Alan Ambrose
    15
Everything posted by Alan Ambrose
  1. I’m in the process of buying a van for the build and looking for a cheapish way to do car insurance. Me and the mrs have 2 cars already. Now, I can’t drive a car and a van at the same time (so, it’s mostly the same risk) so I’m hoping there’s a cost effective way to add a 3rd vehicle. Also there’s some complex stuff re no claims bonuses and multiple vehicles? Anyone figured this out? I understand car enthusiasts who have lots of cars have a way to do something sensible. Anyone figured this all out?
  2. I might have been clearer - there’s a gotcha on self-build exemption of CIL on a 2nd application. If you’re building a bunch of units then self-build won’t apply.
  3. >>> It's a ground floor. Ah, I wonder if you have any idea what’s underneath and whether there’s any insulation at all? You can guess based on the age of the building or core drill to get a better idea. For rooms that get intermittent use, you can heat only for the hours you need to use them, but that may be less possible for rooms that are more occupied. In the worst case (concrete all the way down) you might like to get as much xps/eps insulation in as reasonably possible.
  4. In your shoes, I would send both applications in. Take one or both to appeal depending on the result. That’s assuming you have time and money on your side. Appeals are running at a year atm, so factor that in. Of course, you won’t get an answer up front, that’s what the decision process is for. Nearest best thing is your architect’s and/or planning consultant’s judgement. My experience of pre-apps (only two) is that they’re a complete waste of time and can be actively misleading, which is worse than not doing them in the first place. That may be case officer or LPA dependant. How good is your LPA? - look up the stats. Yes, like a tombola, there’s a lot of luck involved and most of the LPA’s judgements are simple opinion cloaked in planning jargon - it’s not a rational process at all. Engage your councillor too.
  5. Hope that goes well and a fit of common sense breaks out at the LPA. I assume you don't have CIL there? Beware of submitting another full application if you do - it may well be very costly.
  6. OK here's my 10c. I've installed a three of these and I've had a couple installed elsewhere (not by me). The comments above are kind of true. You don't mention what is below the 'light cement floor' or what room this is. Bathroom? It makes it so much harder if we have to extract the clues from you like some kind of cryptic crossword. My floors were all in flats so it wasn't like there was 300mm of concrete below. 4 bathrooms, one kitchen. I think these were laid on the subfloor in all cases (probably chipboard) with a thinnish (maybe 6mm) 'tile backer' board. I would have used a thicker board knowing what I know now about insulation. The three I laid were all heating wire rather than heating mat. Two had ceramic tiles over (I didn't lay those two), one plastic tiles of some sort, two resin (Suba I think). You might want to put in an extra thermistor btw for redundancy. They all work(ed) fine (one flat is sold now). All on a thermostat and a timer. Not too expensive to run. Very quick to heat up. Quite effective I think. Lovely if you like warm feet in the bathroom. One failed - due, I think, to something leaning against the controller causing it to overheat. I have UFH in one bathroom now at a different property. Works fine again, much slower to heat up. Not sure what's below it.
  7. Yeah, I think it's answered here: i.e. a '4m' tower has a 'platform height' (bit you stand on) at 2m, a 'tower height' (max height of safety frame) of 3m (i.e. 1m higher than the platform) and a 'working height' (reasonable height you could reach up to) of 4m. So, if you need to actually reach a widget at a height of say, 8m, you need an 8m tower. Ladders are similar. This assumes you can reach up 2m higher than the floor. Even as a short-arse I can do that, at least for a while holding some light tools. Holding a heavy SDS drill all day drilling into concrete? Well you probably need something 1m higher so you can hold it at waist height.
  8. Suggest giving the whole services in the wall thing a miss. Use surface mount plastic sockets and plastic conduit or metalclad and plastic or metal conduit. You might want the sockets above desk height for ease of use and it's possible you might want a group on a big switch so they can all be turned off at once. Sure in a ring main around all the walls. Philips square led panels for my money - but screw straight onto ceiling. Ensure all insulation and heating is going to work properly - you don't want it to cost a bomb to heat. Ditto windows - it may be cost effective to install double glazed and better frames. Maybe a quick stab at the J Harris spreadsheet to check. Wall mount remote controlled fan heater for quick heat up before you start work. Whatever heating you're comfortable with after that. You could fix up the wood burner if you really like it, but it'll take up quite a lot of effective space once you keep everything flammable away from it. Strictly, the install/recommsiiosning should be (or if BC is not required, for your own peace of mind) Hetas or BC-notified. Don't ignore solar gain either - my workshop gets crazy hot in the middle of summer.
  9. For associates: daily rates vary between £450 and £1,700. With the 10 most extreme values thrown out, the spread comes down to £800 - £1,050. So, say £925?
  10. For anyone following along at home, I'm finding 2023 daily fee rates are: Partners/Directors £1,240 Associates £920 Other Chartered Planners £680 Which if you assume an 8-hour day is £155 / £115 / £85 per hour. This compares to the solicitors rates:
  11. 3 water strikes plus standing water at the surface - no indication how much. Surprising to get standing water in July, but maybe it just rained. Standard Penetration Test value of 7 at 1.6m? Cone Penetration Test value of 50 at 4.3m? Surprised to see both in the same bore. https://en.wikipedia.org/wiki/Cone_penetration_test https://en.wikipedia.org/wiki/Standard_penetration_test So suggest v. soft @ 1.6m, quite hard at the thin sandstone layer. I think you need to just get on and either run a proper SI or use a digger as suggested and/or ask local BC and/or engage an SE. There's only so much you can accomplish sitting at a desk. Personally I would do the last three to start with. You find out in a matter of minutes what's going on down there with a digger. Even better if you have BC or SE there while you dig. Doesn't preclude geting proper bearing numbers / particle size analysis / shrinkage / chemical analysis using an SI later, but gives you a good clue what's going on with groundwater and you also get a rough idea how firm the ground is. What founds are you thinking of? Strip?
  12. Great views, very nice. Yes, I assumed you were designing in longhouse style.
  13. >>> My only concern is storage Nice design. Looks like you have ample room for a big shed once you've filled up the loft space in the garage. 😀 Put up a picture of the view to make us jealous?
  14. >>> screws are screwed, rather than hammered I've seen my dad use something he called a 'brummie screwdriver' (i.e. a hammer) to sink screws most of thier length. And he won a few prizes for the wooden sailing dinghies he made.
  15. Personally, for the hassle factor I would always go Plasson. You will find that as soon as you get away from bog standard fittings (and 32mm is just starting to get non-standard) that the prices vary wildly - so you need to shop around and ask for discounts and be prepared to order on-line and wait. This isn't B&Q stuff anymore.
  16. Yeah something like that - you're just ensuring that any water runs off. Usually no need to hold down, just do something subtle with a leadworkers mallet. Re the flue - you don't say which make it is, but they usually clip together with an airtight seal, very simple. Check the stove instructions - the outlet is usually sealed to the flue with rope and special 'rope glue' e.g. https://www.solidfuelappliancespares.co.uk/product-category/spares-accessories/stove-sundries-accessories/door-rope-seal-kits/ A CO monitor, smoke test etc and you're done. This kind of work is notifiable to BC if it's not done by a hetas person.
  17. My vote would be replace with EPDM - but we’re a bit short of details. Size, pitch, complexity? A picture always helps.
  18. FYI there is a record low in both planning applications & planning approvals - so how are they overworked? https://www.bbc.co.uk/news/articles/cn034n47528o
  19. >>> I'm now stuck, as I don't know precisely what investigations to commission and how to scope these. What would you guys do? Ask the SEs (who are still at presales stage) to advise? Contact some geotechnical companies and ask them? Something else?? <<< An SE will spec your GI for you for a smallish fee, say £250. Check yourself that it seems to make sense.
  20. >>> You need to play nicely. Yeah, our neighbours did - and their non-contentious application took the LPA a year. By which time the economics of what the neighbours were planning had changed for the worse and so having gained permisssion now, they don't intend to use it.
  21. >>> Appealing to the inspectorate for non-determination means a guaranteed delay of about six months though. Actually a year. I have seen before an informal appeal used to the case officer's boss - the org chart of your LPA is probably published like ours is. Another avenue is the councillor for your area - if anything like ours, that person and their contact details is shown on your planning application on your LPA's portal. An increasingly common problem I think, let us know how you get on.
  22. That’s odd. Ours puts out so much heat we often have to open the windows to cool the place down. We’re fairly tiny at 85 m^2 though. We’re an EPC E on paper, although it’s possible we’re actually a C or D. This is a Rais Viva 100L. Pretty much the only heating we use.
  23. >>> I'm perplexed as to why all the SEs I've spoken to so far seem to be being so very cautious Well, looks like it's quite soft going to 2m or so. The problem is that your ground may not be exactly the same as the ground 85m away. Your soft layer could be at 1m or 4m. Which it is, is important, of course. The route of the storm drain may also be an indication of extra water local to your plot. So, you probably need at least a couple of bores / digs near your proposed foundations. The alternative is to just start digging your foundation trenches and be prepared for BC to say 'you need to go down another metre or two' or to have to order in an expensive pump on the fly.
  24. FYI, there’s no problem adding more than 4 materials with the free version.
