I go into panic if I’m spending more than £4 a day 😬 but then I think that’s more part of being a Yorkshire man!
  12. I suspect you’ll probably need a G100 compliant export power manager style device, to limit your export to agreed limits
  13. What size, type is your property and how well insulated is it?
  14. A chimney breast will have zero issues holding 25kg, an almost negligible amount given the load capacity of a double brick chimney breast. your fixing strategy is over the top too, a fixing either end would work fine, and I’d probably up that to three (one in the middle) to stop the timber sagging. Don’t bother glueing the timber to the wall, as you will only be glueing it to paint/paper. the majority of these pre-made timber mantles actually hang on the wall much like a picture frame
  15. If your BCO are like mine, they haven't a clue what MVHR even is 🤣
  16. You shouldn't need to change the flow rate, thats what the actuators are for. I don't have actuators on my manifold, and have to turn the clear plastic tube to alter the flow rate, but yours definitely don't look like mine. Probably worth a call to nuheat, or see if they've a manual online?
  17. Yes absolutely, they sell kits for this which will come with the relevant butyl seal. im sure if you can get the glass dimensions you could probably do it even more DIY for much less by ordering the glass (ensure correct spec) and a roll of butyl seal. you’ll need to buy the same dimensions as it has currently, I think they did used to sell a triple glazed upgrade for the older windows but it only resulted in a 0.1Uw decrease so probably isn’t worth the extra cost
  18. From memory the Redland 49's are slightly curved, they look like Marley Ludlow Plus to me, which are flat from top to bottom
  19. I too have had this over the years, I can only think that the paint isn’t as flexible as the caulk, but I don’t remember it doing this many years ago so something must have changed either in the caulk or the paint makeup. I don’t have an answer for you though, I have just repeatedly applied paint until it covers it up, but it does take some goes to get rid of it completely. any decorators on hand to help?
  20. Compatibility for the battery BMS, but as long as you follow the battery specs you can always setup your inverter in a custom config to match it. LiFePO4 are not the kind of batteries you find in e-scooters, they are currently the safest ones you can buy, but that’s not to say they are perfect. if you are storing it externally, you need to also consider environmental factors, heat moisture etc, far better for the battery to be in a constant environment. I’ve had my pylontech batteries in the boiler cupboard for 4 years now
  21. The onus for any regulations is always on the home owner, though the builder/roofer should have advised really. I wouldn't worry about it, you can try and get a retrospective one, at least everything the BCO will need to see is more or less visible, or as others have said, a simple indemnity insurance policy when/if you sell
  22. You'll need a G100 compliant inverter, some of the Solis ones are properly compliant. There are also export power managers which sit seperate as the G100 device, Solis also do one of these, but i'm not 100% how they work, as i don't have/need one. They'll probably enforce this too, so they'll come out and do a compliance check.
  23. Think the general consensus is rather than use expensive PIR, use double the amount in EPS, and minimise the amount of hardcore underneath and concrete on top will save you a small fortune and likely give a better result overall in terms of insulation. plenty have done it on here, so sure someone will be along shortly to advise.
  24. But how dry was the bone? 🤔
