Oz07
    6
Everything posted by Oz07
  1. Oz07
    Trees!
    @ProDave don't forget you've got a suspended ground floor with void which helps I understood some sycamores to be strong rooted. I built within 7m of a London plane. 1.5m deep. 1m of clayboard never had any problems and was a lovely tree
  2. Really? Still? You're near me aren't you
  3. Check it out but usually you get 5% vat on over2 year empty properties. No reclaim scheme though so has to be invoiced through contractor. Ok if you have your own firm not so great otherwise. I'd prefer starting from scratch but you'd have to do the sums
  4. The heavier flush or patterned doors are just as expensive as the oak atm. The firm's are all geared up for knocking out the oak cheap as they can
  5. Outside would be 1 brick lower if you are extending dpc across the cavity, creating a fall outwards, with weepholes. Not sure on the specific requirements for this, i've had to do it before as BCO suspected methane could be present (not radon). It's not normally done with the floor DPM anyway if spanning cavity, usually a roll of DPC as you say.
  6. Ask them if they have sorted through the issues with their spray shop and lead times
  7. You can leave the perimeter at existing ground level and demonstrate your 1m depth off this. Providing you've scraped all the veg off. They don't expect you to take foundation level from reduced dig level
  8. @Vijay no disrespect think you've got the blinkers on with regards to trying to marry your open webs on floor joists and attic trusses. I'd not worry and go for timber. Like you say plenty of room in eaves for services
  9. point it out now to the builder
  10. Oz07
    VAT
    I think a lot of nods work is to other VAT registered contractors so doesn't really have much impact. They reclaim Any way. That being said I wouldn't apply vat on part of the invoice. All or nothing
  11. Oz07
    VAT
    How so the percentage is added on isn't it? It's not as if the margin will improve if vat at zero. Or am I missing something?
  12. On the bright side it all sounds fixable with the help of you guys. Another problem bites the dust!
  13. I usually find pipe wants to be around a inch off finished wall to accept pan connector. @Nickfromwales is there a standard for pan connectors?
  14. Had access to twin drum but like you say probably sensible to spread it out and go with something smaller
  15. Interesting thanks @MikeSharp01 I was going to go for full 150mm depth compaction with roller in one go. obviously was going to bed in 10mm and cover in 10mm too
  16. Got some drains to put in below a ground bearing slab. One long run ends up only 50mm ish below the top of the sub base (to top of pipe), other two should easily be 100mm minimum. Owing to the depth and the fact that these drains will start out in the sub soil but rise up into the sub base whats the best method? Install drains before spreading sub base. Keeping drains surrounded in pea gravel as per norm then compacting in one go (roller) Get sub base spread and compacted with roller, then re dig out channels for drains. Option 1 would be my preferred. I'd just be wary about loosing any of the fall with compaction. Is this a valid concern or will it only be the subbase compacting around the pipes? Would it help if I played planks over the pipe runs and missed these with the roller and went over with a smaller plate? Option 2 would be a bit messier and kind of doing things twice, but i'd be 100% sure of the fall on my drains then.
  17. So if you don't want to go through again but don't want to stay forever where will you be next? Taylor wimpey?
  18. Yeh that's about as far as my sums got before I had to rely on collective knowledge of forum to advance my understanding cheers @BuildHub
  19. Yeh cheers @PeterW No way is a floor slab at 100mm and partitions plus live loads going to equate to 2t per m2
  20. Kpa into kn though? It's too much for my head!
  21. Thanks Peter. Obviously mine is less structural not holding walls etc up. Jablite guidance says eps70 residential eps100 offices eps300 factories
  22. Cheers Jeremy. I got a ground bearing 100mm conc slab to be around 250 kg m2. This excludes any partitions and live loads but sounds a lot less than yours with me having traditional strip founds. I just couldnt understand that 1% and 10% compression performance if I can't find it's maximum bearing figure. Is the clue in the name ie eps70 can handle 7kn m2?
  23. Going back to EPS bearing capacity. How do you choose what grade to use for ground bearing concrete slab. If the U laves stack up with EPS 70 is there any reason to increase the grade? Can EPS 70 support 100mm of self compacting concrete slab?
