Alan Ambrose
Everything posted by Alan Ambrose
I like the idea of ply over, say PIR, insulation.
>>> When a contractor quotes for piling it's an assumed depth just like most foundations. Can I ask - does this also work if they have to go less deep than they thought i.e. they give you a reduction?
@Tony L Thanks for that - that does look a bit tricky - but congrats on handling the problem. How big a pump did you need? I've been talking to some basement guys (Keller) over the past few weeks, and they said they don't mind clay as the inflow of water is normally fairly slow, unlike sand. >>> I did some research - it's usually at its lowest during the first week in October That's interesting - did you find some stats somewhere?
Concrete into a former to get the shape you might have had if you had started at the beginning? Or a stack of marine ply, ditto? >>> Any suggestions for what I should dress the raised edge with? Matching cut floor tiles? Stainless strip? It's an aestethic decision, so personal choice. Post up a photo maybe?
Plant hire insurance
Alan Ambrose replied to flanagaj's topic in General Self Build & DIY Discussion
Can I ask - are there any other 'legal' considerations for operation of that kind of machine yourself on site? Loler, training, CDM stuff? -
Steel spine staircase
Alan Ambrose replied to crispy_wafer's topic in General Self Build & DIY Discussion
Someone like these guys can probably make you what you want. There's a bunch of them (fabricators) on eBay: https://www.ebay.co.uk/itm/265716170596 https://www.ebay.co.uk/itm/304667947333 -
This is percentage of applications approved within 8 weeks. The 'top 5' should be special measures as they fall below 70% Richmondshire 55.6 Bristol, City of 57.8 Scarborough 61.7 St Albans 67 Halton 69 Harborough 73.4 Fenland 74.1 Herefordshire, County of 74.5 Teignbridge 74.5 Slough 75.9 Castle Point 76.1 Thanet 76.1 East Devon 76.4 South Lakeland 76.6 East Suffolk 76.8 Hyndburn 77 Westminster 77.3 Exmoor National Park 77.9 West Northamptonshire 78.1 Stafford 78.2
Hi, I want to put in land drainage in to make the back of my plot less wet in the winter. This area has fruit trees in atm and will eventually become garden. This is in clay and to feed into a 300mm culvert that's already there ... + what depth would you put the drains in? + what diameter? + how far apart? + would you have a silt trap? Would you use fabric or sand somehow for filtering around the pipe (as well as 20mm stone)? Would you expect this to get clogged over time? Any other tips?
I think you need a bit more meat - what kind of insulation standard, for instance? Is there a spec somewhere or are is this a rough quote with a lot of the detail left out? If the latter, there may be a lot in there for 'builder's contingency' for stuff left unspecified.
Err, remove the pipe, flash, put the pipe back with suitable standoffs?
A pic would be useful. I wonder whether this is due to moisture ingress - sandstone is fairly porous. Water expanding into steam might do it. Maybe granite would be more impervious to moisture. Or maybe a metal (cast iron?) or even sand hearth?
Vendor finance is quite common in the US, I'm not sure why not here. The risks are mainly on the vendor's side - after all they're giving you a loan. Have you got as far as discussing terms - see if they're reasonable? Potential for a good deal, of course, if they want to sell quickly.
If you do go down the pumped route, check out the discussion on Stuart Turner here:
I think I might be tempted to engage my own (proper) SE to do a survey of both sides of the wall at the same time as the other guy. The scenario you want to head off is 'pseudo-SE states problem is all down to you' followed by 'immediate claim of your liability and promptly whisked into court'. The 'expert witness' thing is maybe a bit of a red flag? At that stage you would be arguing (their) SE's qualifications and since it would be in the lower courts, the result might be a bit random. If you were able to present your proper SE's analysis and report at the same time, that might just head the problem off.
>>> Option 1/ will only make relations worse IMO I think sometimes you need to be firm with unreasonable people. As an example: I have a neighbour to my plot who recently declared "water from the rear of your plot is not going to cross our property". He hasn't given a reason or any hint about what kind of problem this might cause, if any. I have been perfectly pleasant to him to date. The drainage is, of course, very important for us and historically there has been drainage ditch there (now a culvert, converted before I bought the plot). It runs in his direction and all the neighbours use it for rainwater drainage and treatment plant outflow. I have sent him a pamphlet from our LPA describing how riparian rights work with the relevant sections highlighted. He hasn't replied. Next I will offer him the opportunity to withdraw his statement/threat or the alternative of a solicitor's letter confirming how riparian rights work. In my experience there's always someone trying to take the piss. You can try and deal with them sensibly and argue them round. But sometimes you have to treat fire with fire.
Ah tricky neighbours, don't you love them? >>> they are trying to blame me for it. Ah you sure that's the case or is that just a fear? There are a couple of options: (1) If you're sure they're just causing unnecessary trouble, then I might string them along and let them get their court order. Write to the solicitor as often as you can to bulk up their legal bill. In the meantime, be assertive and send your pictures to them with a polite but firm letter. By all means chat to them in person and see if you can defuse the situation and thereby stop wasting your joint resources. (2) If you're sure you have not caused a problem, give them access, and give the SE your dated photos, bend the SE's ear re your theories about their plants.
Maybe the combination of house prices ticking up, mortgage rates ticking down and reasonablly quiet politically for the forseeable.
Who ultimately decides and how can I know upfront?
Alan Ambrose replied to flanagaj's topic in Planning Permission
>>> I had this, the local housing stock was a complete abortion of 1980’s fake Cotswold stone, there was no way they could say they wanted me to match in with a load of houses that shouldn’t have been built like they were. Yeah, quite, sometimes LPAs can’t see the wood from the trees. Soneone should tell my LPA that the objective is to improve the housing stock, not to bring everything down to a 1950s prefab standard. -
Smart meter external aerial last ditch attempt?
Alan Ambrose replied to SuperJohnG's topic in Consumer Units, RCDs, MCBOs
Do your SIPS have a foil backing maybe? That might do it. The first solution he talks about is quite straight forward. If you’re not confident with a soldering iron on PCBs I might find someone who is - a geeky and capable teenager maybe? p.s. Like the writer of the article, I can’t believe they didn’t design for a possible external antenna. -
>>> using the design process to understand what we want, as a learning tool Yeah, that's a perfectly valid design technique. You're the customer, do whatever you want. You might like to consider what orientations (sun, views etc) work well with your designs. As are mood boards, magazine clipping files, physical models etc etc etc. If you have the time and energy, there's nothing to stop you thinking about construction teechniques, insulation amounts, plant etc. And reading the 'ub here to learn a lot.
From planningresource.co.uk - I didn't know anything about a 26 week rule? Bolton Council last November revealed that it had been wrongly keeping fees paid to its planning department that it should have been paying back. Since 2013, local planning authorities have been legally required to pay back fees if a decision has not been made after 26 weeks, unless other agreements or exemptions are in place. Now a 12-month internal investigation has reported that the ““the potential maximum financial liability, if we go back to the commencement of the change in legislation, is £450k”.
Regional energy pricing
Alan Ambrose replied to Alan Ambrose's topic in Environmental Building Politics
Oh I see - that’s kinda dumb surely - capacity should be real world capacity no? i.e. what could be generally be generated if nobody was told to throttle back? I guess the economics makes a bit of sense - pay generators less if the grid has to spend lots on that part of the grid to make their electricity viable? Make electricity cheaper around the generators for those who have to put up with the infrastructure? -
You should be able to plane it quite easily, but the edges will be even more vulnerable I think. Possible to cover them with something at least temporarily waterproof? Some kind of tape maybe?
https://www.theguardian.com/money/2024/oct/07/ive-fallen-out-with-people-the-bruising-debate-over-uk-zonal-energy-pricing Anyone understand why all regions seem to have generation capacity much higher than peak requirements?
