Alan Ambrose
Everything posted by Alan Ambrose
Sounds a fantastic project. Welcome … and can we drool over a picture of it please?
>>> Can imagine 6mm cement board sheets being quite fragile to handle. They're really quite tough, although you can shatter them. Also heavy. You need proper carbide tools to e.g. cut a 100mm hole for a pipe. I have some bits of board around if you want to experiment.
Planning Appeals - Statement of Case Examples
Alan Ambrose replied to phykell's topic in Planning Permission
>>> the LPA cited case law I would be interested to read that - presumably they quoted case references. They cited case law in the rejection of your planning application already? Next step is for them to file their statement of case, and then both parties can submit final comments. Don't hold your breath. FYI my LPA ignored the planning appeal procedural guide ( https://www.gov.uk/government/publications/planning-appeals-procedural-guide/f90d5f21-de2c-43cd-b743-6c81b9a1b70f ) in its statement of case and (a) bought up new issues, (b) didn't summarise the issues in dispute as required. When challenged, the inspector said words to the effect 'what can you do, it's only guidance' and allowed the LPA's new issues and their V-sign to the guide. He did award me costs though. If you detect any LPA dodginess, then file for costs (the principle, not the amount) straight away and keep a record or have some way to know how much time you and others have spent and therefore justification for the costs amount. -
That's weird, there are loads of items on the land registry that say 'land 40 paces west of the duck pond' or somesuch. Maybe a new rule. Ask your lawyer what LR suggests for a block of land that doesn't have a street address? Most land doesn't unless it has a dwelling on it (and never will).
Oak frame staircase, connecting to an oak balcony
Alan Ambrose replied to AlanUK's topic in Timber Frame
>>> My builder assistant thinks that dowelling and glueing will be sufficient. I am minded to use stainless steel threaded bar and nuts/washers. Traditionally a dowel or two only, no glue - say, 20mm. Huge oak buildings used to be built with nothing but woodwork joints and dowels. Taper it a bit so it's a tight fit when it's malleted in. From memory, you can do something clever with a slight oval so it pulls up even tighter as the oak dries out and shrinks (although that looks like dried oak already). Or sure, biggish SS bolts, threaded rod, coach screws etc. A4 SS because oak is quite corrosive. Anything of the size that looks right (M10-M16 say) will be crazy over-specified for the shear load. -
Hot Spring ground source heating
Alan Ambrose replied to AllenCherry's topic in Other Heating Systems
>>> don't buy Stuart Turner! We have two ST dual monsoon pumps, one 30 years old, one 20. Both run off and on all day. No problems at all except for a few pressure cylinder replacements over the years. Last time one failed, I replaced them with cheap off-the-shelf vessels and they’re lasting well - last time was 10 years ago. ST had got a bit smart-arsed about the ‘maintenance kit’ costs. So, at least for that product, at that time, they were good. -
Brise Soleil - how I learned to stop worrying and love the metal
Alan Ambrose commented on mike2016's blog entry in The Fun Irish (House)
That’s tough, one of those hardscrabble jobs that needs thinking-on-your-feet skills. Is the angle of the vanes important or just an aesthetic choice? -
>>> Can you self-cert/install Yes, I did. Sent drawing beforehand and a short doc with installation photos after. Suspect much more ‘professional’ than a typical HETAS install - maybe they don’t supply anything to BC.
Thinnest cement board then which will give the fire rating? 6mm I’m guessing. £16 a sheet.
Dimensional Tolerance for Setting Out of Electrical Outlets
Alan Ambrose replied to PLK-UK's topic in Electrics - Other
Sounds BS to me. Ask them for a copy of the standard or reg? -
I’m guessing NZ? FYI Mine water could heat thousands of Welsh homes: https://www.bbc.co.uk/news/articles/c0l867k70p8o Between. 10 & 20C though. That doesn’t sound so encouraging .. according to PHPP my average ground temperature in 9.6C. -
I walked past a kind of modernist design in Nudura at the weekend near Middleton. Half-completed. Looks like a self-build but I don't remember it mentioned on here.
@marshian - that counts @DIYHacker kidding me? We're in Witnesham and another BH guy here lives in Otley.
Best option for dropside van?
Alan Ambrose replied to Bancroft's topic in General Self Build & DIY Discussion
Probably doesn't help any, but I'm leaning towards a transit, preferably with a high roof ... and getting all the aggregates delivered. -
Call me dumb, but the PD won’t actually be designing anything in that case?
Whereabouts in Suffolk are you? We may be winning the county race 😄. We have: me, @LSB, @GaryChaplin, @zzPaulzz, @Nick Laslett, @G and J, @JohnnyB Apologies if I've missed anyone.
Well looks like they have found a useful niche...many thanks.
>>> I found EA good to deal with directly in the past both for advice and site visits. Jeez, I'm on 18 weeks and reading their acknowledgement letter more carefully it says: "Your application should be allocated within 6 months..." !!! FFS. This is for simple output from a treatment plant to a ditch that the rest of the neighbours are using.
That’s interesting re safescope - do you have a sense what they will actually be doing?
>>> the chat bot is talking sh*te Yes, for a random lvt: https://s3.amazonaws.com/a.storyblok.com/f/231903/x/e64b397b14/amtico-signature-technical-specification-sig-ts-20240731-12-en.pdf it says: 0.014 m2K/W (underfloor heating suitable) - for a thickness of 2.5mm i.e. conductivity of 0.18 W/m·K, u-value of 71. A random web site ( https://www.vcalc.com/wiki/thermal-conductivity-of-porcelain ) gives porcelain as 1.5 W/m·K and porcelain flooring tiles are 12mm from memory, so u-value of 125. i.e. not a lot of difference in the scheme of things and they're both v good thermal conductors in building material terms. The big deal with chatgpt et al is that there is no deductive logic there - in fact no logic at all. I'm tempted to suggest that is similar to the quality of your salesman. If it finds the word 'Alan' close to the number '125' often enough it will be happy to conclude that most 'Alans' will be 125 years old. Ask him to do the above calculation to verify his thoughts?
Looking for advice and help for a shed/workshop
Alan Ambrose replied to jobe1972's topic in Planning Permission
>>> the process of getting planning permission could cost more then a cheap shed The cost of householder PP is £258, so I'm thinking the OP is thinking of something not a million miles different from this: https://www.screwfix.com/p/shire-6-x-8-nominal-apex-overlap-timber-shed/644TJ Given this will last 5-10 years max, @DevilDamo are you suggesting the OP needs to apply for PP every time he wants to replace it? Even if it is identical to the last one? -
PV panels are often fitted with little screens on the side for exactly this reason. You can probably find some to retrofit..
I think if the old shed didn’t collapse in the last century, and the old one didn’t look crazy different to the new one … then you’re just ‘replacing the old one’, which is fine. I think I might just do this and see if anyone objects. If you’re in a conservation area, I might be a bit more circumspect.
