Alan Ambrose
    15
Everything posted by Alan Ambrose
  1. BTW you can have quite large faults in timber due to shrinkage that don't affect the strength much. It's all crazily oversized anyway, that's the joy of it, for me at least.
  2. Some tarmac in bags from a cheap DIY store and a welly boot?
  3. OK then there are two problems: (1) the 'engineering problem' of how do you make the roof & veluxes work, and (2) how to get that solution implemented in a sensible way without impacting the warranties. Those are (kind of) parallel problems in that can be solved independently. Question is: whose responsibility was/is it to solve the engineering problem and does any of that responsibility fall on him? On you? Someone else? Was there any written agreement? Has no one seen this coming up in advance i.e. there were not some SE drawings to build to which included this detail? In terms of getting him to be more tractable, maybe a warning shot letter from a solicitor suggesting that it was 'obvious' that the roof and veluxes needed to work together (or include terms from the agreement) and/or suggest 'poor workmanship' if you feel you can justify it. Suggest it would be better for everyone if you worked together to solve the engineering problem. Ask him why it is that he has never encountered this situation with roof and veluxes before? Is he inexperienced? Tell him he doesn't get his final payment until the problem is solved and/or if he doesn't help to solve the problem you will appoint an expert to solve it at his expense. Tread as softly as you can but make make it obvious you carry a big stick. Maybe a third party to help solve the engineering problem - most of this isn't rocket surgery after all? Post up some images / drawings here?
  4. Oh dear, that's disappointing. Suggest first sitting down with them to see whether the problem can be resolved. Start off by saying you would prefer not to have a time consuming and expensive conflict. Is it obvious what practical change needs to happen? - cutting slots out for the hinges, for instance? If so, you can discuss how to get that done without breaking the paperwork. The warranties are probaby worthless except to make a mortgage company or later buyer happy, so I would focus on the above - how can the required physical changes be made with them still providing their standard warranty? You can also very subtly hint on the bad reviews you're likely to post ('I would like to be able to post some good reviews') - that means a lot to all businesses these days. p.s. I would definitely hold the final payment until you have a solution at hand and has been implemented. Presumably this could be as simple as a some careful multitool work and (a) agreed in advance and then (b) signed off ... by whoever is installing the veluxes.
  5. >>> if i get a positive response and then they go on to actually refuse the application surely that would be outrageous We had two pre-apps: one by the previous owner of the plot. One said simply ‘can we build a 1.5 storey?’ (There was already permission for a single storey.) Answer was ‘yes’. Seems the LPA significantly hardened their attitude over time. The single storey application had a single line in the design & access statement re the relationship to the ‘heritage asset’ farmhouse about 75m away. That was deemed sufficient by the heritage guys. For our later applications, the LPA demanded extensive heritage statements - this is for the same plot. Our 1.5 storey design was thrown out for the reason ‘too big’. This, without explanation of what would be an appropriate size and an extensive analysis by us of all the dwellings in the cluster, some of which are 1.5 storey and an 1.5 application has been approved next door. The second pre-app had our single storey design. This time the LPA didn’t like the idea that the building wasn’t positioned exactly parallel to the road, despite the fact that we explained that this was to ensure minimum south facing exposure for solar gain but maximum effective PV generation through the day. The LPA has a specific policy to support this approach re orientation to the sun. Also there are 4 hotch-potch barns next door with different orientations, heights, shapes, roof slopes etc and we would just be seen as part of this set-up. Many, many months later, the same case officer tells us he wants to approve this same design that he ‘turned down’ at pre-app. Nevertheless, the LPA then argued against this design at appeal with some spurious arguments that the inspector then threw out. So, that’s two flip flops. I’m pretty sure we’ll end up building that design after resubmitting it. This is not pre-app but similar. For our present barn conversion, heritage told the developer ‘knock it down if you want to, it has no heritage value’. The developer ended up converting the existing barn. Trying to get our PD rights re-instated, the LPA argued ‘it was important that they had control, so they could preserve its historic barn-like qualities’. Yeah, right. Note that you are unlikely to get any explanation or apology for any change of in LPA’s view. I think as they know there’s no come back then the LPA’s give the pre-apps to junior people and they spend no time on them at all - they’re probably the least important bit of work they do and a small money earner if they can knock them out quick. The LPAs care not a jot that you may expend considerable resource based on their advice, but are happy to change their mind on a dime without any expectation that they will need to explain or justify their change of opinion. So, I will now always opt for full applications - at least the results of those are ‘material’ (i.e. you can argue the LPA’s present decisions should be consistent with their past ones.) Whereas pre-apps are not. Now I think that there is great randomness and variation between LPAs and even between case officers at the same LPA. So, you can also be lucky or unlucky at the amount of real communication and the veracity of the advice/decisions. That is, pre-apps are a complete crap-shoot random number generator imo.
  6. Isn't it odd that all the 'rules' seem to be written in favour of the landowners
  7. See 'doublespeak': https://en.wikipedia.org/wiki/Doublespeak George Orwell saw this coming in 1949, clever guy. He told us how it works and we said 'hey, that seeks a good idea'.
  8. FYI these kind of companies often have quotas of various kinds of customer & risk to balance their portfolios. When they have reached the quota of one type, they'll downplay it until the others risks (in terms of monetary volume) have caught up a bit. That way they keep their portfolios how they want them.
  9. These are fees from the mortgage company's solicitors? In conveyancing terms, they're not that high nowadays. These'll probably be in-house guys. The biggest element is the search pack and they're looking for things that might impact your build and therefore reduce their security - covenants etc. To that extent, the searches are in your interest even though you may already be sure there's no problem there. Computer says they have to check. I don't think you have any option apart from from talk to a different mortgage provider, and the competitor's fees probably won't be any different. Like the mafia, just a cost of doing business nowadays ..
  10. @DevilDamo can I ask - you’re a planner / ex-planner / planning consultant?
  11. That’s the other thing that’s teeing me off with LPAs atm. They’re ignoring the ***** rules. Mine ignores the 8 weeks or negotiate-the-timing rule. They also ignored the absolute basics in the Procedural Guide for appeals and the inspector let them. When your state institutions themselves lie, I mean ‘mislead’ with their stats and ignore the rules, then everything is falling apart rapidly. A friend who’s an architect and has worked in France tells me that if their equivalent of the LPA don’t meet the specified timing, then the application is automatically allowed.
  12. Yeah, I think this 'we refuse to talk to our customers' thing is just making everything much slower and more resource intensive - for the LPA as well as the applicant. In my case, I've now put in one pre-app (the seller had also put in one), two applications, two appeals, I've just filed my costs with the LPA and I'll submit the original application again on Friday. I'm pretty sure now I'll get to build what I asked for on the pre-app several years ago. If the case officer had read it properly and discusssed it with me for an hour, we could all have saved a couple of years and a lot of resource. This is like doctors refusing to talk to their patients; polititians refusing to talk to their constituents; businesses refusing to talk to their customers (all online businesses?). It's all going to go downhill fast and then someone will discover that a 10 minute chat could avoid work for everyone lasting several years.
  13. The topo people normally do something sensible, but add anything you think might impact planning or building. It's annoying to go 'I wish they had measured xxx while they were there', but you will undoubtably forget something, so don't sweat it. (for planning) + Ridge, eves, position of neighbouring buildings + Location, heights of existing building, driveway, access, gates, paths, outbuildings (for building) + Positions of services, drainage runs, manholes, inspection hatches, invert levels, ditches, culverts, meters, position & height of poles and track of overhead lines + Size, position, spread of trees + Geo features - ponds, fences, boreholes, wells, hedges, ridges etc
  14. Yeah, some time ago I paid extra for a pre-app to include a meeting with the planner to discuss. Well ESC didn't honour the meeting and didn't refund the fee either.
  15. Are their any external blinds which have electrically controllable height and blade angle?
  16. Goodness gracious - some daft planner thinks someone will go to the trouble of applying for PP, building a house and possibly paying 10s of thousands of penalty CIL for selling within 3 years - just to avoid BNG. These guys are operating on another ..!.X..! planet.
  17. Concrete screws or old fashioned wall plugs?
  18. Both my pre-apps were a complete and misleading waste of money - both exactly wrong. Suggest consultant, do your own research on the planning portal and/or full app and option agreement. Bear in mind - unless your site is very straight-forward you may be going round the planning loop more than one time.
  19. Sounds a newish property? Fix it all as above, document everything, then set about reclaiming the money from the builder. If you can find him, that is, you can send him a warning letter up front.
  20. >>> The Cil is very clear Yeah, I think it's a badly written and fragile bit of legislation that can catch the unwary for multiple £10s of thousands if they just get the timing or a single entry on a form wrong. We, as a society, have far too many unethical 'rules' like this - forget to pay your £1 parking charge or enter your reg wrongly - well that'll be a £100 fine, thanks. Earn £10 of the limit as a carer - we'll demand 10 years / £40k of carer's allowance back. I wonder what the S106 advantage is to the LPA over and above the CIL legislation?
  21. Ah, glazed ‘arrow slits’ should look amazing - the opposite of the current ‘as much glass as you can’ movement. All mysterious, castle-like and seductive.
  22. You could perhaps have a contract subject to planning. Or do one or more pre-apps (which remain private) to see whether your LPA will countenance anything at all.
  23. If the question is ‘who’, then I think ‘HETAS engineer’ is the answer. Btw a simple diagram or photo helps these kind of questions a lot.
  24. >>> I do question “no new openings” Me too, the openings in there right now don't look 100% authentic. I think we should concentrate on beautiful and efficient and great to live in buidings for the future. A lot of the old stuff, particularly old ag stuff, probably had 5 minutes spent on 'design'. And we're going to go out of our way to 'preserve' this? Ag buildings were built for storage and/or animals ffs. Wouldn't it be an idea to allow a little more slack for the new usage for humans? A friend has a listed place. Heritage were doing a barney about keeping some stairs - until the owners found someone in the village who had put them in in the '70s.
  25. What a lovely old building. It would be interesting to hear more sometime about the steps involved in obtaining consent from the listings people.
