Alan Ambrose
Everything posted by Alan Ambrose
Just got my PD restriction removed on appeal
Alan Ambrose replied to Alan Ambrose's topic in Planning Permission
No it wasn't class Q - just conventional planning permission. My LPA removed PD from the recent permission for a whole new village estate of 20 conventional houses - I think the LPA do it now as a matter of course. I guess the developer doesn't care. Some are 4 beds with big gardens. Amusingly, for my place, when the developers got permission, the LPA heritage people said 'knock it down if you want to, it doesn't have any heritage interest'. And 6 years later, the LPA, in response to my application for reinstatement of PD rights tried 'we need to control its barn-like qualities'. Yeah right. -
I was just reading this bit here about PD addition of extra floors ('class AA'): https://www.planningaid.co.uk/hc/en-us/articles/360012081098-Extending-upwards-building-additional-storeys It talks about "Prior Approval of the Local Planning Authority on matters including external appearance and the potential impact of the extension on the amenity of neighbours (including overlooking and loss of daylight/sunlight)". That sounds a lot like householder planning permission to me. Is there a difference?
Clicking noise from UFH manifold when it fires up
Alan Ambrose replied to thefoxesmaltings's topic in Underfloor Heating
From memory there's a fair bit of pressure required. I think there's a strong-ish spring under the plunger and, of course, a valve. The actuators are quite interesting in that they work by heating up wax which expands and then forces the pin down. When the heat is removed, the wax cools and shrinks and the spring helps push the pin/plunger up again. That's why they work quite slowly. You could try pushing the pin up and down a bit - that will require quite a bit of force - to see whether that's the part that's causing the noise. You could compare with its actuator neighbour. If you're being clever (mark the actuators in advance) you can swap over actuators between valves/circuits and see whether the noise is connected to the valve or the actuator. You'll need to be careful to figure out which stat is controlling which actuator / valve combination. Read off the actuator model code while it's easy, so you can source a new actuator if you need it. I've just twigged that this is a newish installation, so you might just have a dodgy actuator or valve installed. It's possible that there was something wrong with the valve install, although that's fairly unlikely. Can you not just get the original plumber back in? -
>>> So I've narrowed the noise coming specifically from one of the actuators. Neat, well done. Try and reseat the actuator (pull it off and put it on again) to see if that helps. If not, just replace it - they're about 20 quid each. They can be 24V or 240V - in any case power off the controller when you're changing it. To make life simple, just buy the exact same actuator model you have now. -
>>> In the first instance, take the ‘policy’ issue up with councillors, head of LPA, MP etc? If the kids are not playing nicely, then you need to take it up with their parents. Ask consultant to write to head of council etc asap, with the implicit threat that it'll be the the press next.
>>> we’ve also engaged a structural engineer and architect who completed the detailed drawings, structural calculations, and other documents for the Building Control submission. Even they are baffled by the issues (?) raised by the council. If they are meant to be preparing documents that satisfy (amongst others) BC - then the responsibility rests on them to amend the drawings and submissions to satisfy ... BC. Otherwise they shouldn't be paid for their job. That is, push the responsibility back onto your archiitect & SE. In other news, I think there's some mileage in taking the docs you do have to a private BC before engaging them and asking them whether they are happy with those docs. It's a free market and you can buy your BC services from any organisation you like.
Small progress. Just because my LPA were teeling me off, I submitted an application and then an appeal to have my PD rights reinstated. This is for a barn conversion completed in 2017 (not by me). My LPA seems to remove PD rights on all new houses. So, one small step forward. I'll post up a sanitised version of the appeal docs and decision notice when I get a few minutes.
- 3 replies
- 10
Experience with EA for PTP permission to drain to culvert
>>> Can you not discharge under the general binding rules No, otherwise I wouldn't have put the application in. It's actually a bit hard for the uninitiated to navigate when and when to not use the rules. As I looked at them back in May, I don't remember which bits didn't fit when I sent the application in, but I'm sure the EA would have pointed it out if they thought I didn't need to apply. As far as I can see, the general binding rules came in in January 2015. My neighbours have houses ranging from hundreds of years old to ones built in the 1940 to 1960s - so there will have been little if any paperwork for them to do then. They kind of get 'grandfathered in' - which is usual but a whole topic in itself. On reflection, the system seems a bit bonkers - someone's designed something to 'cover all bases', but it's hugely inefficient at processing simple applications, both for the applicants and the EA. -
Demolition exterior spiral staircase, permission needed?
Alan Ambrose replied to Zab's topic in Planning Permission
>>> how I might be sure Only by confirming with BC. It will originally be there for fire regs I expect - so you'll need to be sure it isn't needed. BC are usually lots more accessible than planning, so you may get an email answer quite quickly or a quick visit to confirm.- 6 replies
- demolition
- building control
For anyone else in this situation, I thought I'd document my experience with the EA applying on form EPB B6.5 for an application to drain a STP to the culvert at the back of my plot. This should be fairly straight-forward as my 5 neighbours all drain their PTPs to the same culvert, duh, and the nearest villages with actual sewers are a couple of miles away... + I sent in my 24-page EPB Part B6.5 form and block plan back (and payment) in May and got a receipt for the payment about a week later. I got a call from an EA drainge person last Friday ... that's 5 months. I have asked for status updates by email a couple of times and those were ignored. I called about 6 weeks ago and they told me (a) we can't find your application, send it again and (b) it'll go on the top of the queue. + FWIW (a) I think there's something dodgy with their email receipt mailbox and (b) they don't seem to reconcile the applications with the payments. + About a week ago, I sent in another status request by email and was told that my application would, in fact, go at the back of the queue. I asked them to start a formal compaint. + An EA guy called me late last Friday with a few extra questions - he wanted grid references for everything and a description of the flow all the way to the first named watercourse - which is a river 3.6km away. Gave me 5 days to reply. Yeah right. He said it might take another 4 weeks to approve the application assuming everything was good. So, that'll be end-November, 6 months. BTW I found this reference https://gridreferencefinder.com/ - which is good for converting one style of grid ref to another and also for getting grid refs from maps.
@G and J Stating the obvious - but you do want to be able to get at those easily. I see lots of bathrooms where that isn't the case. I thought I allowed for it in my present place, but it's not as easy to work on them as I'd thought - 2 to 3 hours of buggering about to change the tank or valve.
Sounds like expansion noises due to ... heating. Is it bothersome? Radiators sometimes make this noise - probably from the manifold fixings? -
Floor outlets required....can I use standard backboxes?
Alan Ambrose replied to Thorfun's topic in Electrics - Other
Reckon. "Normal floor box" as in office-style? -
Err, I'm not sure I understand. How can the elevations not implicitly indicate the ridge height? How was the ground level marked so it was incorrect - from a datum level maybe? What kind of adjustments could you make to the ridge wthout affecting the elevations? Are you thinking of bumping the whole house up? I guess as the sectional drawing wasn't mentioned in the decision notice, it is largely irrelevant to the planners.
Is this the base of a former cattery or am I mixing things up? If something like that then suggest it’s not very deep with minimal reinforcing. You could dig down the side of a bit and look. Then belt a corner hard with a sledge hammer and lever with a big pry bar. If that’s easy then smaller, if you made no impression, then larger. Do you need to remove/move any hardcore that’s underneath?
>>> There is currently a concern amongst many LAs of applicants falsely claiming self-build status in order to avoid BNG. That's been said before and I don't think there's any basis for it. In fact I suggest it's complete nonsense. So, there's a bunch of developers in many LPAs (enough to warrant an actual policy for) who develop single dwellings, not as limited companies, and try to swindle their LPAs out of BNG? Yeah right, how many LPAs have more than a handful of self-builds every year? How many get sold before 3-years is up? The developers do the entire complex Everest-like self-build journey for the purpose of saving some BNG? And they sell before 3-years for this scam rather than for instance dying or divorcing? It would be easier and safer and more lucrative to be an internet scammer I think. CIL has a whole mechanism to verify self-build status -- self-build mortgage, self-build VAT reclaim etc etc etc. Why would LPAs need another mechanism?
Electricity pole relocation
Alan Ambrose replied to flanagaj's topic in New House & Self Build Design
Ah don't quite follow (and resolution not good enough to read key): + "existing LV in ... blue" is actually show in yellow? + straight red line is exising HV? + pole to be moved is the one in the wavy blue circle? to be moved ot the boundary shown in red wavy? My data point is one new LV pole installed / ~50m o/h line removed / replaced with ~50m underground in trench - added up to £16K (all by UKPN). (There was no attempt at negotiation afaik - wasn't my shout). Are you actually payng for the new HV pole, or is that at their expense? Looks to me like probably a new span of LV line is required (if the move results in a slighly longer route) plus a pole move. That's what the short written summary says. If you go ahead, it's worth watching whether they actually use new LV line. Ditto the HV pole. They do tend to take the piss (for what will be a leisurely 1/2 day's work) although some on here have either been lucky or negotiated based on common sense. Probably 4 people on site - the pole guy with the machine to swap poles, a couple of riggers with a lift and a guy to put up red plastic 'safety barriers'. None are probably needed, but he'll probably put them up anyway. Easy for them to get their lifts and machines where they need them? Have they proposed traffic management or road closure? That's expensive. -
>>> It states ‘no added formaldehyde’ - does this mean totally formaldehyde free?? Maybe in the sense that smoothie makers say ‘no added sugar’ but the product contains plenty of fruit-based sugars.
Personally, I think it’s important LPAs (and other public institutions) stick to the ‘rules’ and not try to circumvent them. This can’t be an official policy as there just are not that many self builds. In the first instance, take the ‘policy’ issue up with councillors, head of LPA, MP etc?
That sounds a lot, did they give you a cost breakdown, drawing etc? They should do otherwise it’s just a ball park not a proper job estimate. What does the job involve? Post up the quote & drawing? -
Thanks for that, v interesting.
