Oz07
Everything posted by Oz07
Capital gains tax
Oz07 replied to Joe Naughton's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Would the capital gain be calculated on what you paid or the rise in value since you moved out? I would guess in this case if op has split the garden then perhaps there is not such a big gain regardless? -
I agree is worth it however paid more like 130 cu. Did away with need for pump we pulled it 8m with rakes easily
Capital gains tax
Think you're good to go. Just double check the time period. At worst the new bungalow could always sit "empty" while you still live in old house while it sells -
Just seen bull float mentioned we have only ever raked then dabble barred
Used it quite a few times now. Brilliant stuff does self level to an extent but needs skilled bloke to get spot on. Never had to latex a floor done with it yet. Tarmac have binned all their reps round here. I've got a 9m3 pour next week using a competitors product. Paying an ex tarmac rep 35 per cu to lay with me.
Working platform suggestions - internal blockwork
Oz07 replied to Digmixfill's topic in Tools & Equipment
God help us -
I tried to get quotes without zoning. These people are off their heads if they think you could have any noticeable temperature difference in a well insulated house. For some reason they don't seem to agree with this school of thought. I think the expanding tape will be good for around pipes, but you could pick up a small roll from a merchant yourself.
OP just as an aside if you check your planning a lot of the time it will be worded such that- IF gates are installed. Do you actually want the gates? Not seen many conditions insisting on gates. It's more to do with the setback.
Neat boarding
I always water test. Bit of a luddite but you know what you know. Just remember to put some longer stubs on when doing as your supposed to create 1m of head. I don't think I've ever had an all plastic system lose any water yet. Pretty much foolproof. Even those flex seal couplers are pretty much 100%
Cant tell if joke or...
Id have thought 100mm gravel be fine but by the sounds of it you want your surface water drains deeper to mitigate any protection on top of these
Bit strong surely. Don't we all have enough to do? With respect @JSHarris you might have found it easy to prepare all the technical details and sap but for us mortals it's harder than you make it seem! I prefer to send the technicians drawings back to him constantly for revisions. Think I've made it to revision G before now!
The right tool for the job or just a right tool.
Oz07 replied to MikeSharp01's topic in Timber Frame
It's the rulers which allowed for metal expansion/contraction which my beef is with! -
Your place is a tardis isn't it
@Roz how has this progressed? Any pressure tests since installation. As an aside, how come dpm detailing is so finicky then you can go and bang ufh staples in?
Might help if you give location I know it can be done remotely but still
Pleasant welcome @nod?! Hi @Laith J were not all that blunt. Even some Welsh here!
I set out some joinery in a workshop once with a pattern making rule. It was only on something small as the rule was only around 300mm. What a cock up that was. Old boy was a pattern maker in his day, why he bought that rule into a bespoke joinery workshop ill never know. -
They do try and bully you into adding water nearly had an argument on last job. Was being pumped as well. I'm sure less reputable firms do it because they know their mix probably isn't up to scratch anyway, so they want you to add water so you sign the disclaimer.
Current approximate prices for plastering?
Oz07 replied to gwebstech's topic in Plastering & Rendering
Think it's more to do with skill shortage and lack of training. Maybe too many academics! ? -
How do you find the upstand can't see it online
I think 27mm board would be likely to cup. I used 38 on last worktops at 600, did everything by the book 3 coats on all surfaces, biscuit jointed the joints and they still cupped. Urgh...
I've now got opportunity to do this as drawn above. Rather than take the DPM up the outside of the block though I would probably just cut it an inch or so into the cavity then fold down. Wouldn't get damaged on site as these blocks be laid from the outside. Remembering I have a secondary DPM ontop of insulation I can't see what I have to lose apart from making the first layer easier! Any more thoughts? @Brickie? @PeterW? @Declan52
